Haz
    392
Everything posted by Haz
  1. After re-reading your several posts here, it seems that you're describing a vehicle that's not initially recognizing its rightful keyfob as being authorized, until after you very briefly interrupt battery power to the entire system, at which point that same keyfob commands the entire system to life. Without an authorized keyfob present, most of the conditions you describe are normal: exterior keypad is functional and unlocks/locks doors, alarm sounds when door is unlocked with emergency key & exterior keypad silences the alarm, horn works. The non-working interior door switches are puzzling, though. But, you mention a distinct lack of gauge cluster messages, so your Edge did not respond with 'No Key Detected'. Looking through Keyfob / PATS-related diagnostics, I found this... Did you happen to notice if the button's LED was flashing ? Or otherwise, take note if there is a 'next time'. Step 4 is... Good luck!
  2. The message was posted to a secure Ford information system serving Professional Service Technicians & Service Advisors at Ford & Lincoln dealerships, and other selected Ford Motor Company employees. As I learn more about this issue, I will share updates here and in the Recalls, TSBs & Warranty Forum. Good luck!
  3. SSM 50873 - Various 2017-2022 Ford And Lincoln Vehicles - Missing Authorization, Command And Control Or Phone-As-A-Key Buttons In FordPass Or LincolnWay App Some 2017-2022 Ford and Lincoln vehicle owners may experience a condition of missing authorization, command and control, battery charging details or phone-as-a-key setup buttons/selections in their FordPass or LincolnWay App. This condition is due to an error within the FordPass or LincolnWay App and not due to a concern on the vehicle. Verify that the customers FordPass or LincolnWay App is at the latest version. Replacement or reprogramming of the telematics control unit (TCU)/gateway module (GWM)/remote function actuator (RFA) will not resolve this condition. If the condition persists, utilize the FordPass Guides or Lincoln Way Concierge teams. APPLICABLE VEHICLES 2018 - 2019 CAR: PL D544N CONTINENTAL 2018 - 2019 CAR: BW B515A ECOSPORT INDIA 2018 - 2019 TRUCK: UB U502N EXPLORER 2018 - 2019 TRUCK: UB U502N EXPLORER 2018 - 2019 TRUCK: M2 C520N ESCAPE 2018 - 2021 CAR: D9 U540N MKX 2019 CAR: CT B299N FIESTA MCA 2018 - 2020 CAR: C7 CD391N FUSION 2017 TRUCK: M2 C520N ESCAPE 2017 CAR: C7 CD391N FUSION 2021 - 2022 CAR: HD CX430N C-SUV 2021 - 2022 TRUCK: FD P702N F150 2021 - 2022 CAR: GW CX727N C-EV 2020 - 2022 CAR: TV U611N AVIATOR 2020 - 2022 CAR: TF CX483N CORSAIR 2020 - 2022 CAR: TW U625N EXPLORER 2019 - 2022 CAR: DQ CD539N EDGE 2019 - 2022 TRUCK: FE P558N SUPER DUTY 2019 - 2022 TRUCK: FG P375N RANGER 2019 - 2022 CAR: HC V408E TRANSIT CONNECT 2019 - 2022 CAR: HC V408E TRANSIT CONNECT 2018 - 2022 TRUCK: B8 U553N EXPEDITION 2021 CAR: ET U540A NAUTILUS 2018 - 2022 CAR: ZG S550N MUSTANG 2018 - 2022 TRUCK: B9 U554N NAVIGATOR 2020 - 2022 CAR: TC CX482N ESCAPE 2017 - 2020 TRUCK: FC P552N F-150 2017 - 2020 CAR: C7 CD391N FUSION
  4. Omar: Below are PDF download links & JPG image files from sections of the 2016 Edge Workshop Manual relating to P2610 Diagnostic Trouble Code and Steering Column Lock Module... Good luck! Steering Wheel and Column Electrical Components - System Operation and Component Description - 2016 Edge Workshop Manual.pdf Steering Wheel and Column Electrical Components - Diagnostics and Testing - 2016 Edge Workshop Manual.pdf Steering Column Lock Wiring Diagram - Cell 112 Page 4 - 2016 Edge Workshop Manual.pdf Battery Junction Box (BJB) Connector C1035A Details - 2016 Edge Workshop Manual.pdf Body Control Module (BCM) Connector C2280C Details - 2016 Edge Workshop Manual.pdf Body Control Module (BCM) Connector C2280G Details - 2016 Edge Workshop Manual.pdf Steering Column Lock Module Connector C2434 Details - 2016 Edge Workshop Manual.pdf Body Control Module (BCM) Removal and Installation - 2016 Edge Workshop Manual.pdf Fuse Details - Power Distribution Box & Passenger Compartment Block - 2016 Edge Owner's Manual.pdf
