Nick Halstead
Facebook Member-
Everything posted by Nick Halstead
2015 Edge fob self actvates in pocket
Nick Halstead replied to rurick's topic in Alarms, Keyless Entry, Locks & Remote Start
put keys in center console, shut door, hit last 2 buttons on keypad to lock all doors. -
there's lots of 21s available for the Edge 21s None under $300. but way way cheaper than the dunlop SP sportmax that is $700. PER TIRE
no spin on the premieres? That's overall a very hard tire. Not exactly known to be sticky with it's like 640AAA treadware rating.
LMS or Unleashed Tune? - Which is better?
Nick Halstead replied to commbubba19's topic in 2.7L EcoBoost
My last was in early december I think or maybe it was Jan. I dunno but I'm FWD so all this 0-60 talk is out the window as I've only hit 5.9secs once, but from a roll I am a torque steering beast! -
2016 Edge Sport - Tail Light Lens Tint Options?
Nick Halstead replied to roots57's topic in Accessories & Modifications
yes, that's a risk everyone who tints there tails takes. specially if they go blacked out. Soldier in my unit plastidipped his STI tails (dumb) and a brand new 2016 Mercedes S600 ran into the back of him. sadly, the STI was at fault and paid almost $15,000. for 2 headlights/hood and paint work. This mod can be tastefully done though and still emit a ton of light. One thing going for the edge is the led and the race track lights up really bright -
I solved this problem. I have zero keys attached to the fob and don't have the fob in my pocket when I don't need it there. If your out, why not just lock the fob in the car? -
Taillight Led Turn Signal Hyperflash
Nick Halstead replied to Decastro458's topic in Accessories & Modifications
1st thing, switch the left and right bulb and see if the problem moves. If it moves, it's the bulb. If it doesn't move, then switch the left and right ballast. If that doesn't do anything, put the halogens back in, they had better usable light anyway. -
forscan is the way to go, no need to touch any wiring. or buy diodedymanics leds, no need for resistors with them either -
I was wrong, every wheel has a 52.5 offset EXCEPT the 21 which is a 55
....5x114.3 is what I think you meant to type https://www.wheel-size.com/size/ford/edge/2014/ https://www.wheel-size.com/size/ford/edge/2015/
Considering the OP has a 16, all replies where for 2nd gen.
believe its all Edge's I know there's no offset difference between FWD/AWD 20/21
5x108 +52
intake has zero to do with the transmission
biggest paper weight and money scam besides a jet performance chip. ZERO performance benefits proven on a dyno.
if you can replace all the piping for $400. I'm sold. though from my own knowledge of removing the turbo silencers, replacing all the piping is a fvcking nightmare!
well I'm a bad example of how long does it take cause I've had it off about 50 times it seems. Also, the bolts inside the fender behind the fender liner are a pain in the butt. remove all the bottom screws, then fender liner, then inside fender liner (easier to get to these in the fender liner if remove the headlights) then remove the screws up top under the hood. this way it doesn't slam onto ground.
Nick Halstead replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
it hasn't stretched its legs in a while -
what year? easy fix though, just pop open center console and plug it back in
a $10 H9 halogen bulb slightly modified has better lighting than your LED bulbs. With that said, light bars also fall under the "you get what you pay for" quote here's a reputable light bar https://www.diodedynamics.com/store/led-bulbs-1/led-light-bars-1.html
- 24 replies
I drove my Edge today...lol -
Just to inform you, the light that you hate, you are contributing to. It happens when people run the wrong bulb in the wrong projector and prevent the cutoff shield from doing its job of preventing glare into oncoming traffics eyes. A lightbar isn't going to do much other than attract your eyes to the front of the vehicle while driving.
- 24 replies
you don't have to take the grille apart, you just have to remove the front bumper. The emblem is bolted on. Really can't mess it up. though if you don't have any torx bits or screw drivers its gonna be hard. Rear emblem, just slide some fishing line behind it and it pops off, reapply with double sided tape
