Nick Halstead
Facebook Member-
Everything posted by Nick Halstead
Welcome to the forum. Where in Hi? Im stationed at Wheeler.
Because the door meets the wheel well, and creates the wheel well, there is no solution. If there was a body panel behind and below the door we would have this problem but because the door is the lowest and farthest back body panel its gonna happen. Its annoying yes, but if you clean regularly you should be fine. I have to deal with red clay in that area here in hawaii and Ill admit its a pain in the butt and requires special attention but its not a major issue of mine.
How often do you use your paddle shift?
Nick Halstead replied to Chipster's topic in 2015+ Edge & MKX Generation II
only when I purposely want to make the BOV go off in 2nd gear -
Forscan is the way to go, there's various information on forscan, do a little research. It's asked that you explorer on your own because, people would rather have you accountable for a $40k paper weight in your driveway if you somehow messed things up. Forscan is easy to use though. Just do a little research.
Forscan users test Silent Mode Function?
Nick Halstead replied to jmr061's topic in 2015+ Edge & MKX Generation II
I used dark car mode...until I started driving for Lyft -
New 15up Edge and current f150 are designed way better and are actually 2 pieces
doubt it, if anything a slight exterior refresh
you have pics? the 2012 front emblem isn't a sticker...
Not worth it. Stick to Halogen bulbs in Halogen projectors
- 79 replies
- Headlights
- Crappy
(and 2 more)
ambient light question
Nick Halstead replied to northernone's topic in Interior, A.C., Heat, Interior Trim
more than likely the plug isn't plugged in. I didn't plug it back in once when I had it apart and the wife made sure to let me know... -
Nick Halstead replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Yes, reverted back to stock, Though that's not all you have to do. Just a simple flash still leaves you with every DTC available in the system. So you have to open Forscan and clear them. Though with doing all this, Ford can STILL see how many key cycles ago the PCM was "touched" they can't say if it was a tune to the PCM. I also logged almost 800 miles(lyft driver) after my flash back to stock. -
Replacing 2016 HID
Nick Halstead replied to Ray Heath Jr's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
for the record. H9 is way better than H11, I don't even know what Halogen Bulb# the Edge runs, but My 11 Fusion takes H11 and I just converted to H9 and the results are tremendous (I'll never run PNP HID) -
have you tried rubbing alcohol yet? dab and fold, don't dab same part of paper towel twice. I do this with my uniforms
took here in friday afternoon for the transaxle seal leak. I tried to make them give me this as a rental since it's in the same price range, but they weren't having it ended up with this. -
2015+ common area - a place to say anything (feel free to pin)
Nick Halstead replied to 037's topic in 2015 Edge & MKX
its the main screen that shows the rpm gauge, etc...just keep pressing down -
Replacing 2016 HID
https://www.theretrofitsource.com/components/bulbs/d3s-osram-xenarc-66340-cbi.html
