omar302
    194
About omar302
omar302's Achievements
  1. My dealer did mine a few years ago, as per the TSB, no issues so far. Just FYI that the TSB fix is holding.
  2. Can you check if the driver's side CV axle has any in/out play? Mine does have, especially if trying to move it from the inner CV case. Kind of like and as if the grease is this and the snap ring that holds the shaft in the transmission has play in it. Should have made a video of it. The passenger front CV is tight with no play, so are both rear shafts. It is only the front Left (driver's) side. I have had a clunking noise for a few years now that comes when I press on the accelerator pedal from coasting, which usually is an indication of a trans and/or engine mount, but even after changing all 5 mounts the clunking is still there. This video is for an Explorer, but gives an idea of the play:
  3. Probably not the issue, but something to think about or get ideas. There was a TSB for the 2013-2015 FWD 3.5 EcoBoost (link) that fixed the smoking with changing the PCV cover adapter.
  4. Yes. There is another way in ForScan to disable auto start/stop without affecting the BMS. Posted it earlier here.
  5. The axle nut is supposedly a one time use only. So maybe a new nut would be cheaper first solution for a longer fix?
  6. Good to know. Hopefully the front camera will come next. I already had the rear camera replaced before under the extended warranty, not sure if the replacement would also be subject to the recall. Found more info on the recall here.
  7. I understand you. You can see the disconnection in action between the 2:15 and 2:25 marks.
  8. All model years have RDU with clutches. So when the clutches are disengaged it effectively "disconnects" the rear differential from the driveshaft. Pre 2019, the driveshaft will still turn because it is connected to the PTU/Transmission/Engine, while the rear differential will turn based on the speeds of the rear wheels. 2019+ models, the driveshaft stops rotating when the PTU disconnects. As can be seen in this video:
  9. Honestly, I don't know. But I'd guess it is either the motor itself is weak or the lift strut is not helping enough.
  10. If I am not mistaken, that update is for the tuner itself, not the tune. You need to contact them to check if there is a tune update. If there is, then they can push them to your tuner.
  11. All the codes show "Previously Set DTC - Not Present at Time of Request" making me think they came after you disconnected the module. Did you try to clear codes? If yes, do they come after that one cycle?
  12. Your ST should already have a Perimeter alarm. The only function the VSS would add to your ST is the shock sensor. I found 2023 installation instructions (here) and no special programming is required for VSS functions since if already have the key fob remote start from the factory.
  13. I have had the front camera randomly misbehave. Some times a scrolling display view and/or a dark distorted image. When the issue became more frequent, I bought a cheap replacement (~$27), however, after installation it was apparently designed as a rear view camera as the image was inverted (left/right) and it had the rear fixed guidelines. Also the 180 view did not work. Camera also would not program/calibrate with ForScan. So returned it and reinstalled the old camera as is. But, the misbehaving went away for a while, and now started coming back but much less frequently. Suggesting a contact issue. As I did not do the installation myself, I didn't check of corrosion, next time might do as you did and add die electric grease after cleaning the contacts.
  14. These part numbers seem to indicate replacement for the original pan that was designed for the correct model years with RTV silicone sealant, meaning should be with the check valve. But since it is aftermarket, there are no guarantees. Also, not clear which gasket was used, or whether is affects the check valves operations. If you're asking for a recommendation, it would seem that an OEM pan and gasket from the latest TSB 24-2345 should be the best option. Alternatively, maybe try to contact the aluminum pan's manufacturer for advise. Maybe it would work fine with the correct gasket, or perhaps your issue is not related to the pan.
  15. There is no Aluminum OEM oil pan for these engines. So the replacement is aftermarket and you have to know exactly which it is. If it was designed similarly to 2018-2020 model years, then yes, the valve covers should have been replaced. Ford did have the below warning (see the TSB in this post😞 CAUTION: Do not use the oil pan with press-in-place gasket on 2015-2017 model year vehicles as this oil pan is not equipped with a positive crankcase ventilation (PCV) check valve. Installation of this oil pan on a 2015-2017 model year vehicle will result in oil consumption which may result in engine damage.
