Haz
Everything posted by Haz
Document download link> Parasitic Battery Drain Job Aid.pdf Good luck!
From the 2012 Edge Workshop Manual... Pinpoint Test AK: The Chime Sounds When The Driver Door Is Ajar (No Key In Ignition And Headlamps Off) Refer to Wiring Diagrams Cell 60 , Instrument Panel Cluster for schematic and connector information. Normal Operation The Instrument Panel Cluster (IPC) receives the key-in-ignition warning chime command from the Body Control Module (BCM) over the High Speed Controller Area Network (HS-CAN) . The BCM monitors the door ajar input from the LH front door and the key-in-ignition switch status. On vehicles without Intelligent Access (IA) , the key-in-ignition warning switch (part of the ignition switch) is hardwired to the BCM . When the key is inserted into the ignition lock cylinder, the key-in-ignition switch closes, supplying voltage to the BCM . On vehicles with IA , the BCM monitors the ignition start/stop button and determines the ignition mode. When the ignition is in ACC, the BCM assumes a key-in-ignition state. When the BCM determines a key-in-ignition state with the LH front door open or ajar, the BCM sends the IPC a chime request message to sound the key-in-ignition warning chime. The headlamps on warning chime sounds when the LH front door is opened with the ignition OFF and the headlamp switch in the PARK or HEADLAMP ON position. The BCM receives the headlamp switch status from the Front Lighting Control Module (FLM) over the HS-CAN and the LH front door ajar status from the LH front door ajar switch through hardwired circuitry. The BCM communicates the headlamp on chime request to the IPC when the headlamps or parking lamps are on and the driver door is opened. When the BCM determines a key-in-ignition state with the LH front door open or ajar, the BCM sends the IPC a chime request message to sound the key-in-ignition warning chime. DTC B10F1:14 (Key In Switch: Circuit Short To Ground or Open) — a continuous and on-demand DTC that sets if the BCM detects an open on the key-in-ignition switch input circuit or if the BCM detects ignition start, run/start or run/acc inputs without the key-in-ignition input. This pinpoint test is intended to diagnose the following: Exterior lighting concern Interior lighting concern Vehicle may still be in factory mode Wiring, terminals or connectors Key-in-ignition warning switch (part of the ignition switch) (without IA ) BCM PINPOINT TEST AK : THE CHIME SOUNDS WHEN THE DRIVER DOOR IS AJAR (NO KEY IN IGNITION AND HEADLAMPS OFF) NOTICE: Use the correct probe adapter(s) when making measurements. Failure to use the correct probe adapter(s) may damage the connector. AK1 CHECK FOR VEHICLE OPERATION MODE Ignition ON. Observe the message center display. Does the message center display FACTORY MODE? Yes CARRY OUT the procedure to place the vehicle in normal operation mode. REFER to Disable Transport or Factory Mode in Section 419-10. No GO to AK2. AK2 CHECK THE IPC ILLUMINATION Close all doors. Wait one minute. Observe the exterior lights. Are the headlamps and parking lamps off? Yes GO to AK3. No REFER to Section 417-01. AK3 CHECK THE INTERIOR LIGHTING OPERATION Open and close the driver door. Observe the interior lamps. Do the interior lamps operate correctly from the driver door? Yes GO to AK4. No REFER to Section 417-02. AK4 RETRIEVE THE RECORDED DTCS FROM THE BCM SELF-TEST Check the recorded DTCs from the BCM self-tests. Are any DTCs present? Yes For DTC B10F1:14, GO to AK5. For all other DTCs, REFER to Section 419-10. No GO to AK7. AK5 CHECK THE BCM INPUT PIDS FROM THE IGNITION SWITCH Enter the following diagnostic mode on the scan tool: BCM DataLogger . Select and monitor the BCM ignition switch PIDs (IGN_ACC/RUN), (IGN_RUN/STRT) and (IGN_SW_STATE) while cycling the ignition switch through ACC, OFF, RUN and START states. Do the BCM PIDs match the ignition switch position? Yes GO to AK6. No REFER to Section 211-05 to diagnose the ignition switch outputs to the BCM . AK6 CHECK THE KEY-IN-IGNITION INPUT CIRCUIT FOR VOLTAGE Ignition OFF. Remove the key from the ignition cylinder. Disconnect: BCM C2280B . Measure the voltage between the BCM C2280B Pin 34, circuit CDC30 (BU/GY), harness side and ground. Is any voltage present? Yes GO to AK7. No GO to AK8. AK7 CHECK KEY-IN-IGNITION INPUT CIRCUIT FOR A SHORT TO VOLTAGE Disconnect: Ignition Switch C250. Measure the voltage between the BCM C2280B Pin 34, circuit CDC30 (BU/GY), harness side and ground. Is any voltage present? Yes REPAIR circuit CDC30 (BU/GY) for a short to voltage. TEST the system for normal operation. No INSTALL a new ignition switch. REFER to Section 211-05. TEST the system for normal operation. AK8 CHECK FOR CORRECT BCM OPERATION Disconnect all the BCM connectors. Check for: corrosion damaged pins pushed-out pins Connect all the BCM connectors and make sure they seat correctly. Operate the system and verify the concern is still present. Is the concern still present? Yes INSTALL a new BCM . REFER to Section 419-10. TEST the system for normal operation. No The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. Document download links> Ignition Lock Cylinder Housing - Removal and Installation - 2012 Edge Workshop Manual.pdf Passive Anti-Theft System (PATS) Transceiver - Removal and Installation - 2012 Edge Workshop Manual.pdf Instrument Panel — Exploded View - Removal and Installation - 2012 Edge Workshop Manual.pdf Floor Console — Exploded View - Removal and Installation - 2012 Edge Workshop Manual.pdf Steering Column Shroud — Exploded View - Removal and Installation - 2012 Edge Workshop Manual.pdf Body Control Module (BCM) to Ignition Switch Wiring Diagram - 2012 Edge.pdf BODY CONTROL MODULE (BCM) - Connector C2280B Details - 2012 Edge.pdf BODY CONTROL MODULE (BCM) - Connector C2280B Location - 2012 Edge.pdf Ignition Switch - Connector C250 Details - 2012 Edge.pdf Ignition Switch - Connector C250 Location - 2012 Edge.pdf BODY CONTROL MODULE (BCM) - Connector C2280A Details - 2012 Edge.pdf BODY CONTROL MODULE (BCM) - Connector C2280A Location - 2012 Edge.pdf BODY CONTROL MODULE (BCM) - Illustration Showing Connector Locations - 2012 Edge.pdf Good luck!
