Nick Halstead
Facebook Member-
Everything posted by Nick Halstead
2015 Edge Sport b-pillar rattle
Nick Halstead replied to ducrider's topic in Interior, A.C., Heat, Interior Trim
Also, if you hear an odd rattle with music off, make sure your passenger seat belt isnt flipped and bouncing off the trim. Thats a general ford problem. -
Rear hatch lights
Nick Halstead replied to Pardo714's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The outside photo in my sig, looks real but it is a render I did. I'm still waiting for the green light for that. Wife isn't too keen on it plus the edge is her daily. The inside is done though. -
I just start pulling honestly, where it feels tight is a clip. Always pull/tug in the tight areas slowly. The 15up is by far the easiest interior I have taken apart. Not many bolts/screws. All snaps in which in turn creates noise. I'm gonna grab some felt eventually for areas I hear rubbing. -
Rear hatch lights
Yup its a "cool" factor which is why majority SE/SEL drivers are upset. They aren't part of cool crowd. I know how it is. I had a 13 SE with no front DRLs and had to get the Drivebrights to look cool like everyone else -
If you really want to find a solution. Go take the cover off your hatch and see if the plug is on the hatch. I'll do the same on my sport. I have already taken it off but i didnt take pics of the plugs
Ford probably isn't going to give uou a firection on this. Here is a simple way to find out. Take off the panel on thr hatch to access the lightbar. See if it's plugged in or if the plug attached to the hatch has nothing plugged into it. I'f I have time I will take mine off but I really wont be home till 10 Feb due to training.
Do it yourself. I've almost had my whole 4n000 mile sport apart -
Couldn't go to my normal fence cause the edge sits to high. Here's my factory 15 HID cutoff. Note4 could capture the blue cutoff on the concrete but it did on a container I found. Factory doesn't have the best steps in the cutoff but it's also not the worst I'be seen either. 1st pic shows steps up close, 2nd from a distance.
2015 edge low beam
Nick Halstead replied to shockerpabla's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
No aftermarket company sells mass produced headlights with LED projectors in them. In fact every spec d/spyder/anzio/insert anyother cheap, ugly projector/led headlight maker doesn't even put HID projectors in their lights. They all come with low quality generic halogen projectors. If your headlights have truly a cutoff like that you need to tell the headlight world what you did cause hundreds have tried NOBODY has done it. Let alone you could sell them for about $1,000. Per headlight -
to clarify also, I tried to find a pic from about the same distance (120-150ft) I was from the fence in the photo. Tonight I went back with my Fusion (Halogen projector) just to get a comparison from the same distance and also close. I'll eventually go back and get a nice 50 foot(ish) shot with my Edge too. Fusion Halogen from same distance From about 50ft has a pretty flat cutoff the width of the car and then drops on both left and right sides. impressed, doesn't look like direct light is above that cutoff, ideally I wish I had a building around me to look at this more indepth but this gives a pretty good idea.
15 should work no problems.
They are labled correctly 99% of oem HID/LED do not come with a defined cutoff. Some oem setups can achieve a nice more defined cutoff with only swapping to a clear lens (swapping the actually projector lens you see when you look at a projector from outside). Though majority of oem projectors can be out performed by $40. Projectors from morimoto. Thats just a cutoff I googled on the bottom. The first 2 pics are my actual car.
Rear hatch lights
There is nothing "saftey" about the middleblight bar. If it was clearly a "safety" item every car on the road would have a light stretching the width of the car -
Cheapest place for oem cargo cover is on ebay
Tail lights
Nick Halstead replied to Westo's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
they will bolt in but you will only be able to light up half of a 2011 tail light. 07-10 use 1 bulb 11-14 2 bulbs. Best option is what candurin posted -
VBOX TESTED: 91 LMS/K&N FILTER AGGRESSIVE + SHIFT TUNE
Nick Halstead replied to GT500R's topic in Transaxle (FWD)
Just keep this thread going, allows people to go to one spot and follow or catch up
