omar302
    183
Everything posted by omar302
  1. Its an SEL. You can see the "L" in the first picture. Also, SE models in US have 17" wheels.
  2. If it's an early build 2011, you have to go to the dealer for the updates. In any case, the warranty for the APIM (MFT) has been extended by 2 years on all Ford/Lincoln vehicles regardless of mileage, so yours would be covered.
  3. Since your talking about Air Filters, I have noticed that the replacement filters (FA-1884) is different than the one that came in the car from factory. Same part number, but the factory one was orange/yellow with a steel mesh, the replacement is black/white. Wonder what is the difference & which is better (if any is).
  4. The link you have is the latest (3.6.2), for some reason the number on the file's name has v361 which makes you believe its 3.6.1, but it is actually 3.6.2. So it should work. On the other hand, since your still on 3.0.2, I would recommend first installing 3.5.1 because it was a complete flash. The update file was huge (~1.2 GB) unlike other updates that were only ~550 MB. Then update to 3.6.2. I have attached both TSBs for v3.5.1 & v3.6.2. Note: For my brother's 2012 Explorer, it has 3.0.2 which was not confirmed at Syncmyride, hence Syncmyride was indicating the current version as 2.11 & it still made us update directly to 3.6.2 which worked fine without problems. Note 2: If you have navigation, you probably will need an updated SD Card for it to work. TSB 12-11-01 (MFT v3.5.1).pdf TSB13-08-02 (MFT v3.6.2).pdf
  5. Will not work straightforward. They might work with a special adapter (if any exists).
  6. The center hub diameter is different, 63.4mm for 2011+ and 70.5mm for 2010 and below. So the 2009 wheels will have a bigger center hub hole.
  7. Remote start can be activated at any dealer, you just need the IDS (or whatever they call it). One member even bought it & activated remote start himself (Sajid.ali). Navigation, on the other hand, is kind of a one time setup at the factory, once it is set up for "Nav or no-Nav", it cannot be changed.
  8. This is exactly how they work on my car, 2011 MKX with factory HID, no matter how long or short you hold the lever, but that's only during the day (headlights off). If the headlights are on, the highbeams will turn on for as long as you hold (pull) lever, there is no minimum or maximum time.
  9. You can take out the emergency key (that's inside the fob) and keep it with you for emergencies, or you can copy it to a regular key to put it on a key ring along with your other keys.
  10. If you want bright, choose 4300k colour as it gives the most light. Stock HID is also 4300k.
  11. Not the standard Limited. You have to have Equipment Group 301A or 302A to get the Driver Entry Package which includes the "Push button start" & remote start.
  12. Try installing 9011 in place of 9012, there is a slight difference in the base similar to 9006 Vs. 9005. 9011 are 65 watt bulbs with about 2350 lumens.
  13. Disconnect the battery for a few minutes to force a reboot (or pull fuse#29 or ) to see if the system starts.
  14. Make sure you are checking the tire pressure when the car has been sitting for a few hours or early morning.
  15. Check this for glass replacement procedure http://www.fordedgeforum.com/topic/4892-how-to-replace-side-mirror/?do=findComment&comment=95087
  16. From the instrument cluster left screen, go to Settings>Vehicle>Easy Entry/Exit and select off.
  17. I believe its behind the glove box, top side. If you remove the cabin air filter, you'll see the fan immediately under it. Spray their if you like. Also, when was the last time you changed the filter? the odor might be from something stuck on it.
  18. Try disabling the phonebook auto download. I have a HTC One & have no problems with 3.6.2 & voice commands except some quirkiness every now & then.
  19. Though mine is an MKX, it definitely doesn't require such force to close. I suggest you insist on the dealer to adjust it. Tell them to check any other Edge in their lot in front of you.
  20. Running should be the Parking lights. The front signal bulbs have two filaments, the low (weaker) filmanet is used for Parking lights while the high (stronger) filament is for the signal.
  21. The only way to get the 3.7 Engine and all the options is to get the MKX. For is doing the same thing with the Explorer were some options, including HID headlights, are not available on the Sport.
  22. Go for Ford's accessories: http://accessories.ford.com/vehicles/edge/2013/electronics/remote-start.html?order=nameasc They have several choices that can be installed after buying the car.
  23. I would highly recommend thinking of going to a 2011, the differences are a lot.
