omar302
    233
Everything posted by omar302
  1. Some early 2011 & 2012 MFT require full image flashing through the Dealer only, they have early level software releases that couldn't be updated through a flash drive or by the owner. Your vehicle might be one of them. Go to a dealer so they can do the update for you. http://allstatetrucks.com/images/Recalls/R11A01%2011%20Explorer%20and%2011%20and%2012%20Edge%20and%20MKX%20and%2012%20Focus.pdf By the way, the update is now covered by an extended 5 year warranty. So even if your Edge is out of the original 3 year / 36k warranty, the APIM is still covered for 5 years regardless of mileage.
  2. Projectors like these? http://www.ebay.com/itm/HOT-ITEM-2007-2010-Ford-Edge-AngelEyE-Halo-With-LED-Lights-Projector-Headlights-/230984472198?pt=Motors_Car_Truck_Parts_Accessories&hash=item35c7bf5686&vxp=mtr A member is also trying to sell his in the classifieds http://www.fordedgeforum.com/topic/12428-new-never-installed-2007-2010-ford-edge-black-projector-headlights/
  3. I have an HTC One (Android 4.2.2) and messaging now works fully with 3.6.2. I receive messages & can read messages by using voice commands.
  4. For those having problems with recerculating air setting sticking through a restart of the engine, turn off the a/c and then press the recirculate button (effectively turning on the a/c using the recirculate button). If the a/c then remains on until the engine is turned off, the recirculate function will automatically be on when you restart the engine.
  5. Reset the oil life to 50% after an oil change & you would get the oil change warning after 8000 km. It would then serve as a real reminder in case you forget.
  6. I meant to clarify to bce that the setting is off and thats why there is no delay. The feature is still there, only that it is turned off.
  7. As stated, the camera delay feature is off. The cancel button was removed in V3.5.1. One more feature presented in v3.5.1 and is also there in v3.6.2 is the ability to turn off the display.
  8. Recommended pressure is indicated on the VIN information plate at the Driver's door jamb. It should be 35 psi for your tire size.
  9. As far as I know, all MKX/Edge with Push Button start already have remote start from the factory, and since the kit you are referring to is the "Long range" version, most probably it is a long range remote only!
  10. Pull the fuse for the MFT or disconnect the battery for a few minutes.
  11. Go to this website: https://www.etis.ford.com/ Select Vehicle tab & insert your VIN. This should give you detailed specs on the right bottom box (you need to expand the details) & look for "Frequency".
  12. Sajid, I know in Qatar Ford's keyless remotes used to work on 300 MHz frequency, but have noticed that on 2013 models, they started to come with 433 MHz. So double check if your car has the same frequency as the purchased remott
  13. Sajid, I know in Qatar Ford's keyless remotes used to work on 300 MHz frequency, but have noticed that on 2013 models, they started to come with 433 MHz. So double check if your car has the same frequency as the purchased remote.
  14. Hey Sajid, I know a lot of Edge owners in KSA would love to have it activated, I am sure you can charge them a small amount (like sensor cost + 100 SAR) and you will quickly recover the cost of the VCM.
  15. Your rational would have made if the activation charges went to Ford. In reality, the Dealer will charge for the labor only, so nothing goes to Ford. Furthermore, what Sajid is saying is that some SEL Edges where sold to customers with Keys that already have the remote start button (note that the Edge in question is an Export, sold outside US). To be honest, it is an idiot mistake from the selling Dealer who should have known what they are selling!
  16. As per Ford, the range should be up to 300 ft. http://accessories.ford.com/remote-start-system-rpo-plug-in-play-kit.html With my 2011 MKX, with factory remote start, I can start the car from my 3rd floor apartment without problems. I would say the range is acceptable & can reach close to 100 meters (300 ft) as advertised.
  17. How short is the range? The factory system is good for about 100 meters in its best case (no buildings or barriers in between).
  18. Are there any apparent changes or only under the hood improvements & bug fixes?
  19. The APIM has an extended warranty, 5 years for Ford vehicles & 6 years for Lincoln vehicles regardless of mileage. So don't worry, for the time being at least. http://allstatetrucks.com/images/Recalls/R12M02%2011%20thru%2013%20Models%20with%20Sync%20and%20MyFord%20Touch.pdf
  20. Ok, so I updated my 2011 MKX MLT from 2.11 to 3.0.2 to 3.2.2 through the Syncmyride website and then to 3.5.1 using the TSB downloaded file. At the time I started getting the 911 assist error (911 Assist is disabled here living outside USA). After the 3.5.1 update I remember the startup logo/animation used to show the Lincoln logo followed by the THXII Audio animation. Also the logo was Lincoln's new logo. After the dealer fixed the 911 Assist error, the animation now doesn't show complete, the THXII animation does not show at all (only some very rare cases) and the Lincoln logo in the boot animation is the old Lincoln star. Just wanted some feedback what others are getting for their startup animations. Thanks. New Lincoln logo: Old Lincoln logo:
  21. It seems to depend on the type of available light. I noticed that yellow street lights cause graininess. At darker areas without yellow street light the camera image would be clearer.
  22. I get the same feeling, mostly feel air coming from the seat cushion only, but in rare circumstances I might feel it from the back also. I would guess that there is only 1 fan and that there are ducts directing air to the back, hence it feels very week or even not felt at all.
  23. Dear Sajid, I can't help you regarding the Chinese VCM-II, but I would suggest that when you take your car to the Dealer for any service, try to talk to the a technician (not the reception) that all you need is to simply turn on the "remote start" program. Technicians will usually be more understanding.