Welcome to the Forum, 2FMDK3KC5DBA79### ! From the 2013 Edge Workshop Manual... Pinpoint Test E: The Roof Opening Panel Does Not Open or Close — Sliding Glass Panel or Shades Inoperative The roof opening panel motors must be initialized whenever any of the following occur: the roof opening sliding glass panel motor has been removed. a new roof opening sliding glass panel motor has been installed. a new roof opening panel module assembly has been installed. Refer to Roof Opening Panel Motor Initialization attached .below. Refer to Roof Opening Panel Wiring Diagrams for schematic and connector information, attached .below. Normal Operation The roof opening panel uses an integrated motor and module to operate the roof opening sliding glass panel and shades. NOTE: The roof opening panel control switch operates both the power shade and the sliding glass panel. The sliding glass panel opens after the shade panels are open. The shade panels close only after the sliding glass panel is closed. NOTE: Any sliding glass opening operation first fully opens the shade panels. Before closing the shade panels, fully close or make sure the sliding glass panel is fully closed. The roof opening sliding glass panel motor receives voltage from the accessory delay relay when the ignition is in the ACC or RUN position. The roof opening sliding glass panel motor and roof opening panel shade motor also receive voltage at all times through another power circuit. Ground is supplied to the roof opening sliding glass panel motor, roof opening panel shade motor and roof opening panel switch. The roof opening panel switch supplies ground signal(s) to the sliding glass panel motor for opening and closing operations. When commanding the glass to open, the sliding glass motor either requests the shade motor to fully open the shades (if they are not already in the fully OPEN position) or the roof opening panel sliding glass moves to the OPEN position. When commanding the glass to close, the sliding glass motor closes the sliding glass panel to the safety stop position (approximately 280 mm (11.023 in) from the fully CLOSED position). Pull and hold the roof opening panel switch until the sliding glass panel has completely closed before pulling the switch again to close the shades. For information about the roof opening sliding glass panel and shade operation, refer to Roof Opening Panel attached below. The roof opening sliding glass panel motor acts as a master controller to the shade motor. The sliding glass panel motor and shade motor communicate to each other through a dedicated circuit within the roof opening panel jumper harness. The sliding glass panel motor and shade motor do not communicate to the vehicle network. This pinpoint test is intended to diagnose the following: Fuse(s) Accessory delay relay Roof opening sliding glass panel motor not initialized Roof opening panel shade motor not initialized Wiring, terminals or connectors Roof opening panel switch Roof opening panel shade motor Roof opening sliding glass panel motor PINPOINT TEST E : THE ROOF OPENING PANEL DOES NOT OPEN OR CLOSE — SLIDING GLASS PANEL OR SHADES INOPERATIVE NOTE: Use the correct probe adapter(s) from the Flex Probe Kit when making measurements. Failure to use the correct probe adapter(s) may damage the connector. E1 CHECK THE POWER WINDOWS Ignition ON. Attempt to operate the power windows. Do the power windows operate? Yes GO to E2. No REFER to Section 501-11 to diagnose the inoperative power windows (accessory delay relay circuit). E2 CHECK THE ROOF OPENING PANEL MOTOR FOR INITIALIZATION Attempt to carry out the roof opening panel motor initialization procedure. Refer to Roof Opening Panel Motor Initialization attached below. Is the concern still present, or does the roof opening panel motor fail to initialize? Yes GO to E3. No The system is operating normally at this time. The roof opening panel motor was not initialized. E3 CHECK THE ROOF OPENING PANEL SWITCH Ignition OFF. Disconnect: Roof Opening Panel Switch C9001 . Carry out the roof opening panel switch component test, attached below. Did the roof opening panel switch pass the component test? Yes GO to E4. No INSTALL a new roof opening panel switch. REFER to Roof Opening Panel Control Switch attached below. TEST the system for normal operation. E4 CHECK VOLTAGE TO THE ROOF OPENING PANEL MOTOR ASSEMBLY Disconnect: Roof Opening Panel Motor Assembly C920 . Ignition ON. Measure the voltage between roof opening panel motor assembly C920 Pin 13, circuit CBP32 (GN/VT), harness side and ground; and between C920 Pin 1, circuit SBB08 (VT/RD), harness side and ground. Are the voltages greater than 10 volts? Yes GO to E5. No VERIFY Body Control Module (BCM) fuse 32 (15A) and Battery Junction Box (BJB) fuse 8 (20A) are OK. If OK, REPAIR the circuit. TEST the system for normal operation. If not OK, REFER to the Wiring Diagrams manual to identify the possible causes of the circuit short. REPAIR the circuit. TEST the system for normal operation. E5 CHECK THE ROOF OPENING PANEL MOTOR ASSEMBLY GROUND Ignition OFF. Measure the resistance between roof opening panel motor assembly C920 Pin 8, circuit GD133 (BK), harness side and ground. Is the resistance less than 5 ohms? Yes GO to E6. No REPAIR the circuit. TEST the system for normal operation. E6 CHECK THE ROOF OPENING PANEL SWITCH GROUND FOR AN OPEN CIRCUIT Connect: Roof Opening Panel Motor Assembly C920 . Measure the resistance between roof opening panel switch C9001 Pin 2, circuit CPR39 (VT/WH), harness side and ground. Is the resistance less than 5 ohms? Yes GO to E7. No REPAIR the circuit. TEST the system for normal operation. E7 CHECK THE ROOF OPENING PANEL SWITCH CIRCUITS FOR A SHORT TO GROUND Disconnect: Roof Opening Panel Motor Assembly C920 . Using the following table, measure the resistance between roof opening panel motor assembly C920, harness side and ground: Roof Opening Panel Motor Assembly Ground C920 Pin 2, circuit CPR31 (VT/BN) Ground C920 Pin 4, circuit CPR40 (YE/OG) Ground C920 Pin 6, circuit CPR38 (WH/BU) Ground Are the resistances greater than 10,000 ohms? Yes GO to E8. No REPAIR the circuit(s) in question. TEST the system for normal operation. E8 CHECK THE ROOF OPENING PANEL SWITCH CIRCUITS FOR AN OPEN Measure the resistance between roof opening panel switch C9001, harness side and roof opening panel motor assembly C920, harness side using the following table: Roof Opening Panel Switch Circuit Roof Opening Panel Motor Assembly C9001 Pin 3 CPR40 (YE/OG) C920 Pin 4 C9001 Pin 4 CPR31 (VT/BN) C920 Pin 2 C9001 Pin 6 CPR38 (WH/BU) C920 Pin 6 Are the resistances less than 5 ohms? Yes GO to E9. No REPAIR the circuit(s) in question. TEST the system for normal operation. E9 CHECK THE ROOF OPENING PANEL MOTOR WIRING HARNESS Using the following table, check the roof opening panel motor wiring harness for loose pins, an open or a short between roof opening panel motor assembly C920 component side and the