Everything posted by PrinzII
Just called the company and the wheel in 20" is a 29 pound wheel which is virtually the same as the stock 18".
If I went to 22s, I am looking at increased unsprung weight (which I know will be drastically higher than the 20s) which affects my fuel economy.
What do you guys think of these rims to go on my 2011? The options I am considering are as follows: a) Buy the Chrome Version Get the above version but have the face painted to match the Edge's Platinum White c) Buy the Black Version Tires: 245/50/20 Pirelli Scorpion Verdes
Turn signal mirrors!
PrinzII replied to Dingo's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Dingo, thanks. I am really looking at that mod pretty hard. -
I took the step of contacting the company directly to check. -
I wonder if they can make these with the integrated convex mirror. -
This is a mod I definitely like. Maybe when I get the larger mirrors for my 2011, I will look into the integrated signal mirror. -
HID bulb for 2013 Edge
PrinzII replied to Calibre's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Yep. Got them from KC300C. -
That is correct on both counts. Some vendors use 9006/9012 interchangably. -
HIDs in 08 Edge Problem
PrinzII replied to Triplej1002's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Let us know if the company responds to you. -
This thread is a listing of the LEDs for the 2nd Gen (2011-2013) Edge. Thanks goes to the following for creating the list. Candurin, Kc300c, Cellbine License Plates: hhttp://www.amazon.co...uct/B0047RV8WG/ Front Map Lights: http://www.amazon.co...uct/B0063JGFRY/ Rear Cargo/Dome/Trunk lights: http://www.amazon.co...uct/B0061SHI7I/ Vanity Mirrors: http://www.v-leds.co...P-p9768538.html Reverse LEDs: http://www.v-leds.co...H-p9507296.html Puddle Lamps (DIY): http://www.amazon.co...uct/B004ZVZNPM/ Front Turn Signal Switchback LEDs: http://www.v-leds.co...R-p7114832.html Note: The link is for the 5K Type 2s. They also have 6K Type 2s now. For the 6K Type 1s, I am sorry to tell you that they are currently sold out. Rear Turn Signal: http://www.v-leds.co...ForLanding/true Note: Resistors may be required Side Mirror LED Puddle Lights (Plug & Play): http://www.daytimebr...ights_NL3C.html Vertical LED Running Lights: http://www.daytimebr...ing_lights.html
One member did a shallow mount and modified the box that the 8" came in.
Try this: http://www.jlaudio.com/8w1v2-4-car-audio-w1v2-subwoofer-drivers-92070
JL Audio has a few, but you'd be better off going with the 10" Stealthbox.
Help with 2012 Edge Sport HID's...
PrinzII replied to KingMike's topic in Accessories & Modifications
I did not change the light housing for my HIDs but did order a 35w 5000K kit from http://www.3bspec.com with Canbus ballast, Warning Canceller, and DRL module due to my Edge having DRLs. -
Change the outside mirrors so that the blind spot mirror doesn't take up a ton of space in it. However, I did see something on an RV that caught my interest where there is a convex mirror and a camera to alleviate blind spots.
Case in point, I got the puddle lamps from kc using 5K LEDs to match my HIDs. Even the license plate bulbs match accurately.
2011 Edge Limited Noisy Microphone
PrinzII replied to Spaceman Spiff's topic in Audio, Backup, Navigation & SYNC
Now, I am not just getting wind noise, but also my conversations are periodically cutting out due to the wind noise. Dealer is aware of it. Going to suggest the Dynamat thing to the dealer. -
My mileage is also starting to climb. I am at 18.1 now versus 17.8 a few weeks ago.
