Haz
Everything posted by Haz
Judging by the body-color door handle in your mirror photo, I expect your Edge is an SEL, Limited, or Sport. Looking at your Edge's possible mirror attributes provides a similar judgement, with the driver memory capability being the only likely feature either included or not included in your existing mirror... Since you mention replacement cost as being absurd in Brazil, one path for you may be to buy a new Ford OEM mirror with the LED turn signal indicator, but without the BLIS monitoring mirror face, and then change over the BLIS-capable wiring harness and mirror face from your existing mirror into the new mirror shell, keeping the new power mirror motor, presuming it has driver memory function, if your Edge requires it. You then could also remove the body-color cap from the top/front of your existing mirror and install it on the new mirror shell, eliminating the need for painting the new mirror. This Ford OEM mirror assembly is candidate for this cost-saving strategy. Its cost is surprising low (by U.S. standards), if the power/puddle lamp/driver memory/heated/LED turn signal feature list is accurate... It's worth noting the risk that something could be broken during the changing over of components from your Edge's existing mirror to new Ford OEM mirror. The other path you could choose would be to buy an aftermarket mirror assembly with the full list of features your Edge's existing mirror has. Via the Forum's Message system, I have sent you information on a such an aftermarket mirror sold by a very reputable U.S. online seller who offers shipping to Brazil and displays pricing in your country's currency. So it's up to you to weigh the costs and risks associated with each path. Below are PDF download links to sections of the 2014 Edge Workshop Manual related to Power Mirrors, as well as to a 2014 Edge reference document that will explain all other features of your 2014 Ford Edge. Good luck! Exterior Mirror - Removal and Installation - 2014 Edge Workshop Manual.pdf Exterior Mirrors - Exploded View - 2014 Edge Workshop Manual.pdf Exterior Mirror Glass - Removal and Installation - 2014 Edge Workshop Manual.pdf Exterior Mirror Cover - Removal and Installation - 2014 Edge Workshop Manual.pdf Exterior Mirror Motor - Removal and Installation - 2014 Edge Workshop Manual.pdf Exterior Mirror Control Switch - Removal and Installation - 2014 Edge Workshop Manual.pdf 2014 Ford Edge Source Book.pdf
As you mention, Ford just extended to November 30, 2022 the Customer Satisfaction Program (19B37, 21N12) for coolant intrusion on the 1.5L Ecoboost in certain 2017-2019 Escape & Fusion models with no mileage limit. That Program's refund policy for affected Escape & Fusion owners, per the Owner Extension Letter, is... "If you paid to have this service done before the date of this letter, you may be eligible for a refund. Refunds will only be provided for service related to an engine short block or head gasket replacement due to coolant intrusion into the engine cylinder bores. To verify eligibility and expedite reimbursement, give your paid original receipt to your dealer before November 30, 2022. To avoid delays, do not send receipts to Ford Motor Company." Good luck!
2011 Gearshift selector lights
Haz replied to jcouture812's topic in Interior, A.C., Heat, Interior Trim
The 2011 Edge/MKX Workshop Manual wiring diagram shows the PRNDL of the floor shifter is LED illuminated. The LED is attached to the underside of the Console Cover Panel (78045A76), and has a short wiring harness with a C3617 connector that plugs into a corresponding harness on the console's left side. The Floor Shifter Illumination LED and its wiring harness appear to only be provided in the assembly of the Console Cover Panel. Below are PDF download links to the Selector Lever Knob Removal and Installation procedure from the Workshop Manual, which includes the action steps toward removing the Console Cover Panel; and also to Floor Shifter Illumination Wiring Connector C3617 Details document... As @enigma-2 mentions, if you are able to remove the trim panel and assess what type of LED array is attached to the short wiring harness, and you're able to find a replacement LED array online, then the LED replacement cost will certainly be much less than the cost of a new Console Cover Panel with its included LED illumination, per this FordParts listing estimating cost, which depends upon options installed on your Edge... If you have not already viewed it, this very good Youtube video shows how relatively easy it is to remove the Console Cover Panel, and it also shows the involved LED illumination C3617 electrical connectors. Good luck! Selector Lever Knob Removal and Installation - 2011 Edge Workshop Manual.pdf Floor Shifter Illumination Wiring Connector C3617 Details - 2011 Edge workshop Manual.pdf -
