youri631
About youri631
youri631's Achievements
Rare
Rare
Rare
Recent Badges
wlapaglia, this exact behaviour never happened to me. I would suggest you try the sunroof reinitialization method found on that thread. http://www.fordedgeforum.com/topic/5259-sunroof-initialization/ This often resolves the issue when the sunroof does not close completely, I have not heard of an issue with the sunroof cover opening. but it is worth a try.
Sunroof Initialization
youri631 replied to eifel's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The ford edge 2013 does not have one touch closing. It will always stop short. I beleive this is due to the fact that the glass will not "detect" if there is an obstruction and would risk pinching body parts. ( Which is kind of ironic, since i dont think the motor is really strong enough to cause injuries.) The opening is done in two "one touch" stages. The first stage is not fully opened and it is meant to reduce wind noise (ie for a quieter highway mode). The second stage is fully open. The second stage is also "one touch" since tou don't have to hold the switch for it to open fully. You just have to press it a second time. -
sun roof closing problem
youri631 replied to lpgao's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Devon, if your 2015 edge is only two months old, the lubrication may not be the culprit. This happens when dirt and dust get in the track after a long exposure to the elements. I would get the dealer to get it inspected and identify the problem. The initialization instructions posted were for 2007 models and up to 2014 (i.e. not for the current edge model), and may not apply to your model (same with the sunroof lubrication video). I am pretty sure the sunroof changed, but not sure to what extent. Honestly, if your vehicle is still under warranty as it should. I would not even tinker with it. Bring it to the dealer and let them do the work. I don't understand why you would be without the car for 13 days. The worst I was quoted (for replacing the sunroof motor) was 2 day of work, but in the end they just ended up lubricating the rails, and it worked (kinda wish they had replaced the motor, since it was still under warranty at the time). If the dealer doesn't offer a courtesy car for the duration of the repairs, (especially for a 2 month old car), then I would go to another dealer, I assume there are tons of Ford dealer in L.A.. You have no obligations to get warranty work done at the dealer that sold you the car. I ended up having to lubricate the roof on my 2011 edge every year, but your experience may differ. I live in Canada and ice and snow gets in the track in winter and dust and pollen in the summer. Not a good recipe for the poor grease in the sunroof's track. -
I had the exact same issue with my 2011 Edge. The turn signal when turning right would not hold and would always stop after the 3 flashes. I followed the process above (the hardest part was removing the plastic cover. Hint: leave the bottom bolt attached and remove the top part first. You can access some of the clips with a long screwdrivers or your fingers from the bottom where the locking lever is.) The rest was very easy, as long as watch out to not lose anything since the connectors are not attached and can easily fall after removing the circuit switch. In my case the grease on the turn signal connectors was very dirty (dark black instead of a pale yellow), I removed the old grease with a paper towel and applied new dielectric grease. It works like new. I did not need to use sandpaper. My guess is that for some reasons dust and dirt get in the area where this specific connector is and contaminate the grease. All and all, a no cost fix thanks to this forum.
The hard stop you are describing under common operation is not consistent with the lubrication issue that is common to most. When that happens the roof close very slowly and eventually stops. -
Sounds like you are doing it right. Here is how I understand it, Sadly I can't test it myself right now. Start the engine. Pull and hold the roof opening panel control switch until the sliding glass panel is in the fully CLOSED position (or as closed as it will be). Release the control switch. Pull and hold the roof opening panel control switch until the sunshade panels are in the fully CLOSED position. Release the control switch. Pull and hold the roof opening panel control switch (for at least 21 seconds). - the sliding glass panel will move toward the front hard-stop and stall. - The sunshade panels will move toward their front hard-stops, stall, move back a few millimeters, then forward. After the sunshade panels have finished moving backward and forward, release the roof opening panel control switch. Pull and hold the roof opening panel control switch. (keep holding the switch during the entire time for this step) - The sliding glass panel and sunshades will fully open together. - Then, the sliding glass panel will close first and then the sunshades will return to the fully CLOSED position. When the sunshades have stopped moving, release the roof opening panel control switch. Note that the step I posted is for 2011 model and after. The initial instructions posted on the first page of this post were for pre-2011 model. There might be a difference in the procedure that will work for your 2010 Edge. -
It should not matter in step 1 if the roof is fully closed or not. It would fully close, then you would not need to re-initialized the sunroof. I would go through the whole process not matter what happened at step the first step. Wath out for step 5, it is confusing -
Vista roof problems
youri631 replied to toe6's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Mine has been working fine after being lubricated for the last two year, but i did have to go to the dealer twice for them to lubricate the right parts and fix it. (sadly, I don't know what they did different the second time that worked.) It went from not closing at all and being told I needed a new motor, to working for the last 2 years. I have another post that describes the reset procedure which you could also try ( Sunroof Initialization) And somebody posted somewhere else how to lubricate the roof yourself. Bottom line is: your roof must be able to close within a certain amount of time. If it closes within 8 seconds, then it is fine, longer than that and I would recommend lubricating the rails. (But if your Edge is still under warranty, then there isn't any arm in getting the dealer to replace the motor.....) -
Nice to hear it worked for you I did not have to do it since, I just get the roof lubricated as soon as I notice it slowing down a lot. -
Anderson6799, get your sunroof rails lubricated (or do it yourself) before you change any parts. Mine exhibited the same problem than yours, and at one point would just not close completely. Went to the dealer once, they lubricated the rails and it did not work, when I went in to replace the motor, they instead lubricated some other parts of the rail (guess they were not interested in doing 2 x days of warranty work) and it has been working perfectly fine since then (aprox 2 years now, and I open the sunroof a lot in the summer).
Iona, take the time to read my previous post, most of the time lubricating the rails and resetting the sunroof solves the problem. Dealers are often extremely quick to suggest a part replacement for the sunroof (for example, if the sunroof moves back and forth but stop short, the motor is still working...). If you look for it, someone posted the lubricating/cleaning procedure on this forum, as well as the reset procedure for the sunroof. Cleaning the rails is a preventive maintenance procedure rather than a repair, (similar to lubricating the brakes), and would not likely be covered by warranty.
landon_chris, I had the same issue (ford edge 2011), went to the dealer to get it lubricated, it did not fix the problem the first time, they told me I would have to change the motor (under warranty). Went back but instead of changing the motor, they lubricated other parts and it has been working fine since then. With any car companies, some dealer are good, and some are terrible. My recommendation, change dealer, and insist that they fix the problem without replacing the sunroof motor. Usually the problem is that the friction is too high and the motor just stops thinking it has reached the end. Ford should really have a proper preventive maintenance procedure in place for the sunroof, it would prevent a lot of the issues.