roof opening panel sliding glass motor harness connector: Roof Opening Panel Motor Assembly Roof Opening Panel Sliding Glass Motor Harness Connector C920 Pin 1, circuit SBB08 Roof opening panel sliding glass motor harness connector circuit SBB08 C920 Pin 13, circuit CBP41 Roof opening panel sliding glass motor harness connector circuit CBP41 C920 Pin 8, circuit GD133 Roof opening panel sliding glass motor harness connector circuit GD133 C920 Pin 2, circuit CPR31 Roof opening panel sliding glass motor harness connector circuit CPR31 C920 Pin 6, circuit CPR38 Roof opening panel sliding glass motor harness connector circuit CPR38 C920 Pin 4, circuit CPR40 Roof opening panel sliding glass motor harness connector circuit CPR40 Is the roof opening panel motor wiring harness OK? Yes GO to E10. No INSTALL a new roof opening panel motor wiring harness. REFER to Roof Opening Panel Motor Wiring Harness attached below. INITIALIZE the roof opening panel motor. REFER to Roof Opening Panel Motor Initialization attached below. TEST the system for normal operation. E10 CHECK THE ROOF OPENING PANEL MOTOR ASSEMBLY FOR CORRECT OPERATION Disconnect all roof opening panel motor connectors (sliding glass motor and shade motor). Check for: corrosion. bent or pushed-out pins. Connect all roof opening panel motor connectors and make sure they seat correctly. Operate the system and verify the concern is still present. Is the concern still present? Yes INSTALL a new roof opening sliding glass panel motor. REFER to Roof Opening Panel Motor — Sliding Front Panel attached below. INITIALIZE the roof opening panel motor. REFER to Roof Opening Panel Motor Initialization in this section. TEST the system for normal operation. If the concern is still present, INSTALL a new roof opening panel shade motor. REFER to Roof Opening Panel Motor — Shade attached below. INITIALIZE the roof opening panel motor. REFER to Roof Opening Panel Motor Initialization attached below. TEST the system for normal operation. No The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. TEST the system for normal operation. Document download links> Roof Opening Panel - Description and Operation - 2013 Edge Workshop Manual.pdf Roof Opening Panel - Wiring Diagram 1 - 2013 Edge.pdf Roof Opening Panel - Wiring Diagram 2 - 2013 Edge.pdf Roof Opening Panel Motor Initialization - General Procedures - 2013 Edge Workshop Manual.pdf Console — Overhead - Removal and Installation - 2013 Edge Workshop Manual.pdf ROOF OPENING PANEL SWITCH - Component Testing Procedure - 2013 Edge.pdf ROOF OPENING PANEL SWITCH - Connector C9001 Details - 2013 Edge.pdf ROOF OPENING PANEL SWITCH - Connector C9001 Location - 2013 Edge.pdf ROOF OPENING PANEL MOTOR ASSEMBLY - Connector C920 Details - 2013 Edge.pdf ROOF OPENING PANEL MOTOR ASSEMBLY - Connector C920 Location - 2013 Edge.pdf Roof Opening Panel Motor Wiring Harness - Removal and Installation - 2013 Edge Workshop Manual.pdf Roof Opening Panel Motor — Sliding Front Panel - Removal and Installation - 2013 Edge Workshop Manual.pdf Roof Opening Panel Motor — Shade - Removal and Installation - 2013 Edge Workshop Manual.pdf Good luck!
2018 Edge Audio Control Module - No sound
Haz replied to al303's topic in Audio, Backup, Navigation & SYNC
Additional document download links> AUDIO FRONT CONTROL MODULE (ACM) - Connector C240B Location - 2018 Edge w Sony.pdf Audio Front Control Module (ACM) to Audio Digital Signal Processing (DSP) Module - Inline Connector C210 Location - 2018 Edge w Sony.pdf AUDIO DIGITAL SIGNAL PROCESSING (DSP) MODULE - Connector C4362A-B-C Location - 2018 Edge w Sony.pdf Good luck! -
Because you have a record of the modules exhibiting DTCs in your Forscan screen capture(s), I would try performing a Clear All Codes, followed by performing Self Test routines on all modules for which Forscan previously indicated DTCs. From my perspective, the outcome of the Self Tests will indicate fault states currently existing, versus those previously shown which were historical, but are not currently faulted -- if that makes any sense. My hope would be that the DSP's DTC-indicated fault that is capable of blocking speaker audio may be historical, and clearing the DTC may restore the speaker audio -- but I may be wrong. Initially clearing all DTCs and performing the Self Tests is easier/quicker than the disassembly needed to access & perform Pinpoint Test F's circuits/connectors volt/ohm evaluations. If this B13FB:11 DTC reoccurs, there is Pinpoint Test F for you -- or a dealership technician -- to perform... PINPOINT TEST F: NO SOUND FROM ALL SPEAKERS F1 VERIFY THAT THE ACM (AUDIO FRONT CONTROL MODULE) AND AUDIO DSP (AUDIO DIGITAL SIGNAL PROCESSING MODULE) MODULE PASS THE NETWORK TEST Using a diagnostic scan tool, perform the network test. Did the ACM and audio DSP module pass the network test? Yes GO to F2 No REFER to: Communications Network (418-00 Module Communications Network, Diagnosis and Testing). F2 CHECK FOR SPEAKER DIAGNOSTIC TROUBLE CODES (DTCS) Ignition ON. Using a diagnostic scan tool, perform the audio DSP module self-test. Are any speaker fault Diagnostic Trouble Codes (DTCs) present? Yes REFER to the DSP DTC Chart ABOVE. No GO to F3 F3 CHECK THE ENABLE CIRCUIT FUNCTIONALITY BY CHECKING THE AUDIBLE PROMPT FUNCTIONALITY Operate the audio system in AM / FM mode. Operate the VOICE steering wheel switch and listen for the SYNC® audible prompt. Does the SYNC® system produce an audible prompt correctly; indicating voice recognition mode has been entered? Yes GO to F4 No GO to F5 F4 CHECK FOR AN AUDIO SIGNAL TO THE AUDIO DSP (AUDIO DIGITAL SIGNAL PROCESSING MODULE) MODULE NOTICE: This pinpoint test step directs testing circuits using a back-probe method. Use the special back-probe tool POM6411. Do not force test leads or other probes into connectors. Adequate care must be exercised to avoid connector terminal damage, while ensuring that good electrical contact is made with the circuit or terminal. Failure to follow these instructions may cause damage to wiring, terminals, or connectors, and may cause subsequent electrical faults. Ignition ON. Operate the audio system in AM / FM mode. While back-probing audio DSP module C4326A, measure the AC voltage. Positive Lead Measurement / Action Negative Lead C4326A Pin 7 C4326A Pin 17 Is a fluctuating AC voltage present? Yes GO to F10 No GO to F9 F5 CHECK THE AUDIO DSP (AUDIO DIGITAL SIGNAL PROCESSING MODULE) MODULE ENABLE CIRCUIT FOR CORRECT VOLTAGE NOTICE: This pinpoint test step directs testing circuits using a back-probe method. Use the special back-probe tool POM6411. Do not force test leads or other probes into connectors. Adequate care must be exercised to avoid connector terminal damage, while ensuring that good electrical contact is made with the circuit or terminal. Failure to follow these instructions may cause damage to wiring, terminals, or connectors, and may cause subsequent electrical faults. While back-probing audio DSP