Models: Ford 2015-2018 Edge 2017-2019 Escape Built on or before 16-May-2019 2017-2019 Fusion Built on or before 8-Apr-2019 Lincoln 2017-2019 MKC Built on or before 18-Apr-2019 2017-2019 MKZ Built on or before 8-Apr-2019 Summary This article supersedes TSB 22-2133 to update the Parts List. Issue: Some 2015-2018 Edge and 2017-2019 Fusion/MKZ/Escape/MKC vehicles equipped with a 2.0L EcoBoost engine may exhibit a low coolant level, white exhaust smoke and/or a runs rough condition with or without an illuminated malfunction indicator lamp (MIL). Diagnostic trouble codes (DTCs) may include P0300, P0301-P0304, P0316, P0217, P1285 and/or P1299 stored in powertrain control module (PCM). This may be due to coolant intrusion into the cylinder. To correct the condition, follow the Service Procedure to replace the long block engine assembly. Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria: • One of the following vehicles: Below is PDF dowload link for full TSB 22-2229 document, which provides Service Action parts lists for all included models... TSB 22-2229 - 2015-2018 Edge + Other Models, 2.0L EcoBoost - Coolant In Cylinders, White Exhaust Smoke And_Or Illuminated MIL.pdf
For any 2019-2020 Edge/Nautilus owners reviewing this discussion due to Sync 3 screen loss of temperature display, please see... TSB 22-2225 2019-2020 Edge & Nautilus + Other Models: SYNC 3 - Various SYNC Symptoms, SYNC Screen Flicker, Echo/Robotic Voice Concerns, Temperature Not Displayed In Pop Up Screen Good luck!
Below are PDF download links to relevant sections of the 2016 Edge Workshop Manual... Bumper Cover and Active Grille Shutter procedures are included, just in case they prove to be necessary for you. Good luck! Hood Latch - Removal and Installation - 2016 Edge Workshop Manual.pdf Front Bumper Cover - Removal and Installation - 2016 Edge Workshop Manual.pdf Active Grille Shutter - Remaoval and Installation - 2016 Edge Workshop Manual.pdf
*** THIS TSB 22-2254 HAS BEEN SUPERCEDED BY TSB 23-2307 - 2019-2020 Edge/Nautilus + Other Models - SYNC 3 - Various SYNC Symptoms, SYNC Screen Flicker, Echo/Robotic Voice Concerns, Slow/Lag Operation, BlueTooth Pairing Loss *** This bulletin supersedes 22-2225. Model: Ford 2021 Bronco Sport 2020-2021 EcoSport 2019-2020 Edge 2020-2021 Escape 2020-2021 Expedition 2020-2022 Explorer 2019-2020 F-150 2020-2021 F-Super Duty 2019-2020 Fusion 2019-2021 Mustang 2019-2021 Ranger 2019-2021 Transit Connect Lincoln 2020-2022 Aviator 2019-2020 Continental 2020-2021 Corsair 2019-2020 MKZ 2019-2020 Nautilus 2020-2021 Navigator Summary This article supersedes TSB 22-2225 to update the Service Procedure. Issue: Some 2019-2020 Edge/F-150/Fusion/Continental/MKZ/Nautilus, 2019-2021 Mustang/Ranger/Transit Connect, 2020-2021 EcoSport/Escape/Expedition/Explorer/F-Super Duty/Aviator/Corsair/Navigator, 2021 Bronco Sport and 2020-2022 Explorer/Aviator vehicles with SYNC 3 may experience various SYNC performance related concerns including but not limited to: This may be due to the SYNC Software. To correct the condition, follow the Service Procedure to update the accessory protocol interface module (APIM) software. Action: Follow the Service Procedure steps to correct the condition on vehicles that meet all of the following criteria: Special Tool(s) SYNC 3 Universal Thumb Drive Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. Labor Times Description Operation No. Time Reprogram The APIM Using The SYNC 3 Universal Thumb Drive (Do Not Use With Any Other Labor Operations) 222254A 0.3 Hrs. Repair/Claim Coding Causal Part: 14G371 Condition Code: 04 Service Procedure NOTE: For vehicles that are not currently at the dealership, the customer can also update their vehicle's SYNC 3 software via Wi-Fi or follow the instructions on www.owner.Ford.com or www.owner.Lincoln.com to update the SYNC 3 software. 