Everything posted by omar302
Does the Gen2 Edge have an A/C water Drain location? I don't see water dripping even though it is quite humid nowadays. Also couldn't find a drain pipe looking under the vehicle. I want to check for blockage as I am getting a slight mildew smell sometimes when the A/C starts blowing, however all the carpet inside is dry. My other car, the MKS, drips large puddles of water, as does most vehicles I see on the road.
Did you drive the vehicle? if not, drive it for 10 minutes or so to see if it fixes it. Also try disconnecting the battery for a few minutes.
Did the vehicle read the sensors automatically and show correct tire pressures or was there a procedure performed?
Small missing trim piece (liftgate area)
omar302 replied to Correy's topic in Interior, A.C., Heat, Interior Trim
Should be this part. -
07 Edge AC - Not Blowing Hard (AT ALL)
omar302 replied to cornelljl's topic in Interior, A.C., Heat, Interior Trim
Did you check the cabin air filter/screen? -
Project - Get Active Cruise Control functioning
omar302 replied to andyh1108's topic in Accessories & Modifications
This is for my 2016 Edge Sport: From Motorcraft ABD site: From ForScan (also abt file attached): 2FMPK4AP9GBB98478_PCM_20220310_144949.abt -
This is for my 2016 Edge Sport: From Motorcraft ABD site: From ForScan: -
I understand this and have not read anything to the contrary, however, in my testing it seems the Edge will "Auto learn" the tire positions. I previously made a short video showing it. Link to post.
2016 Edge Lift Gate Not Locking
omar302 replied to Maria's topic in Alarms, Keyless Entry, Locks & Remote Start
The liftgate will always open with the fob. To test if it is locked, lock the doors and keep the fob away from the vehicle, few meters away, the try to open the liftgate with button above the license plate, it should not open if it is locked. -
2015 edge FWD 2 liter front rotor size?
omar302 replied to Lincoln81's topic in Brakes, Chassis & Suspension
I don't think it is easy to determine which size you have by description only. If you want to confirm which size online, your best bet, in my opinion, is to check with a seller who will confirm if the rotors you intend to purchase are a correct fit by VIN. -
Add Nav to 22 Edge Titanium?
omar302 replied to Inspidship's topic in Audio, Backup, Navigation & SYNC
22 Edge has Sync 4A, I don't believe adding NAV is similar to Sync 3, at lease have not seen it done yet. However, Sync 4A should have Android Auto and Apple Car Play, they should be even better than the factory NAV. -
Ambient lighting won't stay on
omar302 replied to Davidoo's topic in Audio, Backup, Navigation & SYNC
I remember when people complained when it DID reset. Mine was like that until a Firmware update to the FCIM made the heated and cooled seats remember the last position. Seems it is a feature not liked by all. They should make it user selectable. -
Probably a software bug. Something similar happened several years ago when ambient lights would revert to the default color every few days, the fix was a software update to the then MyFord Touch (Sync 2) center screen. It is better to report it so that Ford becomes aware of it. -
Short answer, no. On GEN 2 Edge models, headlights are 2 bulbs on each side, HID models use the inner bulb (closer to the grille) for a dedicated DRL function. It uses an H15 bulb (a dual filament bulb) but only the 15 watt DRL is connected. Halogen equipped models use separate low/high beam bulbs and the DRL is the low beam. The only ForScan mods I have related to DRLs on my Edge are to enable the menu option in the cluster to turn DRL on or off, like the stock US setup for GEN2 Edges. My Edge being a GCC export market model was setup to have forced DRL always on when the conditions are right (headlights off, transmission not in Park).
Ford Edge Vertical LED DAYTIME Running Lights - IN STOCK
omar302 replied to kc300c's topic in Classifieds
Hi @kc300c, Any plans to offer an LED DRL Kit for the 2015-2018 Edges? Similar to the kits offered for the 2011-2014 models? Thanks.- 31 replies
- bumper strip
- bumper led
- (and 8 more)
Thanks again @Haz The non-working interior switches might be due to the "Inhibit Switches" function I had enabled using ForScan that is supposed to disable the interior switched when locked. I have now disabled it to see/test if the issue happens again. Yes. There was no cluster messages. Completely blank. I just made a test (normal condition) to enter my vehicle using the keypad only (keyfob away from vehicle) and it would show the mileage in the cluster once the driver door is open. Pressing the ignition start button (keyfob still away) will get a "No Key Detected" message in the cluster. When the issue was happening, the start button was not flashing. Next time the issue happens, I'll try to connect the OBDLink MX OBD adapter and see if can get any readings. Also I'll try tapping on the relays/fuse boxes to see if it makes a difference before disconnecting the battery. Visually, the relays look ok. Also, between the first time the issue happened, till the last times, the battery has been replaced, so that is out of the equation.
Thank you @Haz. I feel that the code(s) I got are symptoms only, probably due to the battery disconnection. I went through the attached documents, but I couldn't find a link on what might cause the ignition power to be dead, completely, with no response in the IPC (no warnings or anything), the remote keyfob not responding to any commands, not even if inserted into the backup slot. Yet, the keypad on the outside still worked and opened the door. The horn also worked. The slight disconnection of the battery for a few seconds was sufficient to bring every back to life again. Makes me feel like a stuck relay, but did not find any relay that controls the dead functions only while keeping the others running.
Issue happened a third time yesterday. No response from the keyfob or the engine start button. The keypad still worked and unlocked the door, but nothing in the instrument cluster. Disconnected the battery for a few seconds and then reconnected it, vehicle started completely fine. Again got a single code and was from the BCM related to the steering lock (B1026:87-08) - ForScan stating as "Missing Message". I know that without any codes or a way to repeat it, my dealer will not be able to help. I tried the self tests for KOEO, KOER and BCM, no faults.
Fluttering Noise from Undercarriage and Dashboad Rattle
omar302 replied to CCMAYES72's topic in Brakes, Chassis & Suspension
I found the attached updated TSB 21-2322 issued 23-September-2021 (superseding 17-0065) stating to just remove & discard the fasteners. Calling them "assembly aid fasteners". MC-10201635-0001 - TSB 21-2322.pdf- 90 replies
- 2
- dash noise
- dash rattle
(and 4 more)
What is the difference between SYNC®* 4 and SYNC® 4A? I think that the major difference is the screen orientation. 4A is portrait with the volume dial and 4 is landscape.
Check this F150 sheet (fake engine sound). https://docs.google.com/spreadsheets/u/0/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/htmlview#gid=815852466 You will need to enable/disable it under ACM and DSP, as far as I remember.
