Everything posted by omar302
2015 Ford Edge Introduced - Edge Going Global
omar302 replied to LI Edge's topic in Articles, News & Reviews
Since the 2015 Edge has a new rear suspension setup, my guess is that these humps are to accommodate it (the shock absorbers and/or coil springs). -
You can enable a "Delay" feature in Vehicle>Camera settings of the main (center) screen. This will enable keeping the revers camera on when moving from Reverse to Drive and the Camera will remain on until you reach a certain speed (~5-8 mph, don't remember exactly). But to keep the Camera on in Drive at any other speed cannot be done unless you install an aftermarket kit such as this http://www.coastaletech.com/mytouch2.htm.
Wiring for Paddle Shifters - Sport & non-Sport
omar302 replied to omar302's topic in 2011 Edge & MKX
Thanks WWWPerfA_ZN0W, unfortunately the infotrac does not work for me, it seems there is an IP issue from my country. But from the video it seems simple, the wiring & clock spring look very similar to the 2011. Will try to see it when I have some time. -
We only have 1 dealer in Qatar. So trying a different dealer is not possible. Several things to consider: 1- I know the clockspring has the additional pins, it is the same part for vehicles equipped with & without paddles, but I am not sure wires are present after the clockspring. 2- I don't believe programming would be different, since the paddles don't really add a new function, they do the same job as the +/- switch on the shift knob. The only added feature is the ability to temporarily shift while in 'D' compared to shifting only in 'M' or 'S' for the +/- switch. Considering the above, I would be more inclined to think it's a wiring thing. So to be sure, is it easy to remove the clock spring to check? Would appreciate a simple how to. Thanks. -
Did you try a Master Reset of the center screen?
Update Got my car yesterday from the dealer & they said they couldn't find any configuration that would enable the paddle shifters! -
If you want a known brand name (Philips/Sylvania): For the puddle lamps (Make sure to get the 6000K for white): http://www.ebay.com/itm/221417084888 Front Map lights: http://www.ebay.com/itm/151375536984 Rear Dome & Map lights: http://www.ebay.com/itm/380806431058 Reverse Lights: http://www.ebay.com/itm/161261361410
This is what it incudes: Taken from here: http://www.ford.com/resources/ford/general/pdf/towingguides/13flrv&tt_edge_oct1.pdf
The MFT 's APIM is covered for 5 years regardless of mileage. First, I would make sure your on the latest update, version 3.6.2, second, when was the last time you did a Master Reset?
Will do. Still did not have time to take it to the dealer. Hopefully in a week or so. -
2011+ Edge has stem mounted sensors, and yes, they are rubber stems.
- 1 reply
2013 Edge steering wheel
omar302 replied to toast1850's topic in Interior, A.C., Heat, Interior Trim
It is a simple job. 30 minutes max, 20 of which just waiting for the power to discharge First you need to disconnect the battery. Wait 10-20 minutes to ensure that the Airbag system is fully discharged. There are 2 small holes, one on each side of the steering wheel, you will need a long rod, like a Alen key and insert it in one hole so you would push a spring inside that would release one side of the Airbag. Then do the other side & the Airbag would come out. Note: Once you have the other steering wheel, you can see how you would push the rod/Alen key inside the holes. Once the airbag is loose, you need to disconnect the 2 wires from it and remove it completely. Take extra caution handling it. Disconnect the wire inside from the clock spring. There is a single bolt holding the steering wheel, I used a T50 torx wrench. Unscrew it & the steering wheel is free to remove. Reverse to install. Again, take extra caution handling the airbag & ensure that your battery is disconnected. This also helps avoiding Airbag Warning lights. Removing the Airbag is similar to below video of the F-150, except the Edge has 2 holes only, not 3. This is the Torx wrench I mean, used T50: http://www.powertoolsdirect.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/f/a/faithfull-star-torx-key-set-of-12-t7-t50.jpg -
It is probably for the front 180 degree camera. -
It is official! The 2.7 Ecobooost in the F-150 is rated for 325hp & 375 lbs-ft. Given the expected tranny limitation on the FWD based edge, akirby seems to be spot on with around 330hp (or 325 like the F150) & 350 lbs-ft. From the same article, the 3.5-liter V6 (non-ecoboost) produces 283 horsepower and 255 lb.-ft. of torque http://commetsmigtest.sandbox.autoblog.com/2014/07/22/2015-ford-f-150-specs-revealed-ecoboost/ -
Further to my earlier post, it seems from the technical specs of the 2015 Edge, that all 3 engines can be FWD or AWD. https://media.ford.com/content/fordmedia/fna/us/en/asset.download.document.pdf.html/content/dam/fordmedia/North%20America/US/2015_Specs/2015_Edge_Specs.pdf -
From the main article, in the OP: Edge equipped with the 2.0-liter EcoBoost can be specified with newly available all-wheel drive and a towing package capable of hauling a 3,500-pound trailer. & The available all-wheel-drive system for the new Edge is full-time, on-demand and seamless there are no knobs or switches to activate. An electronically controlled clutch, which can engage faster than a human can blink, transfers power between the front and rear axles, sending up to 100 percent of the power front or back. I didn't find anything on the 2.7 and AWD, but if they follow the same pattern as current the 3.5 Ecoboost, it would be an AWD only drivetrain for platforms with transverse mounted engines (FWD platforms such as the Edge's). Too much torque on a FWD vehicle is calling for trouble. -
Cracked Driver's side window
omar302 replied to NatG's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The side windows on Limited & MKX (not sure of other Edge trims) have laminated windows on the front side doors for the sound isolation. I think the brand is SoundScreen and should be printed on it. As for heat causing pressure build up, cars already have pressure relief flaps. -
Factor99 is correct. Using metric fuel economy, it states how many litres used per 100 km driven, so when your not moving, guess how many litres it takes for you to drive 100 km? Infinite. So the gauge just defaults to 30 l/100km. Also, if you think something became weird after the k&n filter install, how was it beforehand?
I believe a 2011 Limited should have the laminated side windows for the driver & passenger. As for heat, we have A LOT more heat & never face cracked windows. -
Ford is slowly improving newer models. For example, in my 2011 MKX, when selecting M mode, the gauge display will change to the round ROM display and remainthere even after returning to D mode. On a friend's 2013 Explorer, the display will return to the last display after returning to D mode. I noticed this change because I always get annoyed that I have to change back my display after a brief M mode I use at my Work's parking building.
On a little related news, the 2.3 Ecoboost for the Mustang has been rated at 310 hp & 320 lbs-ft if torque. http://www.roadandtrack.com/go/news/ford-announces-official-2015-mustang-horsepower-ratings-ecoboost-v6-gt?src=spr_TWITTER&spr_id=1459_72569254 -
They change, 2, 3, 4 or 5 depending on which menu your in. In the settings screen you'll see them the most.
From http://www.fordinsidenews.com/