1. Verify that the SYNC 3 universal thumb drive is titled SG3v202111 or later (later software levels will have a higher numerical value). Is the SYNC 3 universal thumb drive title SG3v202111 or later? (1). Yes - proceed to Step 2. (2). No - download the latest version of the SYNC 3 Universal USB Updater Application (1.0.2.3) under the Service Tips section of Professional Technician System (PTS) using at least a 32GB USB 3.0 flash drive or higher. The USB drive must be formatted to exFAT and FAT32. Review the instructions and use Scan for Updates and Update USB. Proceed to Step 2. • If needed, this is a one time upload to the thumb drive. Downloading the files to laptop and updating the thumb drive could take up to 2 1/2 hours depending on internet speed. Once the thumb drive is updated, it can be used repeatedly to update all vehicles in this article. 2. Disconnect all customer connected universal serial bus (USB) items from all media hub locations in the vehicle. 3. Start the vehicle. 4. Insert the SYNC 3 universal thumb drive into the USB port on the media hub. 5. The module automatically updates with no user input required. (1). Modules already at the latest software level indicate this after approximately 30 seconds. (2). Module programming for a non-updated module does not need to be monitored and can take approximately 20-30 minutes. (3). Once the reprograming has completed, the screen displays a message indicating the module is up to date. 6. Remove the SYNC 3 universal thumb drive when complete. The screen returns to the SYNC 3 home screen. Reconnect any of the customer USB items. No vehicle or system restarts are required. PDF download link... TSB 22-2254 - 2019-2020 Edge & Nautilus, Other Models - SYNC 3, Various SYNC Symptoms - June 28, 2022.pdf
Beginning with the odd symptom -- explanation of the 'all-dashes odometer' & Pinpoint Test G, from the 2017 Edge Workshop Manual... Good luck! Symptom: The Odometer Is Inoperative Normal Operation and Fault Conditions If the odometer count message is missing from the PCM through the GWM for 5 seconds or longer, the IPC defaults the odometer display to all dashes (------). If the odometer count message is deemed invalid by the IPC , the IPC defaults the odometer display to all dashes (------). If the NVM becomes corrupted or if any NVM failure occurs, odometer displays ERROR. Possible Sources Communication concern GWM concern PCM concern IPC PINPOINT TEST G: THE ODOMETER IS INOPERATIVE G1 CHECK FOR CORRUPTED NON-VOLATILE MEMORY (NVM) Ignition ON. Observe the message center display area. Does the odometer display ERROR? Yes VIN required to access Guided Routine (IPC) No GO to G2 G2 PERFORM THE IPC (INSTRUMENT PANEL CLUSTER) SELF-TEST Using a diagnostic scan tool, perform the IPC self-test. Are any Diagnostic Trouble Codes (DTCs) recorded? Yes REFER to DTC Chart: IPC in this section. No GO to G3 G3 CHECK THE GWM (GATEWAY MODULE A) DIAGNOSTIC TROUBLE CODES (DTCS) Using a diagnostic scan tool, check the GWM Continuous Memory Diagnostic Trouble Codes (DTCs). Are any Diagnostic Trouble Codes (DTCs) recorded? Yes REFER to: Communications Network (418-00 Module Communications Network, Diagnosis and Testing). No DIAGNOSE all PCM Diagnostic Trouble Codes (DTCs). Refer to the appropriate section in Group 303 for the procedure.
I’ve had the same pinball machine effect occur in the gauge clusters of our 2012 MKX and our 2015 MKX. The 2012 slow-cranked and started, but transitioned to no-crank a few days later. Its seven-year-old original battery tested bad. The 2015 no-cranked with a 3-month-old battery in place. Battery tested bad and was replaced under warranty. Many gauge cluster warnings are low-voltage triggered, and most codes will clear when subsequent key cycles serve up normal voltage. Have the battery tested -- probably a bad cell or bad cells. Below is a PDF download link to TSB 17-2219, relating to the park-detect switch failure which did occur in our 2012, but its symptom was limited to a "Shift To Park" gauge cluster message and it did not present any no-crank condition. Good luck! TSB 17-2219 - 2011-2017 Edge, 2011-2015 MKX, & Other Models - 'Shift To Park' Message, Park-Detect Switch .pdf
AC blower fan odd humming noise
Haz replied to Gustafa's topic in Interior, A.C., Heat, Interior Trim
The following Blower Motor Removal and Installation procedure is from the 2011 Edge Workshop Manual... Good luck! -
FordeEdge 2011 AC blower turns on and Off
Haz replied to TARiQ's topic in Interior, A.C., Heat, Interior Trim
What is this part I found in my driveway?
