Let's keep the momentum and the excitement going Lotta love gone into this project!
2015 and up Edge Sport MRT Performance Exhaust
WWWPerfA_ZN0W replied to edsasdelli's topic in Classifieds
What a steal! Hope someone cashes in on this deal and quick. -
2015-2016 Edge/MKX And 2013-2016 Explorer/Taurus – Automatic Transmission Fluid Leaking From The PTU Temperature Sensor Some 2015-2016 Edge/MKX and 2013-2016 Explorer/Taurus vehicles may exhibit a condition where automatic transmission fluid (ATF) may appear to be leaking from the power transfer unit (PTU) temperature sensor. ATF in the area of the PTU temperature sensor may be the result of a leaking right hand (RH) intermediate shaft seal deflector. Replacement of the PTU temperature sensor will not resolve this condition. To correct the condition replace the RH intermediate shaft seal. Refer to Workshop Manual, Section 308-07.
Front grill emblem, how many pieces?
WWWPerfA_ZN0W replied to Mikula's topic in Accessories & Modifications
This may still work for you http://www.therangerstation.com/how-to/body-paint/ford-oval-color-change/ -
It is on-demand AWD, so maybe that is the disconnect in expectations -
Brakes have an intermittently hard pedal.
WWWPerfA_ZN0W replied to lynmark1's topic in Brakes, Chassis & Suspension
Might be the brake booster. Ford has a CSP out for it, if still applicable you will be $0 out of pocket.- 1 reply
Changed the cabin filter
WWWPerfA_ZN0W replied to bamabob's topic in Interior, A.C., Heat, Interior Trim
Go Ohio! -
LOL! A few more years till the oil companies come exploring then.
LOL, glad the cop had a sense of humor!!!
2016 Ford Edge Sport AWD Powertrain Limitations
WWWPerfA_ZN0W replied to snmjim's topic in All Wheel Drive (AWD)
Rock and a hard place Sorry to hear about the PTU ... There's a bit of emotion attached to "all original" and it hurts a bit to replace even if it is paid for. Believe it or not, we still today have to convince people not to run trans fluid in the PTU! -
Congrats on the new ride! Looks pretty sweet Keep it out of potholes and speedbreakers, will ya? LOL.
Any hits these days seem to turn into niggling issues that turn to neverending frustration. Vehicles are better built, yes, but it is all a system. I see this all the time with AWD Edge/MKX damaged in rear-end collisions. Body doesn't look bad at all, but then the AWD components start failing. You made a wise move, IMHO.
Oh man, what a terrible way to go for your MKX, it will be missed on this forum for sure! But as long as you are okay, and you like the Edge , I guess we can move forward. Thanks for posting the PTU service recommendations! If you can post other recommendations from the manual, including oil weight, change frequency, etc. that would be a tremendous addition to our knowledgebase. BTW what color is your Edge Sport?
Its not only mileage but time. Mfrs have moved away from time recommendations with oil, Ford has the IOLM in the Edge that works for 2012+ MYs. But no similar accommodation for other fluids in the vehicle. Yet, all fluids will age just sitting there, yes, they do have a shelf life, even brand new in the bottle. You may have only 38k kms on your vehicle, but the coolant is likely nearly 5 years old!
The cap is supposed to hold pressure (15 psi?). If it has weakened, it will vent early, and lead to coolant loss. We used to replace them sometimes when radiators still had caps
Great to hear!
Enjoy the fresh air! The OEM filter has a lot more pleats ... -
Great info, as usual! Anybody going through these threads can now see realistic timelines for development of custom products like this. Ain't easy!
Absolutely, checking the battery is a basic yet vital maintenance procedure, I feel, on the Edge/MKX.
Usually it is a calibration issue, a bad wheel speed sensor, or a cracked tone ring that causes this light to pop up. The fact that it is intermittent COULD be a voltage issue (e.g. battery), but yours would be the first case I have seen solved with a new battery.
LED recommendations
WWWPerfA_ZN0W replied to Mattyice's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Diode Dynamics, vLED, JDM ASTAR would be among my top choices. I have had SBLEDs recommended back in the day, may still be good. -
No hip room specs for the X series? Rear pass room is definitely better in the Edge compared to the X3 or X5 - headroom, legroom, and shoulderroom.
