omar302
    183
Everything posted by omar302
  1. Disconnect your car's battery to reset the electronics? And/or try to reset the settings to default/factory settings.
  2. HCFX2011, It is strange. Especially that the mirror only has an indicator led! The actual BLIS sensor is in the rear (side of bumper I think). Just a few thaughts that might be worth trying. Did the 2011 MKX work with 2013 mirror without errors? If you simply disconnected your mirror's wiring, do you still get the warning? Are all other systems in the mirror working (power, memory, autodim)? I'd probably think it a change in the wire placement that caused your error message, what I mean is although the socket plugged in fine, the individual wires are connected in a different order & causing the error message.
  3. If you have the latest update, V3.6.2 (not sure if it was also in V3.5.1), go Settings >Display and select "Off" for mode. The display will turn off. To turn it back on, just touch the display.
  4. 12EdgeSport, When you have to do a sequence other than the factory one, do you see the lights on the vehicle working on every press? Is yes, then the remote is working and it's not a battery issue. May I suggest that you disconnect the car's battery for ~30 minutes? Sometimes forcing a reset to electronics fixes them. Edit: Just for information, the remote stat works consistently as per the factory sequence (press 1xLock then 2xStart), so it is designed & should work correctly.
  5. Is the same issue happening with both fobs? Could that one of them has a weak battery. Another thaught, are you sure the vehicles registers the "lock" command? I would suspect that it isn't abd hence the sequence would fail. Try for some time pressing the lock button twice (and hearing the horn chirp to confirm) then press the remote start button twice.
  6. I think the change was made in 2012 with the smaller side view mirrors for all Edges & MKXs. Wish someone could tell us the reasons for these changes and if there were improvements in wind noise.
  7. Linking an IA key is very simple following the instructions in the owners manual. done it several times without any incident. An important note though, you cannot un-link an IA key yourself, it has to be done by a dealer or locksmith with the correct equipment. The maximum number of IA keys that can be linked is 4 only. I made several tests previously & you can remove the battery, the IA key will still work, but only through the backup slot in the center console. Actually it would even be safer to remove the battery because otherwise, pressing the unlock button would disable the Alarm. Check these 2 posts I made earlier: http://www.fordedgeforum.com/topic/14049-spare-key/?do=findComment&comment=108786 http://www.fordedgeforum.com/topic/14049-spare-key/?do=findComment&comment=108877
  8. Try e-bay. Since you have an SE, you have the basic mirror. Also, you need a 2012-2014 mirror only. Older models have larger mirrors, they fit, but will look different.
  9. Do you have the MyFord Touch (8" touch screen)? if so, the APIM, the module responsible for system including the touch screen, has a 5 year unlimited mileage extended warranty (5 years from vehicle purchase).
  10. Your within the range, I wouldn't change a thing. The vehicle was designed with a class 2 hitch, so going above that allowed weight might put extra stress on other parts of the chassis, as long as you don't exceed the maximum allowed weight (trailer & tong) then don't sweat it. Remember that when designers state maximum or minimum numbers, there is always a factor of safety included.
  11. There is a new model available in EBay: http://m.ebay.com/itm/161240710241
  12. In an ideal case, 100% oil life should be good for 10k miles or 1 year. So as a rough estimate, 19% can get you (ideally) 1900 miles or a little more than 2 months.
  13. Is there a lockable version? I have an MKX, and it does NOT have a locking glovebox! It would be nice to have one. The glove box light in the MKX is not connected to the ambient lighting.
  14. The glove box is not lockable, also the light & switch are separate from the lock mechanism. FYI.
  15. Check the 3rd post in this thread for a TSB that might apply: http://www.fordedgeforum.com/topic/14165-2013-edge-sport-pulling-to-the-right/
  16. I think they are used for the AM/FM1/FM2 station presets.
  17. Here is the TSB for the Pull/Drift to right for the 2011 model. TSB 10-24-8_Drift Pull Right.pdf
  18. That would be something, there should probably be a reason. Can you name an example?
  19. If you see the size difference of the pads between front & back, you'll know why the rears wear fast. The rear pads are always smaller.
  20. If you have the 2.0 ecoboost engine, the maximum weight that can towed is 1,500 lbs. If you have a V6 (3.5l), it depends, if you have the factory towing package, then its 3,500 lbs. Otherwise it's 2,000 lbs. To know if you have the factory towing package, you should have the factory installed hitch receiver and there will be a setting in the left instrument panel screen for disabling trailer sway control.
  21. Just to debunk this theory, the hood insulation on the Edge/MKX is held by several plastic retainers but there are also 2 steel clips at the bottom. The hood insulation can't drop completely on the Engine if the plastic retainers are removed because of the steel clips.
