Welcome and congrats!
In the 3.5/3.7, synblend works fine, but does build up varnish over time. Full synthetics keep the engine running clean. The price difference is so small, why would you NOT run a full synthetic? For ecoboosts, in all practicality, one should not even consider a product that is not full synthetic.
Congratulations! Well deserved! Enjoy!
Losing Power To My Instrument Cluster when i hit 1500RPM
WWWPerfA_ZN0W replied to sparky85's topic in Lounge
With time & care, yes it is DIY. Yes, it is a good ole PITA too. Change belts while you are in there, old ones have to come off anyway. -
New alternator time, it sounds like. You could replace the regulator (in the alternator) only, but it costs almost as much as the whole alternator. Make your decision on which brand to buy based on whether you DIY or not. Although Motorcraft remains the #1 choice regardless for OEM spec'd alternators. -
As long as the Firestone center has a good reputation for driveline servicing (check YELP.com for example), why not. Pretty simple process of drain/fill since no flushing can be done. Ask them to use Motorcraft PTU 75W140 fluid if you are worried about non-Motorcraft fluid while under warranty. The key to success in a dealership is to talk to the trans tech directly if the service advisor says no. Explain to the tech what you want done, and they can likely get it done for you. Failing that, try a Lincoln dealership, odds are better they WILL service the PTU. Or you can try to find a shop that does BG Drive Line Servicing. Might still have to explain to them what you want done, but they should be able to figure it out also. https://www.bgprod.com/find-a-shop/ If you are in/near Raleigh NC for example The Car Place4813 Hargrove Road Raleigh, NC 27616 919-878-5600 AAA Car Care Center4618 Atlantic Avenue Raleigh, NC 27612 919-719-1490 Visit website AAA Car Care Center6014 Glenwood Ave. Raleigh, NC 27612 919-832-5907 Visit website Capital Ford-Millbrook Rd2807 Millbrook Rd. Raleigh, NC 27616 919-790-4700 Visit website Sir Walter Chevrolet8501 Glenwood Avenue Raleigh, NC 27612 919-787-3700 Visit website Quail Corners Shell1326 East Millbrook Rd Raleigh, NC 27609 919-876-2235 Atlantic Avenue Tire & Service2131 Harrod Street Raleigh, NC 27604 919-872-6506 Visit website Black's Tire & Auto #351823 East Millbrook Rd Raleigh, NC 27609 919-878-1166 Capital Ford, Inc.4900 Capital Blvd Raleigh, NC 27616 919-790-4600 Capital Ford, Inc.2807 Millbrook Rd. Raleigh, NC 27616 919-790-4700 Capital Ford Quick Lane4900 Capital Blvd RALEIGH, NC 27616 919-790-4748 Chapel Hill Tire, Inc2131 Harrod Street Raleigh, NC 27604 919-872-0786 Capital Chevrolet1820 Capital Blvd raleigh, NC 27604 919-573-5252
It IS fun living life a 1/4 mile at a time ... once in a while Even with CCD there have been some hiccups, so no track is going to be immune.
Welcome to the support group LOL. Hope we can assist. Be sure to put questions in the appropriate subforums!
- 1 reply
No indication of differences. I could go down into the parts detail, usually it is either a change in clutches, or simply standardization across the board. But I do not see why a newer transmission would not work with an early MY Flex. You would have to update the solenoid strategy in the PCM, that would be the major change. Sometimes there are a few minor things like elimination of unneeded mounting points, like they do with engines. Should not affect the control of the transmission by the PCM, or significantly alter the work required to install the transmission. I will look in the FSM to see if it holds any clues as to differences, and update if I find any. Also will compare parts.
Yes on the 6F50, but the rest is a bit complicated. Is his Flex FWD or AWD. Looks like only the FWDs have the early/late issue, as the AWDs are showing a production date of 05/2008-05/2010. The later FWD transmission is compatible to the one in the 2009-10 Edge 3.5 version. Example from FordPartsGiant.com Part Fitment Make Model Year Engine Important vehicle option details Ford Edge 2009-2010 6 Cyl 3.5L 6AT 6F50, Four-Wheel Drive (Full Time), Four-Wheel Drive (Part Time), Front-Wheel Drive Ford Flex 2009-2012 6 Cyl 3.5L 6AT 6F50, 6AT 6F55, Four-Wheel Drive (Full Time), Front-Wheel Drive Ford Taurus 2010-2011 6 Cyl 3.5L 6AT 6F50, 6AT 6F55, Four-Wheel Drive (Full Time), Four-Wheel Drive (Part Time), Front-Wheel Drive Lincoln MKS 2010-2011 6 Cyl 3.5L, 6 Cyl 3.7L 6AT 6F50, 6AT 6F55, Four-Wheel Drive (Full Time), Four-Wheel Drive (Part Time), Front-Wheel Drive Lincoln MKT 2010-2011 6 Cyl 3.5L, 6 Cyl 3.7L 6AT 6F50, 6AT 6F55, Four-Wheel Drive (Full Time), Front-Wheel Drive Lincoln MKX 2009-2010 6 Cyl 3.5L 6AT 6F50, Four-Wheel Drive (Full Time), Four-Wheel Drive (Part Time), Front-Wheel Drive As to the EARLY version of the transmission, only cross-references to the MKS. 9E9Z-7000-ARM Automatic Transmission Assy Remanufactured Fit Note: 3.16 Ratio Production Date: 05/2008-05/2009 Part Fitment Make Model Year Engine Important vehicle option details Ford Flex 2009 6 Cyl 3.5L 6AT 6F50, 6AT 6F55, Four-Wheel Drive (Full Time), Front-Wheel Drive Lincoln MKS 2009 6 Cyl 3.7L 6AT 6F50, 6AT 6F55, Four-Wheel Drive (Full Time), Four-Wheel Drive (Part Time), Front-Wheel Drive 9E9Z-7000-BRM Automatic Transmission Assy Remanufactured Fit Note: 3.39 Ratio Production Date: 05/2008-05/2009 Part Fitment Make Model Year Engine Important vehicle option details Ford Flex 2009 6 Cyl 3.5L 6AT 6F50, 6AT 6F55, Four-Wheel Drive (Full Time), Front-Wheel Drive Lincoln MKS 2009 6 Cyl 3.7L 6AT 6F50, 6AT 6F55, Four-Wheel Drive (Full Time), Four-Wheel Drive (Part Time), Front-Wheel Drive
