Everything posted by omar302
Seat Filter for Cooled Seats - Design Changed!
omar302 replied to omar302's topic in Interior, A.C., Heat, Interior Trim
Correct. They are not filters anymore. -
Excessive smoke on cold start - 2017 Ford Edge Sport 2.7l
omar302 replied to JohnR0983's topic in 2.7L EcoBoost
@JohnR0983 FYI, The drain/fill procedure explains why. See attachment. Engine Oil Draining and Filling 27l.pdf -
Just in case, are you aware that for these engines you have to wait ~15 minutes for the oil to fully drain into the pan before checking the oil level? -
Dealers will always be expensive. The part number is ft4z5820879dc and itself is much cheaper. See here for example an OEM part. But the part will require painting to match your color. Also, searching the part number on eBay you will find even cheaper and cheaper still used. If your lucky, you might find one with same color saving you from having to paint it.
Thanks. Looked up the part number on Ford's online parts lookup and found it applicable for my Edge's VIN. Even the parts diagram confirms it.
I recently got a previously set DTC P06DD:00-28 for Engine Oil Pressure Control Circuit Performance/Stuck off. No symptoms, check engine light or warning messages. Reading online I feal I might need to replace the "Oil Pressure Control Solenoid" soon, pictured in your post, but I can't seem to find a part number. All I can find is the Variable Valve Timing Oil pressure control solenoid. @Haz your usual assistant is highly appreciated.
Rear Cross Traffic Alert Arrows On SYNC Display
omar302 replied to Wubster100's topic in Accessories & Modifications
I was always perplexed why this was not the case from the factory from the day cross traffic alert was added. Always when reversing and looking at the reverse camera display and hearing the the beeping I have to check the instrument cluster. Please do share how can we get it, if possible. -
I remember some Ford owners who retrofitted adaptive cruise control to their cars found the wiring already there. If that's your case it might be a simple plug and play. The plastic cover should come off easily, if it is still similar to the older models. See attached procedure. Head Up Display (HUD) Module.pdf
I see @Wubster100 already answered. At the time I recall enabling it the manual ABD way using information from the 2gfusions forums, however, the site stopped working for me from a long time, probably due to my location outside the US. This thread/post might have the info, but I can't confirm since it doesn't open for me.
AWD graphic doesn’t show up anymore.
omar302 replied to Steve Hauck's topic in All Wheel Drive (AWD)
Are you looking for it in the left screen of the instrument cluster? That is where it is supposed to be. Not in the Sync menu. Also I am not aware it has any configuration. It is just a display. You might be mixing it with another menu. -
I had it enabled on my 2016 Edge Sport using ForScan. Since the 2016 also has the red led bar for collision warning, part of the same bar would turn on when following too closely (red). So I would expect it to be possible to be enabled on the ST.
2022 Ford Edge Titanium - Auto Start System Not Working
omar302 replied to OhhBnertt's topic in 2.0L EcoBoost
As far as I know, if the vehicle has Auto Start-Stop, then it has to have an AGM battery. So much so that on some regular batteries there is an exclamation that warranty would be void if installed in a vehicle with auto Start-Stop. -
2024 Edge rattle noise from rear cargo trim panel
omar302 replied to lasseventies's topic in 2.0L EcoBoost
On earlier Gen 2 models there was a TSB for a rattling sound coming from underneath the vehicle. Maybe worth checking out.- 18 replies
Yes. I believe the larger diameter and wider tires are the main reason. Even if the suspension is bottoming out the tires should not rub. Sorry can't help with recommendations. But OEM (Motorcraft) is always a good option.
Engine wants to stall - Code P1450 & P144A/C - Evap Purge Valve
omar302 replied to shumax's topic in 2017-2018 Edge & MKX
Strange you're having to replace it 3 times now. Glad your able to fix it easily though. -
It was. The 8-speed on the 2.7 was an updated design from the previous 6-speed by adding a shift between the original 1st and 2nd (making a new 2nd) and adding another shift at the top (after the original 6th and becoming the 8th). So with the reprogramming of the 8-speed they cancelled the "new 2nd".
What color is it? If the door's ambient light is different and is red than it is normal. It is supposed to inform you that this door is open. Edit: just noticed this the 2011 sub forum. My comment applies to 2015+.
@Haz Can you please help with the manual procedures for changing the oil pan for the 2016 Edge Sport and 2016 MKX (2.7 EcoBoost)? I ordered a set of parts to fix the oil pan leak on my Edge which started to develop a small leak, but as the parts arrived we got a friend with an MKX that has a much more serious leak. So we'll fix his first then mine.
As stated and linked to by @1004ron above. There was a recall to replace a small plastic bushing that could fail and then the shift lever would disconnect from the transmission. The connecter circled below in your photo clearly shows that it was NOT done, or not done fully/properly.
If I'm not mistaken in my Edge the leak was from the Plastic piece circled below. It was like the outer piece enlarged and would not seal properly. Unfortunately it is part of the full heater hose. This part. Though you have to make sure this is the correct part number for your Edge. Mine is a GCC model with extra cooling so the hose is different. The part I linked above should be the for the standard North America model.
I wouldn't expect the tires would rub even with no shocks installed. Are running stock size wheels & tires?
One more point to consider, using this module means you will still use the original sync2 screen that is resistive. Meaning requires pressure to recognize touch commands, is slow and does not support multi touch (no pinch to zoom). Having a similar solution on a Toyota, the Android auto experience was underwhelming and I'd happily pay an an extra $200 to get a correct upgrade.
SD card won't seat or eject
omar302 replied to Keith Bray's topic in Audio, Backup, Navigation & SYNC
eBay? https://www.ebay.com/itm/167185480475 -
Windshield Replacement
omar302 replied to 1004ron's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The service manual states if the gel is damaged to replace the sensor. I don't have experience, but I would probably be more inclined to replace the sensor and consider the extra $27-$37 as an upcharge as I wouldn't be sure I'll be able to install the gel correctly or the old gel removed fully from the sensor. -
Passenger Front Seat Belt - locks up
omar302 replied to mitchjs's topic in Interior, A.C., Heat, Interior Trim
When you lean out, does the belt extends all the way out? If yes, then it is by design and there is no solution for it. This is for locking the belt when installing a child car seat. Also, when the seatbelt is retractable you would hear a clicking sound. Otherwise it would probably be a failure in the retractor.
