Everything posted by omar302
Stick On Keyless Entry Pad
omar302 replied to Mr. Westfield's topic in Interior, A.C., Heat, Interior Trim
Go to this website: https://www.etis.ford.com/ Select Vehicle tab & insert your VIN. This should give you detailed specs on the right bottom box (you need to expand the details) & look for "Frequency". -
Sajid, I know in Qatar Ford's keyless remotes used to work on 300 MHz frequency, but have noticed that on 2013 models, they started to come with 433 MHz. So double check if your car has the same frequency as the purchased remott -
Sajid, I know in Qatar Ford's keyless remotes used to work on 300 MHz frequency, but have noticed that on 2013 models, they started to come with 433 MHz. So double check if your car has the same frequency as the purchased remote. -
Hey Sajid, I know a lot of Edge owners in KSA would love to have it activated, I am sure you can charge them a small amount (like sensor cost + 100 SAR) and you will quickly recover the cost of the VCM.
Your rational would have made if the activation charges went to Ford. In reality, the Dealer will charge for the labor only, so nothing goes to Ford. Furthermore, what Sajid is saying is that some SEL Edges where sold to customers with Keys that already have the remote start button (note that the Edge in question is an Export, sold outside US). To be honest, it is an idiot mistake from the selling Dealer who should have known what they are selling!
As per Ford, the range should be up to 300 ft. http://accessories.ford.com/remote-start-system-rpo-plug-in-play-kit.html With my 2011 MKX, with factory remote start, I can start the car from my 3rd floor apartment without problems. I would say the range is acceptable & can reach close to 100 meters (300 ft) as advertised.
Are there any apparent changes or only under the hood improvements & bug fixes?
Costs of Repairing MFT as Vehicle Ages
omar302 replied to RJG's topic in Audio, Backup, Navigation & SYNC
The APIM has an extended warranty, 5 years for Ford vehicles & 6 years for Lincoln vehicles regardless of mileage. So don't worry, for the time being at least. http://allstatetrucks.com/images/Recalls/R12M02%2011%20thru%2013%20Models%20with%20Sync%20and%20MyFord%20Touch.pdf -
Push Button Start Question
omar302 replied to Chris Wilson's topic in Alarms, Keyless Entry, Locks & Remote Start
http://www.advancedkeys.com/index.htm -
Ok, so I updated my 2011 MKX MLT from 2.11 to 3.0.2 to 3.2.2 through the Syncmyride website and then to 3.5.1 using the TSB downloaded file. At the time I started getting the 911 assist error (911 Assist is disabled here living outside USA). After the 3.5.1 update I remember the startup logo/animation used to show the Lincoln logo followed by the THXII Audio animation. Also the logo was Lincoln's new logo. After the dealer fixed the 911 Assist error, the animation now doesn't show complete, the THXII animation does not show at all (only some very rare cases) and the Lincoln logo in the boot animation is the old Lincoln star. Just wanted some feedback what others are getting for their startup animations. Thanks. New Lincoln logo: Old Lincoln logo:
Back Up Camera very grainy at night
omar302 replied to ELation's topic in Audio, Backup, Navigation & SYNC
It seems to depend on the type of available light. I noticed that yellow street lights cause graininess. At darker areas without yellow street light the camera image would be clearer. -
I get the same feeling, mostly feel air coming from the seat cushion only, but in rare circumstances I might feel it from the back also. I would guess that there is only 1 fan and that there are ducts directing air to the back, hence it feels very week or even not felt at all.
Dear Sajid, I can't help you regarding the Chinese VCM-II, but I would suggest that when you take your car to the Dealer for any service, try to talk to the a technician (not the reception) that all you need is to simply turn on the "remote start" program. Technicians will usually be more understanding.
Why you can't program a new key with only one working key? My best guess is for security. Having both keys available at time of programming is the only way to ensure that the person performing the programming is authorized to do so. Else, whenever you give your car & single key to anybody (valet parking, car wash...etc.) you would be at risk that someone might program a new key without your knowledge.
My HTC One when paired with MLT, Version 3.5.1 will only read out the messages if they were received while connected. If I use the voice commands to read texts, it will prompt that Text messaging it not supported. A nice thing I also found with the HTC One compared to my previous phone, "HTC One X", when messages come & are viewed or read, they will be marked as read in the phone. My old phone kept them as unread.
I hate asking questions but
omar302 replied to Nick Halstead's topic in Brakes, Chassis & Suspension
Sometimes they list the Edge Sport in a different spec sheet, and in that case, the spec sheet for the Edge (non sport) would only show difference for AWD/FWD. For brake pads and calipers, Ford did this before in the 96-99 Taurus & Taurus SHO. Both had the same brake pads & calipers, but the Taurus SHO had larger Discs & with longer/larger "caliper brackets" that allowed the same calipers to be mounted farther from the hub to make space for the larger Discs. -
As per Ford's specifications for the Edge & MKX on media.ford website, the FWD "regular" Edge has smaller front brake swept area (63.1 sq. in), whereas the Edge AWD, Edge Sport (FWD & AWD) and MKX (FWD & AWD) all have 69.79 sq. in. of brake swept area. Different swept area would mean different sized rotors. Rear, they all have the same swept area, 70.12 sq. in. For Calipers & Pads, there does not seem to be any difference as on Fordparts.com there is no differentiation between different models for Calipers & Pads except vehicle made before 9/20/2010. -
In my MKX, the button lights up normally when headlights are on, but when pressing it, the light does not change. I believe that's how it is designed, just like the fan/seek/scan buttons, a single color LED. All what MyTemp does is quickly set your temp to your preset one, its not like an indicator that tells you have a function turned on (like A/C, Max, recirculate...etc).
What version of MFT is your car running? Make sure you have the latest, v3.5.1. If it is already v3.5.1, did you try a master reset?
- 19 replies
- Bluetooth
- Samsung Galaxy S3
Got the attachment from one of the posts here in the forums, don't remember who posted it. tsb13-03-18 Ford Edge 2011-12 PCM Reprogram.pdf
Just a note, in case you didn't know. You can "Pause" your trip meter by pressing the "Ok" button (instead of holding for reset). This can help you in saving your trip information for later reference.
For the 1st generation Sync (other than 2011+ MyFord Touch), there is an application "SYNC My Phone" that can be downloaded from the SyncMyRide.com website under "SYNC Utilities". The app is for manually creating and downloading phonebook contacts to SYNC-equipped vehicles via a USB drive.
The 2014 already showed up on Ford's Media website! http://www.fordedgeforum.com/topic/12419-will-there-be-a-2014-model/?do=findComment&comment=97726 Its the same as the 2013 model with 2 new colors!