module C4326A, measure the DC voltage. Positive Lead Measurement / Action Negative Lead C4326A Pin 3 Ground Is the voltage between 3.5 and 8.5 volts? Yes GO to F10 No GO to F6 F6 CHECK THE AUDIO DSP (AUDIO DIGITAL SIGNAL PROCESSING MODULE) MODULE ENABLE CIRCUIT FOR A SHORT TO VOLTAGE Ignition OFF. Disconnect: Audio DSP Module C4326A. Disconnect: ACM C240B. Ignition ON. Measure: Positive Lead Measurement / Action Negative Lead C4326A Pin 3 Ground Is any voltage present? Yes REPAIR the circuit. No GO to F7 F7 CHECK THE AUDIO DSP (AUDIO DIGITAL SIGNAL PROCESSING MODULE) MODULE ENABLE CIRCUIT FOR A SHORT TO GROUND Ignition OFF. Measure: Positive Lead Measurement / Action Negative Lead C4326A Pin 3 Ground Is the resistance greater than 10,000 ohms? Yes GO to F8 No REPAIR the circuit. F8 CHECK THE AUDIO DSP (AUDIO DIGITAL SIGNAL PROCESSING MODULE) MODULE ENABLE CIRCUIT FOR AN OPEN Measure: Positive Lead Measurement / Action Negative Lead C4326A Pin 3 C240B Pin 18 Is the resistance less than 3 ohms? Yes GO to F9 No REPAIR the circuit. F9 CHECK FOR CORRECT ACM (AUDIO FRONT CONTROL MODULE) OPERATION Ignition OFF. Disconnect and inspect all the ACM connectors and related in-line connectors. Repair: corrosion (clean module pins or install new connectors or terminals) damaged or bent pins (install new terminals or pins) pushed-out pins (install new pins as necessary) Reconnect the ACM connectors and related in-line connectors. Make sure they seat and latch correctly. Operate the system and determine if the concern is still present. Is the concern still present? Yes CHECK OASIS for any applicable Technical Service Bulletins (TSBs). If a TSB exists for this concern, discontinue this test and follow TSB instructions. If no Technical Service Bulletins (TSBs) address this concern, INSTALL a new ACM . REFER to: Audio Front Control Module (ACM) (415-00C Information and Entertainment System - General Information - Vehicles With: Sony Audio System, Removal and Installation). No The system is operating correctly at this time. The concern may have been caused by module connections. ADDRESS the root cause of any connector or pin issues. F10 CHECK FOR CORRECT AUDIO DSP (AUDIO DIGITAL SIGNAL PROCESSING MODULE) MODULE OPERATION Ignition OFF. Disconnect and inspect all the audio DSP module connectors and related in-line connectors. Repair: corrosion (clean module pins or install new connectors or terminals) damaged or bent pins (install new terminals or pins) pushed-out pins (install new pins as necessary) Reconnect the audio DSP module connectors and related in-line connectors. Make sure they seat and latch correctly. Operate the system and determine if the concern is still present. Is the concern still present? Yes CHECK OASIS for any applicable Technical Service Bulletins (TSBs). If a TSB exists for this concern, discontinue this test and follow TSB instructions. If no Technical Service Bulletins (TSBs) address this concern, INSTALL a new audio DSP module. REFER to: Audio Digital Signal Processing (DSP) Module (415-00C Information and Entertainment System - General Information - Vehicles With: Sony Audio System, Removal and Installation). No The system is operating correctly at this time. The concern may have been caused by module connections. ADDRESS the root cause of any connector or pin issues. Below, and in an immediately following post due to Forum attachment limitations, are download links to wiring diagrams, connector information, and module access procedures in support of Pinpoint Test F efforts... Document download links> Front Controls Interface Module (FCIM) - Removal and Installation - 2018 Edge Workshop Manual.pdf Front Display Interface Module (FDIM) - Removal and Installation - 2018 Edge Workshop Manual.pdf Audio Front Control Module (ACM) - Removal and Installation - 2018 Edge Workshop Manual.pdf Loadspace Trim Panel - Removal and Installation - 2018 Edge Workshop Manual.pdf Audio Front Control Module (ACM) to Audio Digital Signal Processing (DSP) Module Wiring Diagram - 2018 Edge w Sony.pdf AUDIO DIGITAL SIGNAL PROCESSING (DSP) MODULE - Power Distribution Wiring Diagram - 2018 Edge w Sony.pdf AUDIO DIGITAL SIGNAL PROCESSING (DSP) MODULE to Speakers - Wiring Diagram 1 - 2018 Edge w Sony.pdf AUDIO DIGITAL SIGNAL PROCESSING (DSP) MODULE to Speakers - Wiring Diagram 2 - 2018 Edge w Sony.pdf AUDIO DIGITAL SIGNAL PROCESSING (DSP) MODULE to Speakers - Wiring Diagram 3 - 2018 Edge w Sony.pdf DSP-ACM-APIM - Wiring Diagram - 2018 Edge w Sony.pdf Audio Front Control Module (ACM) to Audio Digital Signal Processing (DSP) Module - Inline Connector C210 Details - 2018 Edge w Sony.pdf Audio Front Control Module (ACM) to Audio Digital Signal Processing (DSP) Module - Inline Connector C210 Location - 2018 Edge w Sony.pdf AUDIO DIGITAL SIGNAL PROCESSING (DSP) MODULE - Connector C4362A Details - 2018 Edge w Sony.pdf AUDIO DIGITAL SIGNAL PROCESSING (DSP) MODULE - Connector C4362B Details - 2018 Edge w Sony.pdf AUDIO DIGITAL SIGNAL PROCESSING (DSP) MODULE - Connector C4362C Details - 2018 Edge w Sony.pdf AUDIO FRONT CONTROL MODULE (ACM) - Connector C240B Details - 2018 Edge w Sony.pdf -
Al: Have you scanned your Edge for Diagnostic Trouble Codes (DTCs) ? From the System Operation and Component Description document... Digital Signal Processor (DSP) The audio system provides theater quality sound in the vehicle. Audio signals are sent from the ACM and APIM to the DSP module. The DSP module processes the audio signals and sends them to the speakers. Additionally, from the 2018 Edge Workshop Manual, relating to: No Sound From All Speakers Normal Operation and Fault Conditions When the ignition status message from the BCM indicates that the engine is cranking, the ACM mutes the audio output. If the audio DSP module detects an open, short to ground, or less than 3.5 volts on the enable circuit, the speaker output will be muted for all of the speakers. A short to ground or short to voltage in the circuitry to one of the speakers may cause multiple speakers to lose sound due to the built-in overload protection feature of the audio DSP module. In this case, a speaker fault DTC sets. DTC Fault Trigger Conditions DTC Description Fault Trigger Conditions DTC Type B1142:27 Ignition Status 1: Signal Rate of Change Above Threshold Set by the ACM when an error is detected in the ignition status message from the BCM during engine start. Continuous B13FB:11 Audio Enable Line: Circuit Short To Ground Set by the audio DSP module when a short to ground is detected on the enable circuit Continuous Possible Sources Wiring, terminals, or connectors ACM Audio DSP module I can provide diagnostic Pinpoint Test 'F' if either of the above DTCs are present in the ACM or DSP modules. Good luck! Document download link> Audio Digital Signal Processing (DSP) Module - Removal and Installation - 2018 Edge Workshop Manual.pdf -