Haz replied to Cyberdave's topic in Brakes, Chassis & Suspension
Verging on minutia -- just in case you want to put out an old-school "Did Your Car Lose This?" sign at the curb -- it's a design used on the MX-5 Miata & lesser Mazda models, and on other brands... Good luck! -
The Edge is a fleet-ordered SEL with no additional factory options, and its 3.5L TI-VCT is zippy enough on its own. I doubt it has been tuned, since that would void warranty, and the previously owning law enforcement agency bought two successive Ford ESP extended warranty contracts on this unit. Comparing the As-Built data file, which you have, to the Edge's current-state module programming would confirm it as being stock or tuned. "Before Rockhavok" images from the auction site confirm that the Edge easily blended-in on the street, until the rear liftgate was raised... Certainly a good-find by Rockhavok. Good luck!
Exhaust system illustration from the 2013 Edge Workshop Manual, 2.0L & 3.5L typical, with part usage locations added... Good luck! -
SSM 50804 - 2013-2023 Various Vehicles - 12 Volt Battery Drain When Using Third Party PhoneApplications- Modems Activated Through FordPass Or LincolnWay Some 2013-2023 Ford or Lincoln vehicles with modems activated through FordPass or LincolnWay may experience 12 volt battery drain symptoms when the customer uses non-Ford/Lincoln phone applications as an alternate channel to access vehicle commands such as door lock/unlock, remote start, vehicle location, etc. The battery drain may be caused by excessive calls for data through the vehicle network keeping it in an activated state. Recommend that the customer uninstall the app to ensure this is not contributing to battery symptoms experienced. Advise the customer that unaffiliated third-party app developers do not work directly with Ford to adhere to security, vehicle communication, and privacy requirements. APPLICABLE VEHICLES 2020 - 2022 CAR: TV U611N AVIATOR 2021 - 2022 TRUCK: G1 U725N BRONCO 2013 - 2017 CAR: CG C344N C-MAX 2013 - 2016 CAR: B7 C344 EU C-CAR 2015 - 2017 CAR: EU C344E C-MAX MCA 2017 - 2020 CAR: PL D544N CONTINENTAL 2020 - 2022 CAR: TF CX483N CORSAIR 2021 - 2022 TRUCK: E4 ECONOLINE 2018 - 2021 CAR: BQ B515S ECOSPORT 2018 - 2019 CAR: BX B515A ECOSPORT CHINA 2018 - 2022 CAR: R6 B515E ECOSPORT 2018 - 2022 CAR: BW B515A ECOSPORT INDIA 2018 - 2019 CAR: R1 B515E ECOSPORT RUSSIA 2018 - 2020 CAR: BY B515A ECOSPORT 2015 - 2022 CAR: DQ CD539N EDGE 2014 - 2018 CAR: ED CD539A EDGE 2020 - 2022 CAR: ED CD539A EDGE 2013 - 2014 TRUCK: Q1 U387/388N EDGE/MKX 2013 - 2019 TRUCK: M2 C520N ESCAPE 2019 - 2022 CAR: TE CX482A ESCAPE/KUGA 2020 - 2022 CAR: TC CX482N ESCAPE 2013 TRUCK: M8 ESCAPE/TRIBUTE (J87) 2013 - 2019 TRUCK: UB U502N EXPLORER 2020 CAR: TZ U625A EXPLORER 2022 CAR: TZ U625A EXPLORER 2020 - 2022 CAR: TW U625N EXPLORER 2013 - 2019 TRUCK: WJ U502E EXPLORER 2013 - 2014 TRUCK: F6 F150/LINCOLN MARK LT 2015 - 2020 TRUCK: FC P552N F-150 2021 - 2022 TRUCK: FD P702N F150 2015 - 2019 TRUCK: G2 P131S SUPER DUTY 2013 - 2016 TRUCK: FA P473N SUPER DUTY 2017 - 2022 TRUCK: FE P558N SUPER DUTY 2013 - 2014 CAR: ZF S197N MUSTANG 2015 - 2022 CAR: ZG S550N MUSTANG 2016 - 2017 TRUCK: B7 U222N EXPEDITION 2018 - 2022 TRUCK: B8 U553N EXPEDITION 2020 - 2022 TRUCK: Y3 P131N STRIPPED CHASSIS 2013 - 2020 CAR: C7 CD391N FUSION 2013 - 2020 CAR: C7 CD391N FUSION 2022 CAR: FE P758N C-PICKUP 2015 - 2019 TRUCK: ME C489N MKC 2016 - 2018 CAR: D9 U540N MKX 2015 - 2020 CAR: C9 CD533N MKZ 2015 - 2020 CAR: C9 CD533N MKZ 2021 CAR: GY CX727A C-EV 