PrinzII
    26
Everything posted by PrinzII
  1. Tires of choice: http://www.tirerack.com/tires/tires.jsp?tireModel=Scorpion+Verde+All+Season&tireMake=Pirelli
  2. Eatin: The Snetterton was one of the alternate wheel choices for my Edge. Do you have a pic of the Edge with the wheels?
  3. Latest news (Yeah, I know I am taking my time with this): Sounds Good to Me in Tempe had the 10TW3 in stock. I am going to demo it Wednesday. Another change I am making is going with 6.5" components up front and 6.5" coaxials in the rear. Everything else remains the same.
  4. Nice! Can't wait to get mine going. It may be the same as cdpratt's when done.
  5. PrinzII
    Ruby Red
    I wonder if the Ruby Red is a three stage paint like the White Platinum Tri-Coat?
  6. The high beams on these vehicles are activated by a shutter that you can sometimes hear. Did you hear the shutter move?
  7. PrinzII
    Galaxy S4/S5
    How is playing music/media on MFT with the S4? My S3 tends to cut out now and then.
  8. I might try this on my next run to Sedona or Tucson.
  9. That could be the issue. I am running the Type 1s w/o resistors and have no problems.
  10. Considering that we are both second gen Edges, I think the best place would be where the stock Sony Amp would be. You could modify the slits in there to act as vents.
  11. My guess is that the 2014 is going to be the same as the 2013 except with a few minor changes (e.g. color). It's the 2015 that we have to be concerned with drastic changes.
  12. az_edge: Unfortunately, everyone is correct. The grille is actually molded into the side panel. Some shops will take care of that for you (e.g. Unique Audio on Elliot) and it probably won't cost an arm and a leg. If you did get a stealthbox, there are some install instructions for Edges without the SW and the way to get what you need for the opening.
  13. JL has two thin subs. 13TW5 which is a 13" thin sub and the 10TW3 which is a 10" based on the regular W3.
  14. Did you try in the stock sub location?
  15. PrinzII
    Galaxy S4/S5
    The only side effect of upgrading phones is that if I upgrade, the wife MUST be upgraded.
  16. This will be reflective of when I get mine and install them... http://www.youtube.com/watch?v=kWBhP0EQ1lA
  17. Welcome to the forum. I owned a 2008 prior to my 2011 and could tell you what I learned from that. Audio- Installing Infinity's all around. Keep the stock unit as the wife likes the built in 6 disc. But, I need to hide a 10" sub somewhere. The easiest thing to do is get the JL Audio Stealthbox that can be hidden in the sides of the hatch area, a decent amp, and OEM integration since you want to keep the stock head unit. Exterior- Going to be blacking it out. Anyone have some good ideas on nice grilles that can be powder coated? Plasti-Dip is the going trend around these parts. Best person to talk about that would be Cellbine. Rims- Those stock salad spinners have to go. Will have to check out some members pictures for some ideas. Definitely a wise idea. Just make sure it is something you both agree on. Case in point, my wife likes the wheels I want to put on our 2011 which would be these: http://www.mrrwheels.com/gt1.html Brakes- Probably my biggest issue. They suck. So if anyone here has upgraded, please let me know. The only BBK for the Edge that I know of is by Steeda and it's not cheap. Engine/Tranny- This trans feels similar to an old slushbox. The TC seems finicky and while the shifts are smooth, they can also feel slow under load. Different oil perhaps? And is there any sort of tuning for the engine? Will be doing the exhaust shortly, so wouldnt mind tweaking the engine for a little more power. Unless of course bad things happen. Steeda also makes a program to up the HP that can be applied by a SCT Tuner. You may also want to ensure that the trans has the latest updates. Suspension- Not sure here. Wouldnt mind a little more reactive ride. Again, any tips? Many people get H&R Springs to lower the Edge. However, I am more interested in the rear sway bar and Strut Tower brace.
  18. Fave clay bar: Clay Magic Blue Close second: Sonus
