Everything posted by bobyellow
Send the cable out the 'side' and under the trim. The trim lifts easily as it only has clips holding it in. There is a gap in the frame of the compartment.
Nope. Have a 5% cash back Amazon card. ? So I win! Only $40.27 (with free shipping and 5% back). And don't need to create another place with my personal details (or type them in).
$40 on Amazon. ?
Yup. Lots of times. Mostly for P to R for me (in garage backing out). After a cold start. Doesn't sound good for sure.
Normal. Always happens on mine.
bobyellow replied to ben senise's topic in Accessories & Modifications
You can retrieve your's from you VIN. https://www.motorcraftservice.com/asbuilt -
On the tuner>> Vehicle Info Code: Orig: CNDK2F3 New: CNDM1A4.H32 SW Orig: K2GA-14C204-ARK New: K2GA-14C204-DGA
Interesting. When I had a PCM updated in Feb, prior to the official TSB, I had a new strategy code... my LMS wouldn't even connect. I'm guessing that the cloud now 'knows' about the new PCM. I would recommend reaching out to them. Hopefully you saved the stock after the PCM update! Otherwise you might be reverting to the old 'bad' shift points the next time you revert to stock.
Hello. Welcome. Did you try using the search feature? 'remove bumper'.... 9th or 10th result yields (looks like fun!)
Basic exhaust system shown. Edge has one 'suitcase' muffler, not two as shown. The Resonator helps to control the sound by slowing/expanding the exhaust. Without it, you might get a drone sound which is not pleasant. Some don't care about the drone. The x-pipe 'crosses' the two exhaust flows and replaces the resonator. Should reduce back pressure, increase performance. If you look at MRTs page, it lists the axle-back exhaust with a '2' drone.
Edge ST (worked for me). This is different location than you are showing (?). 41 vs. 40 (is the shown spreadsheet your record? maybe you recorded it incorrectly?) Close Double Horn Honk (Engine Running Without Keyfob Detected (PTS)): 726-41-02 (2014+ MY) xxxX xxxx xxxx 1 (Enabled - Default) 0 (Disabled) Orig: 0101 0101 I love this change for when I take out the trash (very long driveway with neighbors at the end). At 5am, they are 'happy' not hear my double-horn beep when I open close doors! Three places with code to try(check): https://docs.google.com/spreadsheets/d/1qf2gYgkhmsX-dnFO3Ki0nYUvr7aeLKsHsA0WxhDns1s/edit#gid=0 https://docs.google.com/spreadsheets/d/1yax6zfhZYj2joBczEeruqKh9X5Qhee3C0ngilqwTA7E/pubhtml?gid=0&single=true https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466 The 150's have some accessories not on Edges (like better gauge clusters and massaging seats).
You need to use FORScan or know someone who has it (or a friendly garage). Never seen anything to disable Trailer Sway (do you have a light plugged in for a hitch light?). Disable Start/Stop (has a side effect of not monitoring your battery). Auto Start/Stop Disable - by disabling BMS (Battery Management System) BCM 726-48-02 x0xx xxxx xxxx FCIM 7A7-01-01 xxxx x0xx xxxx (optional - disables switch) IPC 720-01-01 xxxx 1xxx xxxx (optional - disables stop/start message center in the trip/fuel IPC menu)
Not tried - Enable view text/new input while in motion (disables traffic and I use that feature occasionally). Yes, works - Door close double horn honk. Yes, works - Turn signal flashes on quick tap. Others (not highlighted) Yes, works - Secureidle Not tried - Adds an 'Average Speed' menu There is a thread already covering FORScan in the ST sub-forum. ? Generally, any newer Fusion (and F150) code works for our STs. The only one that I've found not to work is the winking of DRLs and turn signals.
Yes, if the package you have contains 'steering wheel mounted paddle shifters'. AWD should(might) have them on the steering wheel *with select packages. 'Optional AWD Disconnect, SelectShift® capability and steering wheel mounted paddle shifters'. I use them on tailgaters!