  5. Mustang Mach-E has 15.5" screen... Good luck!
  6. Welcome to the Forum! If you have not already, you may want to review the following Forum discussions... Rough Idle When Cold/P0301 Code - coolant intrusion 2017 Ecoboost, diagnose coolant loss for long block replacement. Good luck!
  7. SSM 50884 - 2021 Edge - Front Camera Inoperative After Vehicle Traveled Over 6MPH (10Km/h) Some 2021 Edge vehicles may exhibit the front camera not turning back on if the camera system button is pressed once the vehicle is below the speed threshold of 6MPH (10km/h). This may be due to the accessory protocol interface module (APIM) software. Inform customers that engineering is currently working on a solution for this condition and will be released via an over the air (OTA) software update, expected in September 2022. Software will update automatically if the vehicle is connected to FordPass. Monitor OASIS for additional information. Schedule a service appointment for customers that are not connected to FordPass once the repair becomes available. APPLICABLE VEHICLES 2021 CAR: DQ CD539N EDGE
  8. Latest OASIS Broadcast Message provides September 2022 target for software patch and OTA deployment for FordPass-connected vehicles, Dealer service bay for others... Jun 17 2022 2021 Edge - Front Camera Inoperative After Vehicle Traveled Over 6MPH (10Km/h) Some 2021 Edge vehicles may exhibit the front camera not turning back on if thecamera system button is pressed once the vehicle is below the speed threshold of 6MPH (10km/h). This may be due to the accessory protocol interface module (APIM) software. Inform customers that engineering is currently working on a solution for this condition and will be released via an over the air (OTA) software update, expected in September 2022. Software will update automatically if the vehicle is connected to FordPass. Monitor OASIS for additional information. Schedule a service appointment for customers that are not connected to FordPass once the repair becomes available. Good luck!
  9. OASIS Broadcast Message, posted on Ford's Professional Technician's System... Jun 15 2022 2021 Edge Front Camera Concerns after OTA update or SYNC update Concerns started with OTAs released/retrieved on 05/04/2022. Customers also reported the issue after the FSA 22S14 is performed. The camera will work if you activate it with the button. After driving, the camera button works until the vehicle speeds exceeds 9mph - 15km/h. After coming to a stop, you cannot activate the camera again until the vehicle is restarted with an ignition cycle or a SYNC soft reset / 2-button reset. This concern can be induced by the latest SYNC SW via OTA update or FSA/recall SW update. Do Not attempt to diagnose the concern. Replacing the camera or module(s) will not address the condition. Please monitor the FSA Landing Page for updates and monitor OASIS Broadcast Messages for updates. I will provide updates as more info becomes available. Good luck!