Al: Have you tried using the Bezel Diagnostics procedure? Your Edge's HVBoM shows originally fit unit as FT4T19C107HE. As-Built data for your Edge's ACM shows as... 727-01-01 10A0 F000 00D0 727-01-02 0000 31 727-02-01 5B8C 727-03-01 3C6E 727-04-01 0001 0155 53DD Document download links> Bezel Diagnostics - General Procedures - 2018 Edge Workshop Manual.pdf Information and Entertainment System - System Operation and Component Description - 2018 Edge Workshop Manual.pdf Module Configuration - System Operation and Component Description - 2018 Edge Workshop Manual.pdf Good luck! -
To supplement dabangsta's findings, I pulled Historical Vehicle Bill of Material (HVBoM) reports on 2022 & 2024 ST Performance Brake Package Edges and both confirm the Ford and Motorcraft part numbers... Similarly, those same part numbers are reflected on the FordParts website in reply to the same 2022 & 2024 ST Performance Brake Package Edge VINs... Document download links> Cooling Fan Motor and Shroud - Removal and Installation - 2.7L EcoBoost - 2022-2024 Edge Workshop Manual.pdf Cooling Module - Removal and Installation - 2.7L EcoBoost - 2022-2024 Edge Workshop Manual.pdf Good luck!
SSM 52231 - 2024 Nautilus - Audio Settings And Presets Will Not Save Some 2024 Nautilus vehicles may exhibit concerns with the last audio settings or audio presets not saving, audio system defaulting to AM radio, or memory seat settings not being retained. This may be due to the customer using a guest profile or inadvertently switching to a guest profile. Memory seat, audio presets, or last audio settings will not be retained when using a guest profile. Customers must set up a personnel profile and link the key fob and seat memory to a profile for these features/settings to remain in memory. Refer to the Personal Profiles section of the Owner Manual for further information. Customers may also be referred to the Lincoln YouTube Channel or Lincoln owners website for additional videos and information on how to use the features on their vehicle including how to set up a personal profile. The referred-to Owner's Manual section...
How to turn radio off and back on..
Haz replied to Termin8r's topic in Audio, Backup, Navigation & SYNC
Our 2015 MKX's comparatively Stone Age SYNC 2 system reacts to "Radio Off" and Radio On", though beginning the phrase with "Turn" confuses SYNC 2. SYNC 4A is described as having Enhanced Voice Recognition, and being more capable with conversational expressions, so I expect that "Turn Radio Off" & "Turn Radio On" should be effective commands. Good luck! SYNC 4A with Enhanced Voice Recognition 2021 Edge Availability SE SEL ST‑Line Titanium SYNC 4A with Enhanced Voice Recognition S S S S SYNC 4A with Enhanced Voice Recognition is a one-stop shop for most of the vehicle controls, including applications, settings and climate controls. The SYNC 4A touchscreen offers a unique layout and larger font size for readability. Status bar: Now supports up to six buttons and five icons Buttons include: Home, Settings, Camera, Android Auto™ or Apple CarPlay® (if activated), Alexa Built-in, Ford Power-Up software updates and Personal Profiles (if equipped). Certain buttons can be customized Icons include: Charging (if applicable), TA (traffic announcement), Wi-Fi, location sharing, phone signal strength, temperature and time Active screen: Displays the current feature in use, with Dash Cards below. A smaller version of Dash Cards now display up to six recently used apps that function as quick links. Swipe up or tap to launch a card into the active area and swipe down to close it Lower tray: Climate controls are always available here on-screen, along with audio volume/On/Off knob (if equipped). Pressing on temperature, fan or heated seat icons now enable the volume knob for quick level control, instead of sliders Touchscreen features accessed on the Status Bar: Applications drawer: Pressing the Home button brings up two tabs: Apps include both factory installed and third-party apps, as a phone is paired Entertainment includes games and music available for stationary times, like charging NOTE: Charging, Towing, Intelligent Backup Power, Zone Lighting and Pro Power Onboard are now native apps Settings drawer: The Toggle button now brings up a consolidated view for quicker access: Controls, at the top of the menu, opens first by default when the drawer is open; Drive Modes, Camera and Seats are located here Settings, such as Sound, Phone List and Driver Assistance, can be accessed on the left menu Profiles drawer: Pressing the Personal Profiles button (if equipped) now brings up a dedicated drawer to see them and set up a new one Owners will appreciate cordless smartphone pairing, SiriusXM with 360L availability and Alexa Built-In compatibility. Up to 12 smartphones can be paired, but only two phones can be connected to Bluetooth® at the same time. Two phones cannot call or conference simultaneously The Ford Assistant allows owners to use conversational voice commands to talk to the vehicle and ask questions more like Siri or Alexa Ford Sketch allows owners to draw, erase, clear, save and use different brush sizes directly on their SYNC 4A touchscreen They can also play tic-tac-toe and use a calculator with this feature (Mustang Mach-E only) SYNC 4 Technology also carries over base embedded voice capability from SYNC 3, with the addition of a “wake word,” natural language understanding and one-shot Navigation search. The following embedded features are available regardless of whether a cloud connection is available in the vehicle: Phone controls, such as email message read and reply Navigation (with an active subscription) options, such as one-box search from main menu for addresses, Points of Interest (POI) and intersections Radio/media operation Climate features SYNC AppLink controls The embedded voice allows the owner to use a “wake word” to talk to the vehicle. The wake word is turned Off by default but can be turned On in Settings. Go to Settings > Voice Control > Listen for Wake Word “OK, Ford” is the default wake word. Other options include “OK, FordPass,” “OK, Ford SYNC” or “Hello, Ford” A short press of the Push-to-Talk (PTT) button on the steering wheel can be used instead of the wake word. A long press of the PTT button will alert Android Auto or Apple CarPlay, if they are connected Penny Games: When the vehicle is stationary, owners will be able to entertain themselves with casual, quick to play games, including Sudoku, Doublesum, Jigsaw Puzzles, Lane Change and more Using SYNC 4 Technology, owners can simultaneously connect two phones through Bluetooth. They can alternate between the two phones to call, answer, email and text. Either phone can be enabled to speak commands, stream media and use Android Auto/Apple CarPlay NOTE: The Dual Phone feature does not allow the connection/conference of two calls from both phones. -
