rls7
Everything posted by rls7
  1. Have to agree thats what i did ..... yanked out the ddm and installed trs (morimotos ) and been working fine ever since... the real kicker is ddm is only a couple miles from my house, i went in person to buy them.
  2. I had a problem with my ddm tuning set up as well (was blowing fuses) with their relay harness. so i took the hole thing out and started fresh with the TRS set up, no relay just the canbus adapter, it works perfect, the only two issues are when you plug their harness into the ford factory plug its upside down, so you cant use the snap lock on the plug unless you remove the wires from the trs plastic plug and reverse them,or you can just run a piece of electrical tape around the plug to hold them together, and the bulbs are a little tough the get in . but this trs kit with the canbus adapter is just plug and play . works great.
  3. yea i just installed a set of TRS Morimoto HID 35 watt 5000 with the canbus adapter and couldnt be happier . had the ddm tuning 35 watt with relay but it just didnt work right for me. although i must say the ddm tuning bulbs fitted better.