  10. Feature Comparison - Sync 4 versus Sync 4A... Good luck! SYNC 4 with Enhanced Voice Recognition SYNC 4 with Enhanced Voice Recognition allows the customer to use conversational voice commands and includes either an 8-inch touchscreen or a 12‑inch touchscreen with a new split-screen Information on Demand panel The 12-inch version with the Information on Demand panel, located on the right side of the main touchscreen, can display the customer’s smartphone, music or audio, available Connected Navigation (90‑day trial)(2) or Connected Built-In Navigation (3‑year service period), trips or fuel efficiency Some content from the Information on Demand panel can be slid left into the Main screen With a design similar to SYNC 3, customers will be able to operate this version with ease The bottom menu is accessible no matter what is showing on the SYNC 4 touchscreen and the 12-inch touchscreen now includes a new Favorites icon. This icon allows the customer to assign a feature of their choice to the Favorites button The upper bar provides status information, such as the time, temperature and Ford Power-Up software update messages Customers will appreciate cordless smartphone pairing, Apple CarPlay® and Android Auto™ compatibility, SiriusXM® with 360L availability and Alexa Built-In compatibility The Ford Assistant allows customers to use conversational voice commands SYNC 4 Technology also carries over base embedded voice capability from SYNC 3, with the addition of a “wake word,” natural language understanding and one-box Navigation search. These embedded features are available regardless of whether a cloud connection is available in the vehicle Phone controls, such as email message read and reply Navigation options, such as one-box search from the main menu for addresses, Points of Interest (POIs) and intersections Radio/media operation Climate features SYNC AppLink controls The embedded voice allows the customer to use a “wake word” to talk to the vehicle. The wake word is turned Off by default but can be turned On in Settings. Go to Settings > Voice Control > Listen for Wake Word “OK, Ford” is the default wake word, but the other options include “OK, FordPass,” “OK, Ford SYNC” or “Hello, Ford” A short press of the Push-to-Talk (PTT) button on the steering wheel can be used instead of the wake word. A long press of the PTT button will alert Android Auto or Apple CarPlay, if connected SYNC 4A with Enhanced Voice Recognition SYNC 4A with Enhanced Voice Recognition is a one-stop shop for most of the vehicle controls, including applications, settings and climate controls. The SYNC 4A touchscreen offers a unique layout and larger font size for readability With a screen size up to 15.5 inches, the screen layout is divided into three sections: Status bar: Provides vehicle status information, time, temperature and over-the-air Ford Power-Up software update messages Active screen: Displays the current feature in use and Adaptive Dash Cards. Adaptive Dash Cards display up to six recently used or popular apps. Swipe up or tap to launch a card into the Active area and swipe down to close it. All apps shown, including Dash Cards, are active Lower tray: Certain controls for temperature and volume that are always available on-screen The touchscreen features include: Applications drawer: Location of apps once a smartphone is paired Controls tab: Find vehicle controls — such as drive modes, camera and other driver-assistance features Settings tab: Location of vehicle settings Volume knob (if equipped): Control volume of in-vehicle audio and tap center of the knob to turn audio On or Off Climate controls: Soft keys, which may be located at bottom of the screen SYNC 4A learns habits of the customer in order to provide suggestions, such as calling home during rush hour or driving to a preferred coffee shop en route to work in the morning Intelligent one-touch suggestions are based on the driver’s daily routine and appear as shortcuts on screen The customer preference icons are stored in the Applications drawer next to the personal profile name It can take up to two weeks to learn the customer’s habits and preferences. Customers can opt out of this feature by turning intelligent suggestions Off in their Settings Customers will appreciate cordless smartphone pairing, Apple CarPlay® and Android Auto™ compatibility, SiriusXM® with 360L availability and Alexa Built-In compatibility. Up to 12 devices can be connected, but only one can be active The Digital Assistant allows customers to use conversational voice commands to talk to the vehicle and ask questions more like Siri or Alexa Ford Sketch allows customers to draw, erase, clear, save and use different brush sizes directly on their SYNC 4A touchscreen. They can also play tic-tac-toe and use a calculator with this feature (Mustang Mach-E only) SYNC 4 Technology also carries over base embedded voice capability from SYNC 3, with the addition of a “wake word,” natural language understanding and one-shot Navigation search. These embedded features are available regardless of whether a cloud connection is available in the vehicle: Phone controls, such as email message read and reply Navigation (with an active subscription) options, such as one-box search from main menu for addresses, Points of Interest (POIs) and intersections Radio/media operation Climate features SYNC AppLink controls The embedded voice allows the customer to use a “wake word” to talk to the vehicle. The wake word is turned Off by default but can be turned On in Settings. Go to Settings > Voice Control > Listen for Wake Word “OK, Ford” is the default wake word, but the other options include “OK, FordPass,” “OK, Ford SYNC” or “Hello, Ford” A short press of the Push-to-Talk (PTT) button on the steering wheel can be used instead of the wake word. A long press of the PTT button will alert Android Auto or Apple CarPlay, if they are connected
