Need Help -- 2008 Limited Battery Drain Problem
WWWPerfA_ZN0W replied to Peveto's topic in 2008 Edge & MKX
a module not falling asleep can cause this, or something that spikes hard when it activates. if you can get an amp meter or ammeter and record amp drain over time (video) for at least 40 minutes from just before engine shutoff, you may find the culprit. or go fuse hunting, usually in the BCM/SJB/pass compartment fusebox. some battery testers will also tell you if there is AC voltage in the circuit (generator fault) but you can use a DVoM for the same. use YouTube to find out how. -
Cold Air Intake Edge ST & Sport 2.7EB
WWWPerfA_ZN0W replied to Xtra's topic in Accessories & Modifications
ford doesnt officially list it for anything but edge/mkx use, but you never know ... with a little finagling in other SUVs/CUVs ... https://parts.levittownfordparts.com/oem-parts/ford-air-cleaner-assembly-f2gz9600a -
this atkins diet thing has gone TOO far.
well, can definitely pray for soft landings lol. if you're not moving, you're d..d.
since you have replaced the pcm and coils, that leaves the wiring harness. ohm test the wiring harness for breaks. what misfire code were/are you getting?
have had at least one owner report having to have the radiator replaced in a Euro Edge, for a leak not an obstruction tho. so may want to have it thermally imaged to check for obstructions as Cerberus mentioned. are the cooling fans coming on as designed when temps exceed set point?
most likely canister/canister vent valve having an issue. could be fuel filler neck too. but they should have prompted codes ...
Selling addco custom sway bar for edge
WWWPerfA_ZN0W replied to Denny Gaughan's topic in Classifieds
what year edge, assuming rear sway bar? -
rail dust can get on the vehicle during shipping to the dealer or owner, from factory. over time, it will show itself. surface rust is very common in some areas like frame and driveshaft. no failures to date due to rust, except maybe remotely on the body panels. you can try claybarring it or giving it a good dose of products like IronX before the bar. that will tell you how bad it is. if really concerned, get into an annual regimen of WoolWax or Fluid Film for protection. https://www.youtube.com/c/MACTFordEdge/search?query=rust https://www.youtube.com/c/FordTechMakuloco/search?query=woolwax
not too early at all. if you think about it, the edge is practically 12 years old. it has had avg 12K/year put on it, less than the national 15K/year. and we all know how traffic has worsened in the last couple of decades. if you have been following ford maintenance schedules, you are in for a shock. All fluids (trans, power steering, brake and coolant) should be serviced on a 5/60 schedule from mile 0. the fantasy "normal' maintenance schedule exists for an ever diminishing owner population. AWD fluids - every 3/36 max for PTU, 6/72 max for RDU. look up how much it costs to replace either unit, and you will quickly realize the value of regular maintenance. plugs should be changed on a 5/60 schedule as well, with PCV valve at least being cleaned if not replaced. the tube on the valve is a PITA to take off, but it will yield to heat lol. https://www.youtube.com/c/MACTFordEdge/search?query=maintenance
Welcome. As soon as I saw 2016 and 2.0 and a misfire code, I was ready to cry lol. It may simply be the plugs need changing. ecoboosts eat plugs for lunch, and 60K is a good interval to change them anyway regardless of engine. if a plug change/code reset does not fix the problem, you MAY be looking at a coolant intrusion problem. check the engine label on the right side of the valve cover. post a pic plz. does it say Cleveland or VEP. how is the coolant level? you will want to mark current level with a marker, then follow progress daily/weekly. do you have remaining ford warranty?
i hope you A) replaced all the TTY bolts, and B ) used cam holders before taking the system apart. did you put on new timing chain/tensioners/guides? all parts ford/motorcraft or were they aftermarket?
knee jerk reaction? water pump/timing chain failure. P0016 and P0018 codes are basically the same animal. bank 1 vs 2. as the timing chain stretches or tensioner loses flexibility, power loss can definitely be a symptom as the PCM retards timing to save the engine. how many miles on your Edge? the work can be DIY, depending on your mechanical ability. it is an exhautive process and you must be diligent about following procedure. you can follow the video series on this work over at YouTube.
argh! we are not ready yet to buy i have seen this Edge in person, and it is everything that has been posted about, in words, pictures, and videos.
The Ultimate 2.7TT Aftermarket Parts Thread!
WWWPerfA_ZN0W replied to Special_K's topic in 2.7L EcoBoost
thanks for the kind words, Jim, Happy New Year to you as well! -
@snmjim the conversation gets out of whack now and then. we definitely do not want you to mothball Edge stuff in any way, it is amazing what you and your son have achieved in a relatively short period of time. there is much you have contributed also outside of this forum, that many may not be aware of. stick with us. -
Edge 2019 AWD malfunction service required
WWWPerfA_ZN0W replied to Ammarko's topic in 2.0L EcoBoost
probably something wrong with the viscous coupler in the RDU if tires and fluid and axles check out. -
sweet. dont want that rdu crapping out. that can be a 2000$ plus repair.
very nice -
2021 Edge ST Rotora BBK (Big Brake Kit )
WWWPerfA_ZN0W replied to Kbeck59's topic in Brakes, Chassis & Suspension
dunno if Xtra's deal w Rotora still applies, what discount would be given by namedropping.