From the 2012 Workshop Manual... Pinpoint Test D - DTC P0625 or P0626 [Introduction - Full procedure is linked below] Refer to Wiring Diagrams Cell 12 , Charging System for schematic and connector information [Pictured here and also linked below]... Normal Operation [Emphasis added] The PCM monitors the generator output via the generator monitor (GENMON) circuit. If the PCM cannot read the GENMON circuit due to an open or short to ground, when the engine rises above approximately 2,000 rpm, the generator defaults to a steady voltage of approximately 13.5 volts and the PCM sends a request to the Instrument Panel Cluster (IPC) to illuminate the charging system warning indicator. A GENMON duty cycle of 3% or less indicates a short to ground fault is present and results in DTC P0625 setting in the PCM. A GENMON duty cycle of 98% or more indicates an open or short to voltage fault is present and results in DTC P0626 setting in the PCM. DTC P0625 (Generator Field Terminal Circuit Low) — The PCM sets this DTC if the GENMON circuit is shorted to ground, the "A" sense circuit is open or the B+ circuit is open. This DTC also sets by a faulted PCM or generator. DTC P0626 (Generator Field Terminal Circuit High) — The PCM sets this DTC if the GENMON circuit is open or shorted to power. This DTC can also be set by a faulted PCM or generator. This pinpoint test is intended to diagnose the following: Fuse Wiring, terminals or connectors Radial arm adapter Engine, generator and battery grounds Battery Generator PCM Relevant wiring and connector information & Workshop Manual sections are linked immediately below. Document download links> Pinpoint Test D For DTC P0625 or P0626 - Diagnosis and Testing - 2012 Edge Workshop Manual.pdf Charging System Wiring Diagram - 2012 Edge.pdf Generator - Connector C102A Details - 2012 Edge.pdf Generator - Connectors C102A & C102B Location - 2012 Edge.pdf Powertrain Control Module (PCM) - Connector C175B Details - 2012 Edge.pdf Powertrain Control Module (PCM) - Connector C175B Location - 2012 Edge.pdf Charging System Principles of Operation - Diagnosis and Testing - 2012 Edge Workshop Manual.pdf Good luck!
Dead battery causing stereo issues
Haz replied to Anthony_a2's topic in Audio, Backup, Navigation & SYNC
Welcome to the Forum, Anthony_a2 ! Diagnostic Trouble Codes (DTCs) may be present that can guide corrective efforts. Try performing the Audio Control Module (ACM) Self-Diagnostic procedure, also known as Bezel Diagnostics. From the 2010 Edge Workshop Manual... Audio Systems With Navigation Turn the ACM on. Operate the audio system in radio tuner (AM/FM) mode. Press and hold preset buttons 3 and 6 for 3 seconds until the speaker walk test begins. The display indicates each speaker as it is tested. NOTE: If the speaker walk test is the only test required, this procedure can be stopped after this step, or by allowing the speaker walk test to complete on its own. Before the speaker walk test is complete, press the "End Test" selection. The following tests are available through the "BEZEL DIAGNOSTICS" menu: Display Selection Diagnostic Function Description On Demand Self Test The ACM carries out a self-test. At the end of the self-test, the display either indicates "Test Passed" or lists any DTCs present. Note that the self-test may not indicate all DTCs that are present. If DTCs are suspected, retrieve continuous and on-demand DTCs using the scan tool. View DTCs The ACM displays any DTCs that are present. If there is more than a full screen of DTCs present, to scroll through the DTCs, press the down arrow on the display. If no DTCs are present, the display reads NO DTCS. Press the "Clear DTCs" selection to clear any DTCs present. Configuration Status The display shows the ACM configuration. A "0" indicates the item is configured off, while a "1" indicates the item is configured on. If the ACM appears to be misconfigured, refer to Section 418-01. System Info The ACM displays system information for various components of the audio system. The following items are most important for servicing the audio system: Nav Radio Part Number — provides the ACM part number ESN1 — provides the satellite radio Electronic Serial Number (ESN) GPS Info The current Global Positioning System (GPS) satellite information is shown, along with the current vehicle position. Pressing the "SV Status" selection provides additional information, if present. Speaker Walk Test The ACM carries out the speaker walk test. DVD Mechanism Test The ACM tests the internal CD/DVD drive mechanism. Display Test This test provides for testing of the touchscreen colors and the touchscreen sectors. Pressing any of the colors on the display causes the whole display to change to that color; pressing the display again returns to the Display Test menu. Pressing the "Touchscreen Activation Test" selection enters the touchscreen sector test. Press any area of the screen to test the touchscreen sector; press the "X" at the RH lower corner of the display to return to the Display Test menu. Hardkey Test This test provides for testing of the ACM buttons (not the touchscreen). When each button is pressed, the screen displays the button that is active. This test can also be used to isolate a stuck button. Radio Signal Strength The ACM displays the AM/FM antenna signal strength. To run this test, the audio system should be in AM radio tuner mode before entering the ACM self-diagnostic mode. HDD Test The ACM tests its internal hard drive. Sensor I/O Status The ACM displays inputs it is receiving from external sources. These inputs include: Ignition — indicates ON (ignition in ACC or RUN) or OFF Brake — indicates ON (brake applied) or OFF (brake not applied) Illumination — indicates ON or OFF ReverseGear — indicates ON (vehicle in reverse) or OFF (vehicle not in reverse) Microphone Test The ACM tests the microphone by supplying a test tone and monitoring the input from the microphone. As this vehicle is not equipped with a microphone, this test does not provide any diagnostic assistance. SDARS Signal Strength The ACM displays the satellite radio antenna signal strength. To exit the self-diagnostic mode, press the "Exit Diagnostics" selection from the "BEZEL DIAGNOSTICS" menu. Please report back on the outcome, and then we'll determine if additional diagnostic procedures are necessary. Good luck!- 1 reply
- 2
The audio system not powering-off via spoken SYNC command is an added symptom that dealership Service staff will explore, along with any related DTCs, if they exist. The issue may involve corrupted software or a faulty module, apart from the audio control panel. Online resources show your Edge's various SYNC & APIM software are up-to-date, but the dealership tech will connect your Edge to Ford's online Service systems to verify that, as well as to perform other diagnostic procedures comparable to Pinpoint Test J. Establishing a relationship with a local dealer's Service department is a useful thing, especially if they participate in Ford's Pickup & Delivery Service. As MLTEdge describes, absent overt physical damage, correcting this issue will very likely occur at no cost to you. I can't speak to the Power pushbutton's depth of travel, if it is other-than a momentary contact control -- perhaps another GEN 2 Edge owner will clarify that. Good luck! -