  11. SSM 50858 - 2019-2022 Ford/Lincoln Vehicles - SYNC 3 Display Brightness Can Only Be Adjusted In Dark Or Night Time Conditions Some 2019-2022 Ford or Lincoln vehicles with SYNC 3 may notice that the display brightness can only be adjusted in dark or night time conditions. This is a normal condition after software release 3.4.21020 or later. Covering the sunload sensor to eliminate any ambient light to verify brightness adjustment is recommended to test the feature if needed. No repairs should be attempted to address this condition. APPLICABLE VEHICLES 2019 - 2020 CAR: PL D544N CONTINENTAL 2019 - 2020 CAR: DQ CD539N EDGE 2019 - 2020 TRUCK: FC P552N F-150 2019 - 2020 CAR: C7 CD391N FUSION 2019 - 2020 CAR: D9 U540N MKX 2019 - 2020 CAR: C9 CD533N MKZ 2019 - 2021 TRUCK: TH V363N TRANSIT 2019 - 2022 CAR: ZG S550N MUSTANG 2019 - 2022 TRUCK: FG P375N RANGER 2019 - 2022 CAR: HC V408E TRANSIT CONNECT 2019 - 2022 CAR: HC V408E TRANSIT CONNECT 2020 - 2021 TRUCK: B8 U553N EXPEDITION 2020 - 2021 TRUCK: B9 U554N NAVIGATOR 2020 - 2022 CAR: TV U611N AVIATOR 2020 - 2022 CAR: TF CX483N CORSAIR 2020 - 2022 CAR: BW B515A ECOSPORT INDIA 2020 - 2022 CAR: TC CX482N ESCAPE 2020 - 2022 CAR: TW U625N EXPLORER 2020 - 2022 TRUCK: FE P558N SUPER DUTY 2021 - 2022 CAR: HD CX430N C-SUV 2022 CAR: FE P758N C-PICKUP
  12. You are kind and generous in your reply, but I have served you poorly by commenting off the top of my head, without referencing the Workshop Manual. From the 2022 Edge Workshop Manual, on Push Button Start operation, modes of ignition readiness, and LED ignition mode indicator behavior... Ignition Switch - Push Button Start The ignition switch - push button start (engine start/stop button) is a momentary contact switch that is hardwired to the BCM and the PCM . The ignition switch - push button start is used to obtain the OFF, ON or START ignition modes. Push Button Ignition Switch The push button ignition switch is used to control the ignition mode. Ignition Entry Condition Desired Ignition Mode Action To Take Off ON (engine off) Press the START/STOP button without applying the brake pedal. Off or on START Apply the brake pedal and then press the START/STOP button. On (engine off) OFF Press the START/STOP button. On (engine running) OFF Press the START/STOP button. Ignition Mode LED Indicator The ignition mode LED indicates the ignition mode of the vehicle. The BCM controls the voltage to the ignition mode LED indicator. Refer to the following table. Ignition Mode Ignition Mode LED Indicator Off Off On (engine off) Flashing On (engine running) On OFF When the ignition is in the ON mode, a single press and release of the START/STOP button (without applying the brake pedal) changes the ignition to the OFF mode. No programmed key is required to change the ignition to the OFF mode when the vehicle is running. If the vehicle is in motion, a momentary press of the START/STOP button does not shut the vehicle off. If the vehicle is moving at a speed greater than 15 km/h (9 mph), the START/STOP button must be pressed and held for longer than one second (or pressed 3 times within 2 seconds) to turn the ignition off. ON When the vehicle enters ON mode, multiple indicators in the IPC prove out and the IPC displays the gear selection and the vehicle mileage. START The vehicle temporarily enters the START mode if the brake pedal is applied when the START/STOP button is pressed, and a valid programmed key is detected within the vehicle. After the ignition has completed the vehicle start sequence, the ignition mode returns to ON and the ignition mode LED in the START/STOP button illuminates steadily. The engine can be started from any ignition mode. I hope this additional information equips you to successfully access the Bezel Diagnostics function, to conduct the Speaker Walk-Around test or to access any useful Sub Menu tests or other data points. Below is a PDF download link to another B&O Audio info sheet, as a token of my appreciation for your generous attitude... Good luck! B&O Sound System by Bang & Olufsen - 2022 Ford Edge.pdf
  13. Sorry, I don't have access to any dimensional data on the LED turn signal component, or any CAD document. Because I was focused on new mirror sellers and their pricing, I have neglected to ask you these few questions... Have you verified that power is being delivered through the harness to the mirror's LED strip when the left turn signal is operating Have you applied continuous power to the LED strip, via appropriate pins in the mirror's connector, to verify that it is absolutely not working? Have you used a diagnostic scan tool to see if any turn-signal related Diagnostic Trouble Codes (DTCs) are stored in your Edge's electrical modules? Below are download links to wiring diagram, wiring connector circuit details, and the connector location illustration... Good luck! Exterior Rear View Mirror, LH Side with Memory - Wiring Diagram - 2014 Edge Workshop Manual.pdf Exterior Rear View Mirror, LH Side - Connector C516 Circuit Details.pdf
  14. Sorry that I wrongly marked the seek button. (The following has been struck-thru by Haz, due to it being incorrect. Please refer to Workshop Manual description in next post by Haz, below...) The first momentary push of the button is Accessory Mode, the second momentary push of the button is Ignition Mode, during which the warning light icons in the gauge cluster should light up and you may hear several chime tones that subsequently go quiet, while some of the gauge cluster warning light icons will stay lit, until a third momentary push of the button shuts everything back off. Good luck!