Use engine hours and an initial oil analysis to see when to change your oil at an optimal interval. Engine hours can be tracked via trip meters built into the instrument cluster. Recommendations are 200 hours all highway, 100 hours all city/stopngo, and 150 for mixed conditions. The oil analysis will help you refine it further. If you do choose to get the used oil analyzed, please post the results here
The 3.5 is a noisy little bugger, and so are the ecoboost engines in their own way. That said, for gen 1.5, there was a tsb issued to address noise appearing to come from the valve cover area, MAY apply to your Gen 2 in a similar vein. Especially since you feel that the engine begins to get noisier 4K into the OCI. It should sound about the same throughout, UNLESS you are driving a LOT of hard miles like idling, WOT, or stopngo. I assume you are using not only the Motorcraft oil of the correct weight (5w20) but also the filter (FL500S)? Definitely stick with full synthetic when in doubt. You could try different brands, as they will have different effects from a subjective viewpoint at least. Oil is not Oil
Towing is where I might think twice with the 2.0, but no reason not to go for it otherwise. Do maintain fluids regularly, engine oil and transmission in particular.
2016 Edge Sport Liftgate Will Not Open
WWWPerfA_ZN0W replied to ezndo's topic in Alarms, Keyless Entry, Locks & Remote Start
The instructions for manual release of the liftgate are here https://drive.google.com/drive/folders/1fv8z-AqOpghGEmK-_0UA_PRCjLUHQZ4b If you are even a little into DIY, given how deep into electronics vehicles are these days, a DVOM is a no-brainer to have around. Even ones from the much maligned Harbor Freight. Here is a look at what macbwt's toolbox has evolved into LOL -
Simple fix at least. Hopefully the replacement battery lasts a day or two longer, LOL.
180k combined?
The same oils recommended in the series will stand up to scrutiny in the Ecoboost. More and more, the oils are designed with direct injection in mind anyway. Naturally aspirated port fuel injection engines are just along for the ride LOL.
That Edge is barely driven! It needs to have the battery charged up on a proper charger, then maintained with a battery tender. Or you could opt to replace the lead acid battery with an AGM type battery. The AGM is stouter, although this would be bandaiding the problem. Keeping the battery charged either through sufficient driving or a battery tender is the real fix. -
Shoulda done it eons ago LOL. Yes, do switch to a quality full synthetic oil, with no regrets. 5W30 for your Ecoboost. Comparative data is at mactgarage.com for 5w20 oils but composition generally carries over to 5w30 as well. https://docs.google.com/spreadsheets/d/1oTuPwZHKoSqFLClaZrBhMh9D5vpX0VhLZrmVdLyFnbE/edit#gid=1379600026 The Motorcraft filter is a good filter for 5K, I think longterm 7.5K is probably the absolute max under normal driving conditions. If you want better filtration, you certainly have options that use full synthetic media and filter out more contaminants. But the FL500S is pretty good for the intended use.
Is the battery verified working ok? CCAs? There is a cinch button that needs to be depressed once the access cover is removed. Need a flatbladed screwdriver for this. If that does not open the latch, use the screwdriver to hook to the latch release on the right side of the cover opening and slide the screwdriver to the left to open the latch. -
You mean this one? CT4Z-9910494-A Under Cover 2.0 LITER $130.95 $90.36 -W716006-S439 Under Cover Retainer Nut Under Cover Retainer 2.0 LITER $2.50 $1.44 BB5Z-00817-A Rear Plate Retainer Clip Under Cover Fastener 2.0 LITER $13.12 $9.05 https://parts.levittownfordparts.com/auto-parts/2012/ford/edge/sel-trim/2-0l-l4-gas-engine/body-cat/splash-shields-scat
I believe a fellow Gen 2 owner has the Power Stop kit on his vehicle as well. Likes them so far. As far as the HID lights, you would have to swap the headlamp assemblies. I don't know if they still separate fuses for each HID headlamp, vs a single fuse for the halogens, but that is another (minor consideration). Back to brakes!!! Wish the BBKs were more affordable, but there is always Rotora if you namedrop Xtra in the right ear, or so I hear
