Everything posted by PrinzII
'18 Edge Sport w/ Full SS Tuning body kit, 22s, and bagged
PrinzII replied to ESedge's topic in Ford Edge & MKX Member Builds
Very sick. -
Found a breaker yard (Junkyard) in the UK with one to fit my 2018.
PrinzII replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Found a breaker (Junkyard) in the UK with a grille for $200. -
2011 - 2014 Ford Edge Light Bar
PrinzII replied to dfreeman332's topic in Accessories & Modifications
How about these? https://www.amazon.com/dp/B07TDJ6SBW/ref=cm_sw_r_cp_awdb_imm_t1_9kY4FbSGG5J41 -
Researching getting a Vignale grille for my SEL. -
Installed puddle lamps and high beam LEDs Installed low beam LEDs on wifey's car. -
I like the Vignale grille. I am going to investigate my options.
I have a friend in the UK I might need to call in a favor on......
I am looking for something similar for my 2018. The only difference is that I want the switch on the dash. -
Puddle lamps came in yesterday. Planning to install tomorrow. -
First mod 50% completed - Install LED headlight bulbs. Low Beams are done and highs will be coming soon. Need to replace dust covers on passenger side because they came apart when I was removing them. -
I went through Dan at Daytime Bright Lites. -
2007 - 2011 tail light swap, now have fast signal!?
PrinzII replied to hdmapp's topic in Mods & Tech
You are going to need a resistor to match the ohms of a regular incandescent bulb to alleviate that. -
Ordered new puddle lamps for the 2018. -
You also have to consider the extreme heat where I am is also a factor. The day it croaked, it was 115 degrees out.
I did avoid a 4 cylinder altogether. Mine has a 3.5L V6. It's also Burgundy Velvet. This makes the 2nd car in the burgundy family I have owned. The first was a Caprice.
I am exploring the Gianelle Verdis for the new Edge Considering I already have black SEL wheels, I am going to put the Gloss Black version on this Edge. On my white one, I wanted the black chrome version.
It fits my everyday needs. Not too big. Not too small. Just right. Now, if we can convince Ford not to kill it off............. -
This just sunk in: I literally have owned three different trim levels of Edge and two generations (2008 SE, 2011 Limited, 2018 SEL). -
Xtra, I am sorry that happened to you. -
Traded the 2011 Limited for a 2018 SEL....... -
This:
Update: It's a wrap with my 2011. Turns out there are more issues than previously listed. I am in the process of getting a 2018 SEL that is fully loaded (Price could not be beat).....Stay tuned.