  15. Omar: With you providing them the Recall details, at least they can inspect & ensure there is no issue with the cable bushing, and/or evaluate if the cable bushing is a contributing factor to your Edge's symptoms. Good luck!
  16. Updated Notice To Dealers (partial letter, with red line emphasis added) Refunds For Owner-Paid Transmission Shifter Cable Bushing Repairs Sample Letter To Owners PDF Download Link To Recall Repair Technical Info Safety Recall 22S43 - Technical Info - 07-05-2022.pdf
  17. On the 2022 Edge, the Audio Controls Panel is at the bottom of the touchscreen and is removable from the touchscreen's backside... I've not run the Procedure, but you might try the below-marked button combination first, to see if that works, and then try the steering wheel controls method, and please report back on the outcome... (The following image has been struck-thru by Haz, due to its being incorrectly marked...) (The following corrected image has been added by Haz...) Since you have the B&O system in your ST, perhaps you'll enjoy the PDF download link below... Good luck! B&O Audio - 2022 Edge.pdf
  18. Bezel Diagnostics - Speaker Walk-Around Procedure & Sub-Menu List - 2022 Edge Workshop Manual.pdf (Download link) Good luck!
  19. Judging by the body-color door handle in your mirror photo, I expect your Edge is an SEL, Limited, or Sport. Looking at your Edge's possible mirror attributes provides a similar judgement, with the driver memory capability being the only likely feature either included or not included in your existing mirror... Since you mention replacement cost as being absurd in Brazil, one path for you may be to buy a new Ford OEM mirror with the LED turn signal indicator, but without the BLIS monitoring mirror face, and then change over the BLIS-capable wiring harness and mirror face from your existing mirror into the new mirror shell, keeping the new power mirror motor, presuming it has driver memory function, if your Edge requires it. You then could also remove the body-color cap from the top/front of your existing mirror and install it on the new mirror shell, eliminating the need for painting the new mirror. This Ford OEM mirror assembly is candidate for this cost-saving strategy. Its cost is surprising low (by U.S. standards), if the power/puddle lamp/driver memory/heated/LED turn signal feature list is accurate... It's worth noting the risk that something could be broken during the changing over of components from your Edge's existing mirror to new Ford OEM mirror. The other path you could choose would be to buy an aftermarket mirror assembly with the full list of features your Edge's existing mirror has. Via the Forum's Message system, I have sent you information on a such an aftermarket mirror sold by a very reputable U.S. online seller who offers shipping to Brazil and displays pricing in your country's currency. So it's up to you to weigh the costs and risks associated with each path. Below are PDF download links to sections of the 2014 Edge Workshop Manual related to Power Mirrors, as well as to a 2014 Edge reference document that will explain all other features of your 2014 Ford Edge. Good luck! Exterior Mirror - Removal and Installation - 2014 Edge Workshop Manual.pdf Exterior Mirrors - Exploded View - 2014 Edge Workshop Manual.pdf Exterior Mirror Glass - Removal and Installation - 2014 Edge Workshop Manual.pdf Exterior Mirror Cover - Removal and Installation - 2014 Edge Workshop Manual.pdf Exterior Mirror Motor - Removal and Installation - 2014 Edge Workshop Manual.pdf Exterior Mirror Control Switch - Removal and Installation - 2014 Edge Workshop Manual.pdf 2014 Ford Edge Source Book.pdf
  20. As you mention, Ford just extended to November 30, 2022 the Customer Satisfaction Program (19B37, 21N12) for coolant intrusion on the 1.5L Ecoboost in certain 2017-2019 Escape & Fusion models with no mileage limit. That Program's refund policy for affected Escape & Fusion owners, per the Owner Extension Letter, is... "If you paid to have this service done before the date of this letter, you may be eligible for a refund. Refunds will only be provided for service related to an engine short block or head gasket replacement due to coolant intrusion into the engine cylinder bores. To verify eligibility and expedite reimbursement, give your paid original receipt to your dealer before November 30, 2022. To avoid delays, do not send receipts to Ford Motor Company." Good luck!
