omar302
    233
About omar302
omar302's Achievements
  1. I recently faced a major knocking issue in the 2.7 after a Spark Plug change (SP594). I thought I got a good deal on them on eBay only to find out they were counterfeit and are most definitely no iridium. The knocking was so bad that the pcm through a code for the crankshaft position sensor, P0339. Bought a new spark plug set from the dealer, which looked iridium, and the issue was fixed. I didn't know about the counterfeits being sold, but after facing the issue immediately after a spark plug change and then searching online I stumbled upon several posts of the issue. This is one from Ford Tech Makuloco. So just beware.
  2. This is my stock 2016 Sport with the Sony system: 727-01-01 90A0 F200 0052
  3. I was browsing randomly through AliExpress and found they offer the sunroof cable for about $40 for the pair for 2015+ Edges. Link to the listing.
  4. If I'm not mistaken, it'll take an 8 hour period with no electrical interceptions for the battery state of charge to read correctly. Check next day.
  5. This module for cooled/heated seats is the one I meant and is also listed for a 2020 Edge Titanium. https://ford.oempartsonline.com/oem-parts/ford-seat-heater-control-module-bu5z14c724a
  6. Attached is for a 2015 showing the location of the boost pressure sensor, but I guess it is the same for all 2.7 Edges. Since both turbos dump compressed air to the same intake, the pressure of the compressed air should be the same. Turbocharger Boost Pressure Sensor.pdf
  7. Both are on there on my 2016 from factory. The left icon, if I recall correctly, indicates which camera view is shown. So if you turn in the front camera the highlighted parts change to the front, either the middle only or all three based on regular front view or split 180 view.
  8. No hearing element. It would have a TED device with a fan. One TED on the seat bottom and another in the seat back. There was an issue faced by some with the wiring & connector on the module that is under the passenger seat which controls both seats. Maybe check that. But a proper codes reading with ForScan or a dealer will get greatly assist in diagnosis. Check this F-150 thread for the issue.
  9. If you also have cooled seats, then your edge wouldn't have a heating element, rather a Thermoelectric Devices (TEDs) leveraging the Peltier effect. It is better to try reading codes using ForScan to assist in the diagnosis.
  10. If you haven't already figured it out, use the "load all" button and then scroll to the downloaded ABD file. This would restore the values for the selected module only from the selected file and loads on the screen. Then click "Write all" to actually write the values to the module. If the code is still present, maybe a battery disconnect will help. Another thing to consider, check if there is a setting in the display for the camera guidelines. I know some Ford models have the setting.
  11. If it works with ForScan, yes. It would then be able to read codes from all modules and if any code is present it can help direct you for a correct diagnosis.
  12. It is probably the damper arm got loose. Or of you recently changed the cabin air filter, it might have not been connected in pace properly. See any videos on how to change the cabin air filter and you'll see how it is connected. Like this:
  13. omar302
    Coolant Flush
    That is definitely not the way to go. There is no one coolant for all cars. As @1004ron suggested, is the best way to go. Drain/fill with distilled water several times until you have mostly distilled water, then drain and fill with concentrated coolant. Depending on you engine, fill half the coolant capacity with concentrate. Between drain/refill cycles, make sure to run the engine until it warms up to ensure complete mix.
  14. The issue used to be because the original pan and even several OEM updated versions depended on RTV gaskets that required extensive cleaning from possible contaminants and long cure/drying time that would eventually leak. Making an official fix unreliable. Ford later did come up with a Oil Pan with a press in gasket (instead of the RTV), so the official (latest) fix should be a good one with no need to look aftermarket, in my opinion. The fix differs between model years, for the 2015-2017 models is under TSB 24-2345 (link to details).
  15. I found a thread in Facebook of a similar issue. Seems the common issue is the aluminum oil pan. https://www.facebook.com/groups/fordedgeforum/posts/2749362808595155/
