WhiteMKX2008
Everything posted by WhiteMKX2008
  1. I am also glad it's smart enough to protect itself from the engineers who designed the volume knob
  2. I'll leave it for now. See what happens when it gets colder. I'm just glad it seems to be the consensus that it's acting normally.
  3. That's kind of what I thought. But honestly, I would think any system that allows you to set it to MAX in the first place would be able to handle playing at MAX. Maybe my ears are just damaged from too much clubbing when I was younger, so I need it LOUD
  4. It doesn't seem like anything is blown. I can feel air whuffing out of each speaker. It just can't handle high volume, high bass before quickly quieting down. I just don't know why it quiets down. It should also be stated that I am not a sound guy by any means lol.
  5. Hi guys, It seems when I play songs with a lot of bass and at MAX volume, the volume will drop substantially over a few seconds and then rise and fall during the song depending on the amount of bass at any particular point. Is this normal or is something loose or something? Cheers
  6. Fact - the drone on highway portion of my commute got old very quickly. I guess that's why the real thing (Corvette + Corsa) is better.
  7. I've only had this car from 91k to 105k so so far that's the only thing. My last car was a Taurus and it was decent. I'm hoping this car is even better
  8. Thanks . Now come post-install checks where I make sure things aren't heating up/melting.
  9. So I was googling Corvettes and Corsa mufflers and angrily glancing at my Lincoln with it's contemptuously quiet exhaust when I bought this app. I tried it out today and it is a hoot! I actually saw a challenger and a Camaro out on the roads. No more being disappointed when I kill the radio and air and open the windows only to hear an unsatisfying exhaust from the other car. Now I have my very own synthetic exhaust booming out of my stereo! You guys should try it. Best $1 you ever spent.
  10. For future generations and posterity: spliced in new connector. Light works. All is well.
  11. Bulb is good. Saw some melted plastic on the H11 connector. One of the prongs inside the connector is longer and seems to contribute to a bad connection. Bought a new connector locally for $6. Going to splice it in tomorrow.
  12. Hmm no dice. When I got home both lights were on. Checked 10 minutes later and the same light was off again.
  13. I'm getting some intermittent function out of the lowbeam. After I get home from work it's off, but if I pop the hood and fiddle with it a bit it will come back on. I'm noticing the wire connector attached to the bulb has about 1 cm of bare wire. I wrapped it in electrical tape and I'll check again tonight. Could it be melting insultation? If so, can that wire connector be replaced by itself? It seems to connect somewhere in the bowels of the headlight assembly. Thanks.