Steering Wheel Control Wires for aftermarket Android head unit
Haz replied to BraddB's topic in 2013 Edge & MKX
Based upon this description from the 2013 Edge Workshop Manual... Steering Wheel Controls The steering wheel controls are mounted directly to the steering wheel and wired to the Steering Column Control Module (SCCM) . Depending on what features the vehicle is equipped with, the SCCM sends messages via the High Speed Controller Area Network (HS-CAN) to the PCM (cruise control) and the Instrument Panel Cluster (IPC) (message center and entertainment system). The IPC receives the SCCM entertainment system messages via the HS-CAN and then sends them to the applicable entertainment system module(s) along the Infotainment Controller Area Network (I-CAN) . ...and this Front Control/Display Interface Module (FCDIM) - wiring diagram... Your Edge's main plug may be the FCDIM Connector C2123... If so, then your Aftermarket Head's two wires may find their rightful places on Pin 4 and Pin 5... Document download links> FRONT CONTROL DISPLAY INTERFACE MODULE (FCDIM) - Wiring Diagram - 2018 Edge.pdf FRONT CONTROL DISPLAY INTERFACE MODULE (FCDIM) - Connector C2123 Location - 2018 Edge.pdf FRONT CONTROL DISPLAY INTERFACE MODULE (FCDIM) - Connector C2123 Details - 2018 Edge.pdf Steering Wheel Switch, Right - Wiring Diagram without SYNC - 2013 Edge.pdf Steering Wheel Switch, Right - Connector C2999 Location - 2013 Edge.pdf Steering Wheel Switch, Right - Connector C2999 Details - 2013 Edge.pdf Good luck! -
Additional document download links> Charging System - 2.0L EcoBoost - Diagnosis and Testing - 2018 Edge Workshop Manual.pdf Pinpoint Test AJ - THE CHARGING SYSTEM RTT WARNING INDICATOR IS NEVER OR ALWAYS ON - 2018 Edge Workshop Manual.pdf Good luck!
Relating to the Battery Monitoring System (BMS) reset method and effects, this from the 2018 Edge Workshop Manual... If the vehicle battery is replaced, it is very important to perform the BMS Reset using a diagnostic scan tool. This reset is reserved for new battery installation. Resetting the battery monitoring system will clear the learned battery data, the battery time in service, and will affect the aging algorithm parameters, which have been learned since the installation of the battery. If the battery monitoring system reset is not carried out, it holds the old battery parameters and time in service counter in memory. Additionally it tells the system the battery is in an aged state and may limit the Electrical Energy Management system functions. So, use of a diagnostic scan tool (including Forscan and other scanning apps) is the only way to perform a BMS reset. The 8-hours is involved in the Body Control Module (BCM) validly tracking the battery's State of Charge, this from the 2018 Edge Workshop Manual... The BCM uses the battery current sensor (without auto-start-stop) or battery monitoring sensor (with auto-start-stop) to keep track of the battery state of charge. During a drive cycle the Electrical Energy Management software adjusts the battery state of charge up during charging, and down during discharge. During rest periods with the key off, and the vehicle enters sleep mode, the BCM automatically recalibrates the Battery State of Charge. It takes 8 hours in sleep mode, with the vehicle undisturbed, no doors opened or keyless entry buttons pressed, and the total vehicle current draw less than 300mA, to calibrate the battery state of charge to a high accuracy. If the system draw has not allowed the battery state of charge to calibrate over the previous 7 days, the state of charge quality factor changes to identify this and some Electrical Energy Management system functions may be temporarily turned off until a calibration takes place. This vehicle is equipped with an Electrical Energy Management system which manages battery charging and monitors the battery state of charge. The Electrical Energy Management system software is housed in the BCM . It has the algorithms and control structure for the Smart Regenerative Charging, and Load Shed Control Strategy. The Electrical Energy Management system is equipped with a battery current sensor (without auto-start-stop), or a battery monitoring sensor (with auto-start-stop) and generator current sensor to monitor the battery. These sensors serve as input to the Electrical Energy Management system software. If the sensors malfunction due to wiring issues or failure, a DTC will be set. In most cases the Electrical Energy Management system functions will be turned off until the sensor operation is restored. So, while the 8-hours in sleep mode doesn't perform a BMS reset, it is comparably important. Relating to the CHECK CHARGING SYSTEM message and/or the charging system warning indicator, this from the 2018 Edge Workshop Manual... The PCM reports any charging system faults and sends a message through the High Speed Controller Area Network (HS-CAN) to the BCM . The BCM controls the charging system warning indicator by sending a message over the Medium Speed Controller Area Network (MS-CAN) to the IPC . The IPC then controls charging system warning indication based on the message from the PCM through the BCM . The status of the PCM charging system warning indicator and/or message is confirmed by viewing PCM PID generator fault indicator lamp (GENFIL). Any charging system fault detected by the PCM results in 1 or more Diagnostic Trouble Codes (DTCs) being set and the PID GENFIL having a status of On. If equipped with a charging system warning indicator, the IPC turns the indicator on or off. If equipped with a message center, the IPC displays a CHECK CHARGING SYSTEM message. In some instances, the CHECK CHARGING SYSTEM message may not display if the ignition is on and the engine is off. Under certain circumstances, the charging system may have a concern but will still keep the battery charged and the vehicle running. GENCOM normally initiates charging but with a fault in this circuit, the generator can self-excite and start charging on its own. The charging system warning indicator is illuminated and/or the CHECK CHARGING SYSTEM message is displayed, and the generator operates in a default mode (approximately 13.5 volts). The Charging System RTT Warning Indicator Is Never Or Always On Normal Operation and Fault Conditions See Charging System RTT indicator. REFER to: Message Center - System Operation and Component Description (413-01 Instrumentation, Message Center and Warning Chimes, Description and Operation). If the charging system indication request is missing for less than 5 seconds, the IPC defaults the charging system RTT indicator to the last indication state (on or off), based upon on the last message received. If the charging system indication request