2021 - 2022 CAR: GW CX727N C-EV 2020 - 2022 CAR: D9 U540N MKX 2017 TRUCK: B5 U228N NAVIGATOR 2018 - 2022 TRUCK: B9 U554N NAVIGATOR 2019 - 2022 TRUCK: FG P375N RANGER 2021 - 2022 TRUCK: RA P703A RANGER 2019 - 2022 TRUCK: KF P375S RANGER 2019 - 2022 TRUCK: KE P375E RANGER 2019 - 2021 TRUCK: KD P375A RANGER 2015 - 2022 TRUCK: TH V363N TRANSIT 2015 TRUCK: T9 V347/348E TRANSIT 2015 - 2022 TRUCK: TG V363E TRANSIT 2019 - 2022 TRUCK: TS V363E TRANSIT MCA 2021 - 2022 CAR: HC V408E TRANSIT CONNECT 2021 - 2022 CAR: HC V408E TRANSIT CONNECT 2023 TRUCK: E4 ECONOLINE 2023 TRUCK: BC H567N MEDIUM TRUCK
The C127 Connector's relative location for Hood Ajar Switch is among images in FordParts online listing for this 13A840 Wiring Harness... Good luck!
Excellent photo-find, @enigma-2. The FordParts online Hood Latch listing also includes photos that show the connector... Good luck!
The Historical Vehicle Bill of Material (HVBOM) for your Edge's VIN shows a F2GT15K867AF Parking Distance Aid wiring harness, which has been updated to Service part F2GZ15K867A... Good luck!
2019 Edge SEL AWD - Trailer lights on, Edge is off.
Haz replied to TheStuffz's topic in Cargo, Hauling, Roof Racks & Towing
SSM 50175 - 2015-2021 Edge, 2016-2018 MKX, 2019-2021 Nautilus - Parking Lamps Stay On And/Or Trailer Lights Flicker With Vehicle Turned Off Some 2015-2021 Edge, 2016-2018 MKX, and 2019-2021 Nautilus vehicles may exhibit the parking lamps stay on and/or the trailer lights flicker with vehicle turned off when a trailer is connected to the vehicle. This may be due to the software in the trailer module (TRM). To correct the condition, reprogram the TRM with the latest software of the appropriate Ford diagnostic scan tool. Use causal part 19H332 and applicable labor times from Section 10 of the Service Labor Time Standards (SLTS) Manual. APPLICABLE VEHICLES 2015 - 2021 CAR: DQ CD539N EDGE 2016 - 2021 CAR: D9 U540N MKX -
The mystery receptacle appears to be a C139 connector, associated with the front parking aid harness, which also includes a C140 connector in the vicinity of the C139. Below is the C139/C140 connectors location diagram image and PDF download links to documents providing details, including basic wiring harness designations for male/female connector applications... The FordParts website shows four iterations of the base harness descriptor 15K867 which vary by (optional) equipment installed on the vehicle, with harness website photos appearing to show C139/C140 connectors on the various harnesses. The FordParts site may provide improved search results when your Edge's VIN is added to the known attributes I used from your Forum signature. Good luck! Connector C139 Details - 2018 Edge Workshop Manual.pdf Connector C140 Details - 2018 Edge Workshop Manual.pdf
Below is a PDF download link to the 2.7L Ecoboost Engine Oil Draining and Filling procedure from the 2020 Edge Workshop Manual, which includes the following torque specification... Engine Oil Draining and Filling - 2.7L Ecoboost - 2020 Edge Workshop Manual.pdf Good luck!
Is there any connector ID number on the receptacle that you can see, or otherwise how many pins and what wire colors are on back of receptacle? Beginning a process of elimination based on adjacency of horn plug and Signature light, maybe Front Parking Aid Sensor? Compare "what plugs in here" location & wiring diagram and PDF download link to Connector C1428 Details document... Good luck! Front Outer Parking Aid Sensor Left Hand Connector C1428 Details - 2018 Edge Workshop Manual.pdf
