@1004ron
I had done the same for my Edge since installing a locally made H6 battery. However, in ForScan there is a PID to monitor battery state of charge, and after a few weeks it would not read correctly, be less than 80% most of the time, ~55-65%. I had attributed this to bad battery quality.
Recently I installed a new battery, same brand/size H6, and again after a few days same issue with the battery state of charge, less than 80%. I then checked with ForScan module configuration, the "Easy Mode" and found that the battery type was listed as "Incorrect value or not configured". Found out that for some reason, the ABD values "0C" & "0D" show this result.
So I tried the battery type just after the default one (Varta 70Ah 600CCA H6 Case), which is "13" in the ABD value, and not included in the battery type list in the F-150 ABD sheet). Couple of days later the battery state of charge got around 80% as it should be.
