egar
Everything posted by egar
I had the same thought, how the heck am I going to get tissues in there. Leave it to the wife, she says "I've got tissue packets that will fit that". Sure enough, she runs in the house and comes out with Kleenex packets that fit perfectly.
I had the same problem last winter. The power steering fluid level was about 1/16" below the minimum line. I topped off the fluid and the noise went away in a few seconds. The Edge seems to be quite sensitive to the PS fluid level.
Using usb drive or sd card for music?
egar replied to thinguy's topic in Audio, Backup, Navigation & SYNC
I just drag and drop from the iTunes app to my SD card. You can also copy directly the audio files directly from the iTunes folder to SD card or USB. Copying folder structure and all works just fine. -
Back up camera staying on in drive
egar replied to cnyle's topic in Audio, Backup, Navigation & SYNC
There is a setting that allows the backup camera to stay on after putting the Edge into drive. It will stay on continually until you reach a certain speed. I can't remember exactly where to find the setting on the MFT screen, probably under the vehicle settings menu. I'd suggest checking there first to see if the extended camera on setting is enabled. -
can edge sel AWD run in deep sand?
egar replied to monteiroalexandre's topic in All Wheel Drive (AWD)
Crazy jump that guy did with the Edge at the end. Did you see the speedometer just before the jump? Just under 120 kph (74 mph) -- that's keeping up some speed on the sand. :-) Does look like he was going that fast at the time he hit the dune, but he did get some good air. I wonder how much damage that did to the front end? -
Cycling through those options are controlled by the left and right buttons on the steering wheel switch. I'm sure you're using the up/down directions, so perhaps this is a switch problem. Maybe a short or dirty contacts in the switch?
I haven't taken my Edge offroad, so I don't have direct experience with it. I did grow-up near the Outer Banks and have spent a lot of time driving on the beaches and dunes there in various offroad vehicles. The sand on the Outer Banks tends to be very deep and loose (not packed). This puts a great deal of load on most vehicles (except really light weight vehicles with balloon tires, like dune buggies). The Edge, being a heavy-ish vehicle with road tires will want to sink into the sand and take a lot of power to keep moving. As Dr Fildo said, you can let air out of the tires to increase floatation on the sand. You may also be able to "plane" on the sand if you can get up enough speed. The Edge has marginal grown clearance for deep sand. Letting air out of the tires will lower the vehicle more. This is my major concern with taking the Edge onto the sand. You'll encounter many locations where other vehicles have traveled. These tire tracks can easily get over a foot deep and will high-center the Edge, leaving you sitting on floor pan and bumpers without the tires even being touching the sand. Personally, I'd be reluctant to take the Edge into the sand. If you can't resist, lower air pressure to 15 lbs, go easy - don't spin your tires, keep up as much speed as safe to do, don't climb hills, and stay out of ruts caused by other vehicles. Good luck! -
I can put my clubs straight across if I pull the driver out of the bag. I've carried 4 sets this way, needing only to pull the drivers out of the two sets that were closest to the back seat.
Headlight polishing
egar replied to galcala's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I also used the 3M kit and couldn't have been happier with it! It was in my wife's 10 yr old Audi. Took about 30 min per headlight. Followed the directions closely. I was a bit tempted to shortcut a few steps in the interest of time, but was so happy with the outcome I'm glad I didn't. One recommendation, cover up surrounding areas with paper or a drop cloth. The spinning pad will put off a fine spray of sanded down plastic and water. The drop cloth will save some clean-up time. -
Checkout http://www.thecarconnection.com/overview/ford_edge_2014. First media coverage if the 2014 Edge that I've seen.
I've got the Mountek (http://www.mountek.com) CD slot mount and have been pleased with it. Holds the phone solidly and in a convenient location. It does slightly cover up the volume/tuner knob on the radio, but I rarely use it because of the touch screen and steering wheel controls. For $20, it's a good deal. My only caution would be to say that you can hit your knuckles on the mount when shifting into park. After doing it a couple of time, I learned keep my fingers out of the way when the mount is in place.
newbie with a navi traffic question
egar replied to Jamie Evans's topic in Audio, Backup, Navigation & SYNC
I use Waze as my primary GPS, replacing my Tom Tom device. I find the routing and real time traffic updates to be superior to what Tom Tom is offering. Waze has even provided some real unique routing that I never would have thought about. I couldn't be happier with it, especially considering it is free! -
Thanks for the tip Dingo. That would have to be a lot of music not to fit on a large capacity flash. I've got a long way to go before I'll have to worry about that.