is missing for 5 seconds or longer, the IPC defaults the charging system RTT indicator on. Possible Sources Charging system concern Communication concern GWM concern IPC PINPOINT TEST AJ: THE CHARGING SYSTEM RTT (RECONFIGURABLE TELLTALE) WARNING INDICATOR IS NEVER OR ALWAYS ON AJ1 CHECK THE MESSAGE CENTER OPERATION Ignition ON. Close all doors, the hood and the liftgate. Clear all message center warnings by pressing the OK button for each warning present. Monitor the door ajar RTT warning indicator. Open the driver door. Clear the message center popup warning. Monitor the door ajar RTT warning indicator. Is the door ajar RTT warning indicator off with the door closed, and on with the door open? Yes GO to AJ2 No VIN required to access Guided Routine (IPC) AJ2 PERFORM THE IPC (INSTRUMENT PANEL CLUSTER) SELF-TEST Using a diagnostic scan tool, perform the IPC self-test. Are any Diagnostic Trouble Codes (DTCs) recorded? Yes REFER to DTC Chart: IPC in this section. No GO to AJ3 AJ3 CHECK THE GWM (GATEWAY MODULE A) DIAGNOSTIC TROUBLE CODES (DTCS) Using a diagnostic scan tool, check the GWM Continuous Memory Diagnostic Trouble Codes (DTCs). Are any Diagnostic Trouble Codes (DTCs) recorded? Yes REFER to: Communications Network (418-00 Module Communications Network, Diagnosis and Testing). No GO to AJ4 AJ4 CHECK THE CHARGING SYSTEM OPERATION Check the charging system operation. Does the charging system operate correctly? Yes If the charging system warning indicator is never on, the system is operating correctly at this time. If the charging system warning indicator is always on, DIAGNOSE all BCM Diagnostic Trouble Codes (DTCs). REFER to: Body Control Module (BCM) (419-10 Multifunction Electronic Modules, Diagnosis and Testing). No REFER to: Charging System - 2.0L EcoBoost (184kW/250PS) – MI4 (414-00 Charging System - General Information, Diagnosis and Testing). Relevant sections of the 2018 Edge Workshop Manual are linked for download below, and in an immediately following post, due to Forum file attachment limitations... Document download links> Charging System - 2.0L EcoBoost - Overview - 2018 Edge Workshop Manual.pdf Charging_System_-_2.0L_EcoBoost_-_System_Operation_and_Component_Description_-_2018_Edge_Workshop_Manual.pdf Message Center - System Operation and Component Description - 2018 Edge Workshop Manual.pdf Battery Load Shed - Description and Operation - 2018 Edge Workshop Manual.pdf
SSM 52206 - 2024 Lincoln Nautilus - Reserve And Black Label - Knocking Type Noise From Rear Shock Absorber Area Some 2024 Lincoln Nautilus vehicles equipped with the Reserve and Black Label packages may exhibit a knocking noise from the rear shock absorber area of the vehicle while driving at speeds between 8 mph and 19 mph (13 km/h and 30 km/h) on rough road surfaces or when going over bumps. If the concern is isolated to the rear shock absorber assembly, replacing it at this time is unlikely to resolve the concern and is not recommended. This concern has no effect on vehicle operation or durability and is currently under investigation. Repair direction is expected late Q1 2024. Schedule a service appointment for this timeframe and monitor OASIS for additional information.
Document download link> Bezel Diagnostics - General Procedures - 2022-2024 Edge Workshop Manual.pdf Good luck!
It is true that scanning your Edge's electronic modules will reveal any current and/or historical DTCs, including those associated with the Audio Control Panel. Your good choice to invest in the longer-term Ford Protect CPO-Wraparound Premiumcare, to expand the covered items and extend the duration of the selling dealership's Blue Advantage Gold CPO, relieves you of any need to scan the Edge, unless you already have the device on hand. The selling dealer's Service department will surely correct your Edge's radio power-off issue, and your being able to tell them whether or not the radio powers-off to your SYNC Voice Command may be useful to the Service Writer and Repair Tech as they seek the issue's root cause. Your Edge's original factory Bumper-To-Bumper warranty coverage expires on August 13, 2024, so covered Warranty repairs to your vehicle should be performed at no cost to you through that date. After that, the $100 deductible of your Ford Protect CPO-Wraparound contract will apply to covered repairs, except in the case of manufacturer Recall actions which are fulfilled at no cost to owners. There are no unfulfilled Field Service Actions on your Edge, as a result of the selling dealer's completion of Recall 22S14 (link to details) in November 2023. Once again, welcome to the Forum -- and congratulations on your 2021 Edge/CPO-wraparound purchase. Good luck! -
change single note horn to dual note horn
Haz replied to Dan H's topic in Accessories & Modifications
Document download link> Headlamp Assembly - Removal and Installation - 2022-24 Edge Workshop Manual.pdf Good luck! -
Providing full removal procedure with fastener locations for possible partial unfastening & repositioning to accomplish your task. Document download link> Fender Splash Shield - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf Good luck! -
I surveyed photos of 2021-2023 Edges offered for sale online and these images are representative of what I found... The Edge Workshop Manual offers 'Pinpoint Test J' as a diagnostic for the Audio Control Panel. Diagnostic Trouble Codes (DTCs) which are set for several faulty conditions... The DTCs for knob control fault and/or continuous button press may indicate an issue with the Power Button. Given that the sales rep unsuccessfully addressed the radio power-off question with you, and, you've recognized the no-power-off issue after only two weeks, the selling dealer may consider covering the full repair cost or a shared-cost repair arrangement for your Edge. Have you tried using SYNC Voice Command to turn off the radio? If the dealer refuses to cover any repair cost, and using SYNC Voice Command successfully turns radio power Off and On, then it's up to you to decide if the cost of a functioning Power button is worth it. Additional Workshop Manual documents relating to the Audio Control Panel are attached for your awareness... Document download links> PINPOINT TEST J - THE AUDIO-SYNC SYSTEM DOES NOT OPERATE CORRECTLY FROM THE AUDIO CONTROL PANEL - 2021 Edge.pdf Audio Control Panel to SYNC Module Wiring Diagram - 2021 Edge.pdf AUDIO CONTROL PANEL - Connector C2009 Details - 2021 Edge.pdf AUDIO CONTROL PANEL - Connector C2009 Location - 2021 Edge.pdf SYNC MODULE (APIM) - Connector C2383A Details - 2021 Edge.pdf SYNC MODULE (APIM) - Connector C2383A Location - 2021 Edge.pdf Audio Control Panel to Body Control Module (BCM) Wiring Diagram - 2021 Edge.pdf Audio Control Panel to Ground Wiring Diagram - 2021 Edge.pdf Audio Control Panel to HVAC Module Wiring Diagram - 2021 Edge.pdf Audio Control Panel to Body Control Module (BCM) Hazard Lamps Wiring Diagram - 2021 Edge.pdf Good luck!
