Darren Jeffrey
Facebook Member
About Darren Jeffrey
Darren Jeffrey's Achievements
  1. I have a F150 2013 and a Windows 8 Phone and I very disappointed in what I thought should be a perfect match. I had previously used a BlueAnt S3 with my Windows 7.5 phone so I know what is possible. Here I what works: Text messages will read thru the Sync interface to tell you that you have a message and allow you to voice interactive with the phone to play, reply call. It will also allow you to speak to the phone to compose a reply. On my BlueAnt I would ay 'Phone Commands' and it would connect to the Siri like Speech interface, but the only way I can find (so far in 24 hours) to get that interface is to press the 'Windows; button the phone. This is an AWESOME feature, just wish I could press the truck speak button to make it work, (to get text messages to read you will need to go to Speech and turn on the options. (to get text messages to read you will need to go to Speech and turn on the options.). It does not seem to play 'alert' or new message tones thru the Sync, but phone ring does work great otherwise, it will load the phonebook with all the pictures you have in your contacts so they display when the call is coming in or calling out. It uses the Sync to make the ring so I don't think that custom tones from the phone are transferred thru and played on the truck speakers. The 'Message' function does not integrate to get the text messages from the Windows Phone... You would think this should work, but not. When you 'Call Home' it is using the Sync interface to select the name and number, so whatever Windows Phone 8 (WP8) would do that is extra is not used. I have not tried playing music thru the phone to Sync yet. I not sure how the Sync calendar function works, but it does not take the calendar enties from the phone, Hope that helps, DJ