  21. The 2011 Edge/MKX Workshop Manual wiring diagram shows the PRNDL of the floor shifter is LED illuminated. The LED is attached to the underside of the Console Cover Panel (78045A76), and has a short wiring harness with a C3617 connector that plugs into a corresponding harness on the console's left side. The Floor Shifter Illumination LED and its wiring harness appear to only be provided in the assembly of the Console Cover Panel. Below are PDF download links to the Selector Lever Knob Removal and Installation procedure from the Workshop Manual, which includes the action steps toward removing the Console Cover Panel; and also to Floor Shifter Illumination Wiring Connector C3617 Details document... As @enigma-2 mentions, if you are able to remove the trim panel and assess what type of LED array is attached to the short wiring harness, and you're able to find a replacement LED array online, then the LED replacement cost will certainly be much less than the cost of a new Console Cover Panel with its included LED illumination, per this FordParts listing estimating cost, which depends upon options installed on your Edge... If you have not already viewed it, this very good Youtube video shows how relatively easy it is to remove the Console Cover Panel, and it also shows the involved LED illumination C3617 electrical connectors. Good luck! Selector Lever Knob Removal and Installation - 2011 Edge Workshop Manual.pdf Floor Shifter Illumination Wiring Connector C3617 Details - 2011 Edge workshop Manual.pdf
  22. Paragraph reformatted for clarity... Warranty Status: Eligible under provisions of... New Vehicle Limited Warranty (NVLW)/ Emissions Warranty/ Service Part Warranty(SPW)/ Special Service Part (SSP)/ Extended Service Plan (ESP) ...coverage. Good luck!
  23. Models: Ford 2015-2018 Edge 2017-2019 Escape Built on or before 16-May-2019 2017-2019 Fusion Built on or before 8-Apr-2019 Lincoln 2017-2019 MKC Built on or before 18-Apr-2019 2017-2019 MKZ Built on or before 8-Apr-2019 Summary This article supersedes TSB 22-2133 to update the Parts List. Issue: Some 2015-2018 Edge and 2017-2019 Fusion/MKZ/Escape/MKC vehicles equipped with a 2.0L EcoBoost engine may exhibit a low coolant level, white exhaust smoke and/or a runs rough condition with or without an illuminated malfunction indicator lamp (MIL). Diagnostic trouble codes (DTCs) may include P0300, P0301-P0304, P0316, P0217, P1285 and/or P1299 stored in powertrain control module (PCM). This may be due to coolant intrusion into the cylinder. To correct the condition, follow the Service Procedure to replace the long block engine assembly. Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria: • One of the following vehicles: Below is PDF dowload link for full TSB 22-2229 document, which provides Service Action parts lists for all included models... TSB 22-2229 - 2015-2018 Edge + Other Models, 2.0L EcoBoost - Coolant In Cylinders, White Exhaust Smoke And_Or Illuminated MIL.pdf
  24. For any 2019-2020 Edge/Nautilus owners reviewing this discussion due to Sync 3 screen loss of temperature display, please see... TSB 22-2225 2019-2020 Edge & Nautilus + Other Models: SYNC 3 - Various SYNC Symptoms, SYNC Screen Flicker, Echo/Robotic Voice Concerns, Temperature Not Displayed In Pop Up Screen Good luck!