Alternate Path: Use Fogs as DRLs. Far enough away so 'legal'. With FORScan, you can set DRLs to not turn off with turn signal. Enabled DRL Selection (BCM): 726-50-01: XXxx (my AsBuilt was 10) XX: 01 = Disabled / Parking Lights Only (See change below) 02 = Low Beams 04 = Front Fog Lamps 08 = Front Turn Lamps 10 = Dedicated DRL Lights (LED Light Bars/Strips) - Enables BCM DRL Outputs - C2280F (F-150) Pins 36 (Right) and 40 (Left) 20 = High Beams 40 = Low Beams and Dedicated DRL Lights Combined with 726-26-02 xxx* xxxx xxxx DRL Switchback w/Turn Signal: 0=disable, 1=enable Trying it for a little while.
Any VW/Audi can disable 'winking' with a tool like FORScan (VAG). I used to own a VW and that tool/software is very advanced (more checkboxes with descriptions of changes/functions). I would help locals owners in exchange for a cup of coffee. Supposed to be the following... but doesn't work on my Edge ST. FORScan: 726-26-02 xxx* xxxx xxxx DRL Switchback w/Turn Signal: 0=disable, 1=enable
Looks like it (front is noticeable but on a slight incline so the gap might be skewed). Note: the '19 Edge is almost an '18 Sport so probably just H&R on this one.
Try local junkyards?
I found a way to get a USB cable out of the media hub. Since the spring loaded door doesn't have a cut-out for the cable, I routed the cable under some trim. 1. Pull the trim. There are tabs easily allow removal and reattachment. I know the other side has a 12V port. 2. Send the USB cable through the small hole (red circle). I chose to route it up to a vent phone holder but you could route it back too. The cable was easily pushed between the trim and vent (am thinking of maybe removing the vent to allow it to come in from behind).
- 1 reply
- 4
Just wondering what the 3rd option does... two are shown in the manual (1 & 2 pushes). The ST seems to have a 'hidden' 3rd option (race like the Fusion/Focus?). Presses: 0 - normal mode with car start 1 - Traction control off (stuck in snow/mud or launching at drag strip) 2 - Sport mode, have to push twice quickly. Sport mode which allows the driver to reduce normal electronic stability control system intervention and provide a more spirited driving experience (from manual). Long hold (status bar on display) - 'AdvanceTrac Off' how is this different than 1 quick push? Does this also disable Roll Control? Thanks for any known information.
I don't think it can be used on the Edge ST (I was told I needed the newer version). Also, $300 for a tune for a new VIN. Just saying as yours is 'married' to your VIN.
Key/Remote buttons too sensitive ?
bobyellow replied to Etienne Bégin's topic in Alarms, Keyless Entry, Locks & Remote Start
FORScan (as usual): Panic Alarm BCM 726-37-01 xxxx xxx0 xxxx Panic alarm on fob disabled BCM 726-37-01 xxxx xxx1 xxxx Panic alarm on fob requires 2 presses BCM 726-37-01 xxxx xxx2 xxxx Panic alarm on fob enabled Forscan.org and you need a OBDII connector to a PC. I use an ELM327-compatible USB connector. -
Nice! I'd guess that I've already completed this... or not? I had my PCM reprogramed on 2/15/19. Guess I'll have to contact my dealer to see. Or I was part of the 'testing new software' phase before a TSB is issued.
'Possible' was me talking with the service rep who said "A TSB was issued". He didn't know jack. My VIN was searched and no such TSB was found. Many forum ST owners were hoping for one. LMS - yes, a mod/tune. But the Library of Congress has held up the 'Right' to alter software as long as the modification doesn't break a vehicle (and you don't sell the software), a manufacturer can't hold that against warranty. A tune most likely resets the transmission 'learning' as they warn about hard shifting for a bit. I use it to get better gas mileage. And shifting is fine. FORScan - yes, use it to activate more software that FORD USA has deemed not allowed. Like Open/Close front windows from a key fob (useful when I walk away and need to close; or hot day and want to open to cool).This software can 'break' things in terms of 'Crap, my lights don't work'... but then you just change back to AsBuilt settings (or a saved file).
Only reporting what is on the Dealer Invoice "Checked Linkage and Shifter. Found Update for PCM during Quick test. Updated the PCM and Road test vehicle." It was 'understood' that the software was updated. There was a thread on the possible TSB as that was first stated on the phone by the service desk. Once 'the software' update was completed, there was a new Strategy Code (broke FORScan and LMS tune; until those were updated).