Normcloutier, you asked two questions in your first post - copy music and copy playlists. Copying playlists will need some type software as others have suggested to extract your playlists from the iTunes library files. I did want to let you know there is an easy way (no software required) to copy just the music to a USB or SD Card. I do this on my Mac, but I think same process would work on a Windows PC as well. For me, I just copy everything from "/Users/ed/Music/iTunes/iTunes Music" directory to the USB or SD Card. Works like a charm!
To Touch or not to Touch, what's say you?
egar replied to txken's topic in Audio, Backup, Navigation & SYNC
I've had my Edge with MFT for 4 months and have been quite pleased. The MFT has behaved perfectly. Sure there are some quirky features that I wouldn't have designed that way, but I can say that about most of the tech products I have. If I had to choose again, I'd still go for the MFT. By the way, I don't have the navigation option, I still would not opt for that in the future either. Dedicated GPS or smartphone options still win out over MFT version in my opinion. -
Interior Illumination quesiton
egar replied to Cruiser64's topic in Interior, A.C., Heat, Interior Trim
I never really noticed until you brought up the question. I checked my 2012 Limited and found that no, they did not light up. Like you said, probably not a big deal... -
I used an old mouse pad and cut to the size of the bottom of the cup holders. I put the printed side down, so only the black rubber shows. I guess it was about 3/16" thick and provides excellent padding.
ambient lighting problem after sync update
egar replied to flyers27's topic in Audio, Backup, Navigation & SYNC
Yeah, that's definitely different than mine. When I turn ambient lighting off, it stays off. When I set it on at a certain color and brightness level, it stays that way. -
On my 2012 Limited the blue lighting always comes on when entering the car and after turning off the ignition. Sometimes I run the red ambient lighting at its lowest setting. But whenever you enter or exit the vehicle the blue lighting comes on at its brightest setting. I view it as courtesy lighting -- it compliments the whole lighting package (puddle lights, dome lighting, etc) when entering or exiting. -
White Platinum Metallic Tri-coat For both men and women
egar replied to Chris13's topic in Welcome Forum!
I think people make too big a deal about make, model, and color of vehicles as they relate to gender. Sure there are a few colors (e.g. bright pink) that probably don't look so good for most men to drive -- but then again, that's their choice. As for your question, I really like the While Platinum, wish I could have found one when I bought my used 2012 Edge. I ended up with black (more manly perhaps?), but would have been very happy to have either the White Platinum or Mineral Gray. -
Windshield Washer fluid not coming out
egar replied to Laurie Budziszewski Weber's topic in 2007 Edge & MKX
I'm not sure where you are located, but the weather here is getting cold. Could possibly be frozen washer fluid in the line. I just had the same problem with my Edge. I bought the 2012 Edge used about a month ago. The dealer had put in cheap washer fluid that froze when the temps got to the low 20's. I parked the car all day in a heated underground parking garage to thaw the fluid and then I siphoned out all the old washer fluid and replace it with a good winter stuff. -
steering wheel controls light up?
egar replied to sillyjt's topic in Interior, A.C., Heat, Interior Trim
For my 2012 Edge Limited, the controls on the steering wheel light up and so does the shift indicator. Sounds like you might have a problem. -
egar replied to exodus's topic in Audio, Backup, Navigation & SYNC
New Edge owner here. I just updated Sync from 3.02 to 3.22. Followed the instructions on syncmyride.com and had no problems. The update process took about 35 minutes. A couple of times it seemed stuck but I was patient and it kept working. During one of the reboots, the system appeared to be off for several minutes, but restarted on its own. All settings and radio presents were retained. The only thing I needed to do after the update was re-pair my bluetooth phone. Like others have reported, the temperature now displays on the main screen. Another thing I noticed, but have not seen mentioned is the date is now correct on the calendar.
