oskar27
About oskar27
2,784 profile views
oskar27's Achievements
  1. Mine is 2016 Titanium with the 2.0 EcoBoost and just turned 60K kilometers. No problems so far, love the car, but I'm waiting to see when it will happen to me too......
  2. My 2016 Titanium 2L Ecoboost has 51k kilometers so far has been a wonderful car. Looking to see what you will do. Sorry for your troubles.
  3. Finally the mystery noise is solved, had a chance to go to the dealer and the noise comes from my shock absorber. Dealer will order the parts and will call me to have the work done. Many thanks to all for the help.
  4. Thanks for the help mate, something new to look for but I will be very surprised if its the shock mounts. As I mentioned I am sure my noise is related to the reclined rear seat cause when the seats are up the noise is almost gone and when the back of the seats is down the noise is there in every pot whole/bump. Didnt have the time yet to check but eventually I will.
  5. The problem persist and best alternative is the dealer but due to weather and bad traffic (have to cross a bridge which now is under repairs and chaos to cross) I always postpone to make an appointment. Trying to remove the big side panel by the loading area is impossible for me, pulling up and away from the wall it feels I will damage it. However I noticed when the rear seats are up the noise almost disappears or not as frequent so I now believe this noise is related to the rear seats recline mechanism. Reading on the web they say the 2 motors under the rear seats are connected to the switch on the drivers side rear panel via a "tunnel". I also noticed there is a steel cable per motor which goes towards that rear panel. If the "tunnel" is metallic then the noise I hear is that, a steel cable banging on the walls of metal. To view the motors mechanism properly under the rear seats I am able to lift the one pc seat but there are cables attached to it and before removing the seat I should first disconnect these cables. Is there any schematic available of all wiring / mechanism involved on the 2 reclining motors? (2016 Edge Titanium) Thanks
  6. Had a quick look tonight to remove the panel but I think it is a big job for me. Will have another look tomorrow and decide if going to the dealer is a better alternative.
  7. Thank again Haz, I do have the Sony and that makes me believe that module in banking inside the cavity. I will check it tonight or tomorrow and report back.
  8. no I have seen no answers and have forgotten this subject but last summer the a/c was working good. Maybe I had set the function of the dual mode in the wrong position? Good luck
  9. Much appreciate your time Haz and many thanks. I did remove the lift gate panel and found nothing wrong. Tomorrow I will take a drive with the wife at the back seat to see if we can pinpoint where the noise comes from. I dont expect any major discovery so my plan is on Monday to call the dealer for an appointment. Soon I have news I will post the results here
  10. Empty the trunk completely including the spare tire and drove around and the rattling noise still there. Looked under the car and see nothing neither expecting to see anything cause the noise comes from the inside of the car and in particular on the driver side and just behind the inside of rear gate. Thats the side where the gas tank is. The rear gate closes tight so its not her making the noise. The rear gate at the bottom is about 3" to 4" thick, is it possible something inside the gate came loose? The license plate is not loose neither any of the rear lights. I just cant figure it out. Next try will be on the weekend and have wife sitting on the back seats and see if she can pin point something other wise I will have to go to the dealer but with X-Mas approaching most likely I will do it in January.
  11. Well the annoying noise it becomes now a PITA. Test driving today it definitely comes from the drivers side and just behind the rear gate. So I stopped, lower the backs of the rear seats and pushed the trunk floor cover towards the rear seats. No the sound again is there. Next step is to empty the trunk including the spare wheel and give it a try. When I get a chance to do this work I will post back
  12. I'm going this Thursday to Ford dealer for 2 recalls in my record (22N12 and 22S43). One of the recalls is for a flexplate possible crack and the other for a bushing on the shifter and although I'm sure nothing is wrong in my car regarding these recalls (hear/feel nothing) I got to get it done. I'm approaching the 50k kilometers with my 2016 Titanium 2.0L ecoboost FWD and I'm more concerned with the dreaded "engine coolant intrusion" than anything else. Since I will be at the dealer, is there anything I can ask the dealer to check regarding the possibility of the coolant intrusion without of course taking the engine apart? Many thanks
  13. Many thanks for the tips, I will check them out. Freezing rain here so test drive will take place perhaps tomorrow
  14. Yes It is the panel in your first picture which feels "loose" in my car. I remember when I used to lift that panel to access the storage spaces under it, after it used to kind of "fit or locked" somewhere / somehow. Now it sit loose and yesterday when driving I noticed the end of it by the rear gate was flopping up/dn and making the rattling sound Last night I play with it and now somehow "feels" its stuck somewhere. Will test drive it today or tomorrow and post back. If noise is still there I will test drive without that panel. Thanks for your time
