PrinzII
    25
Everything posted by PrinzII
  1. I just bought two small rectangular convex mirrors. They work well, especially for parking.
  2. For some reason, I don't think the install would take 2 hrs like the dealer was going to quote me.
  3. I am looking at putting on a couple of blind spot mirrors on ours.
  4. Gotta agree with that. Case in point, I am going the same route by installing a 6000k HID kit for both low and high beams.
  5. I saw how you mounted it. I am also looking at a second mounting point for the second ballast for the high beams.
  6. Update: I did a test with my 6000k kit last night. The kit I ordered has both the harness with the relays and without. I tested without. From the looks of things, everything worked solidly and the 35w is a drastic improvement versus the halogen. I may just go ahead and install both the low and high beams tonight. Lex: Where did you mount your ballasts? I saw a couple of good spots on the driver's side but the passenger side is another story.
  7. sonyguy: I am already thinking about rims/tires and the choices are rather interesting/staggering. So are the prices. As for my HIDs, I have the 6000k 35w H11 and 9005 so I can have HID High Beams as well.
  8. edgy: Truer words were never spoken. I had a 2002 Maxima that had the following issues: - Hood catching air at 65 mph or higher - Wind noise from rear vent window - Brake pads would constantly torch rotors - Paint would chip even if you looked at it - Recall for accelerator stop ....and many others.
  9. tiaquessa: I have a 35 watt set that works nicely. The wattage doesn't determine the light output. The number of lumens is the measure of light output.
  10. On a similar vein, what's the part number for the USB and Mini plug module for Sync? Hopefully, I don't have to replace the whole console to do it.
  11. Mine doesn't have it, either. I am going to have it done when I redo the tint on the windows.
  12. :shades: :shades: I may take pics of my HID install as well.
  13. http://forums.maxima.org/showthread.php?t=194580
  14. http://forums.maxima.org/showthread.php?t=301625
  15. http://forums.maxima.org/showthread.php?t=256276
  16. Items needed for the initial interior treatment a) Vacuum cleaner: I personally have a shop vac I paid $32 bucks for and it's good for general vacuuming of vehicles. Terrycloth wax applicators: Those are excellent when applying leather cleaner and conditioner as well as protectants. c) Protectant: If you get one, make sure it has a high UV rating to protect the vinyl on the dash. I recommend Lexol's Vinylex or 303 for that purpose. I also may use the Vinylex or 303 to treat the tires as well. d) (For Leather Interiors Only) Get a good leather cleaner and conditioner. Recommendations are Lexol, Zaino, Pinnacle, Einszett and Leatherique. e) Microfiber Towels or newspaper for glass cleaning. You can get Microfibers at Wal-Mart for a reasonable price or order from the links I have listed above. f) Glass Cleaner: I try to stay away from ammoniated glass cleaners because of tinted windows. Ammonia tends to interact with the mylar in a negative way by ruining the coloration and (sometimes) the material itself. Recommendations: Eagle One 20/20, Stoners Invisible Glass, Sprayway. g) Plexus Plastic Polish. Use that for the gauge windows and the radio windows. I also recommend that if you have a wood dash kit.
  17. Items needed for the initial detail a) 2 Buckets: The reason I suggest using 2 buckets is to reduce swirl marks and/or spiderwebbing. You fill one bucket up with car wash shampoo and water and the other with just plain water. After washing an area with the shampoo, take the mitt and put it in the bucket with the clear water so that all of the dirt particles will sink to the bottom of the rinse bucket and your mitt will be clean for the next application of the car wash shampoo. Chenille Wash Mitts (One for the lower body, One for wheels/fenderwells, One for upper body). The reason for this is also to prevent swirls. The lower regions of the car will have more dirt and tar than the upper regions. It takes one dirt particle to get caught and you can easily have scratches/swirls on your car. c) Car Wash Shampoo (I personally use Meguiar's Gold Class) d) Clay Bar e) Carnuba wax (e.g. Meguiar's #26, P21S, S100) f) Polymer Sealant (e.g. Klasse, Blackfire, Zaino) Most polymers have a cleaner to allow for easier bonding of the sealant glaze. Bear in mind, these will last up to 6 months or more dependent on environment.
  18. I wrote this for a Maxima forum I moderate and thought I'd share this with you guys. One of the most frequently asked questions in my detailing experience is whether or not it is proper to detail a new car. I used to share the common thought that detailing a new car was nonsensical. But in all honesty, the answer to that question would be a resounding yes. The main reason for this is that cars are assaulted by different things in transit and storage. You have items such as rail dust (small specks of metal that come off of train wheels and bond to a car's finish), industrial fallout (depends on the area), bird droppings, fruit/tree sap....to name a few. This thread is designed to answer the questions about detailing new cars and outline a procedure that will give you a shiny vehicle for years to come. The first part of the procedure is NEVER allow the dealer to detail your new car. Many times, dealers will swirl the heck out of a finish because they are using too aggressive a pad or polish (sometimes both).
  19. Lex, that's good news. I should be getting my 6000k kit tomorrow and I will post the results as well.
  20. I briefly entertained the Z3 because of the voice command capability. What's the sound quality like? What kind of speakers are you running?
  21. Is there a possibility that my Edge SE could be pre-wired for foglights? The reason I am asking is that I had a different car that I thought would have taken a LOT of work to install fogs have the wiring already in place ('94 Maxima GXE) and I am wondering if Edges are the same way. If so, I am going to have fogs installed.
  22. I just ordered my HIDs and will get back with you when they are installed. I got mine for $240 (H11 and 9005) with digital ballasts and harnesses with relays and without relays.
