About mclellan83
787 profile views
mclellan83's Achievements
Rear brakes not releasing completely
mclellan83 replied to JL6173olds's topic in Brakes, Chassis & Suspension
Had a similar problem, dealer said that my pads were too old so they were crumbling due to age. They gave me a $99 parts and labor deal. Was very strange to me to have to change rear pads before front. Since having it done it has only done it twice slightly, but since it is going in for panaromic roof issues I'm asking them to look at it again even though last time they thought I was crazy. -
2013 Edge SEL left rear brake dragging
mclellan83 replied to wally67's topic in Brakes, Chassis & Suspension
I have the same problem, but thought it was both rear at times. Had it to the dealer and they blamed age of my pads making them crumble which I said was from heat. To me is was not right that rear pads needed replaced before the front but wanted to work with the dealer. Now after the replacement it has done it twice, they act like I'm crazy. -
PD all emblems with vinyl flat black and blue overlays on front and rear big Ford emblems, All LED conversion, 50w HIDs, flashback turn signals, and Daytime Running LED Fogs
I didn't have that luck, I tried once but couldn't get the edge up enough when doing it up at my dads to be able to do them all at once when I was trying to take the rims off. I guess I will try again since I don't have to take them off. Yeah, that's what I'm thinking so it matches all the rest of mine.
thanks for the link, had been wanting to mimic the explorer badge but only want to do the edge in flat black to match the rest. I've had my caliper covers forever but haven't got to put them on.
So where did you get the hood badge? Also, do you have caliper covers?
Did You End Up Doing this?
In It's Natural Habitat
Preach It, I Actually Have About The Same Issue. I Trouble ShoT Mine When I Was Using The Auto And The Driver Side Would Turn Off after Start Up, Now The Driver Lo Beam Itself Is Dead Because I Swapped Back Thinking LOw Voltage Killed The BallAst. Heard Someone On The board Say Mine Could Be A Fuse Since Totally Dead But Learned My Lesson With The Auto Headlight.
Headlight issues. One loe beam out rest work
mclellan83 replied to Eddieandkat's topic in 2010 Edge & MKX
I Have A 2013 Ford Edge sport And Have The Same Problem. I Was running Aftermarket Hids For A Few Months But When On Auto When First Starting The Car The DriveR Side Would Fire Then Shut Off. I Had Read About voltage Flux Being An Issue, But Now Checked The Bulb On Both Hid And stocks And Both Are Fine But drivers Side Won't Work On Low Or High But everything Else In The Bezel Works. Looked In The Fuse Box But Can't Find The Fuse For Headlights, Found Both For Hids That Were Empty Since It's Not Factory. Any Help Would Be Appreciated. -
Haven't Tried That Yet, Didn't Want To Go Digging Again Yet But I'm Sure MorImoto Will Say Do The Same
- 326 replies
- LED light bar
- LED strip
(and 4 more)
Sorry About ThE Capitalizing, ITs The Stupid Android Update That They Haven't Fixed. Cycling Off does Not Fix It, I Have The canbus Set Up From Morimoto That They Told Me To Get When I Told TheM What I Had. I Tried To Order The Regular Set Up With A Harness And They Said To Do Canbus Instead. It's Weird To Me That The problem Only came Up After The Drl install, I Figured It Was A PoWer Draw Problem Since People Report Some ProblemS With Just Hids Firing When Set On Auto OR Headlights Are Already On When You Start The Edge. But This Has Gone To A whole New Level.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
Anyone Having Hid Problems? Everything Was Running great For A While But Now Both hids Seem To Not Be Getting Enough Power. I Always Have It On The Auto setting. One Night The Passenger Side WaSnt Fully firing, When I Went To Headlight On It Didn't Change And Going To the Parking Lights It Turned Off The driver But Passenger Was Still On. Turning It To Off shut It Down And Then Going To Auto turned Them Both On Fully. Then I Had No Problems For A Few Days And Figured It Was A Fluke. Yesterday when The Headlights Should Have Been On At First Neither Would fire No Matter What I Did, Luckily I Had my Switchbacks To Look Somewhat Like Headlights. Then Finally After continuing To Change The settings Just The Passenger Would Fire. Later That Night The Driver Would Fire But Not Fully, Then Next Time I Went Out They All Worked Fine. It's Totally Driving me Nuts.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
i Had The Same Issue, My HidS Do The Same. I Don't Believe Its An Issue with The Drls, Its A Factory Problem That we Don't Get Enough power To Fire TheM. I Was trouble shooting My HiDs For The Issue A Few Months Ago, At first I Thought It Was The Auto seTting. But I Would Just Set My HiDs To On Before Starting The Edge And Then Start It And Would Have The Same Problem
- 326 replies
- LED light bar
- LED strip
(and 4 more)
