    269
  1. ^^^ seconded. Welcome and congrats!
  2. Only the truck based 3.5EB has the dual injection systems currently in production. May migrate to the smaller engines as well, don't know. Hardly a new setup for overseas manufacturers.
  3. Yeah, RDU also needs regular servicing, recommendation is generally at every other PTU fluid change, as the RDU is not taxed nearly as much as the PTU is. Now some people like to test the limits of AWD, shall we say , and in that case, may benefit from doing the PTU and RDU together. The main difference would still be that anytime the vehicle is in gear (anything but P or N), the PTU is engaged. The RDU is an on demand system, plus has significantly greater fluid capacity than the PTU.
  4. Pretty easy to do for both components, DIY. There ARE professional services for induction cleaning that are worth it if you don't normally use top tier gas. Every year or couple of years, say. Do you have an ecoboost or the 3.5L engine in your Edge? GDI fuel induction services really do help, as intank cleaners are not that effective over time. Valvoline, BG offer specific services for GDI, others may also at the pro level.
  5. Cleanside vs dirtyside, as they call it in PCV lingo. The idea is to draw in fresh air from the clean side (i.e., the bank 2 or radiator side valve cover), and push out the vapors through the PCV valve on the dirty side (bank 1, or firewall side cover) on the V6. Actively managing vapors created during normal operation and preventing deposits from forming inside the engine, and more importantly, meeting EPA goals.
  6. The test Ford does is to see if the heater core is clogged, as laid out in the document. Since the tubes in the heater core are very narrow, they are the canary in the coal mine, I guess. No idea if there is any visible indication in the coolant itself, or it would have been mentioned. I suppose you could have coolant analyzed to confirm the presence of foreign matter. There might be some buildup in the overflow tank/degas bottle, but that usually is simply additives that have dropped out of solution. Answer: change the coolant! Knowing this to be a potential problem, the question is why not implement a KNOWN solution and be on the safe side. I assume Ford stopped using the painted crossover tubes, but maybe not. Regardless, the answer is to CHANGE THE COOLANT. Motorcraft Orange began to be used sometime in July 2011, so 2012 MYs and up use it. For your Edge, the PEAK coolant needed is the Universal Extended Life 5/150K coolant, which is fluorescent green/yellow in color. It might work in place of the Orange as well, since it meets the ASTM spec. As far as materials used in production, I would have no idea. Suppliers change, quality changes, specifications change. That level of detail is almost never visible to us as outsiders, and MAY be hinted at if the part number is revised. It is a fallacy to try and assume the details from the summary, so to speak. Assume, as they say, and you make an ASS out of U and ME, LOL.
  7. Unlikely, probably happened over time, did not get noticed, and added up. Pretty typical today, with computer systems extracting every last drop from physical systems, and owners/drivers expecting to see a check engine light for the smallest of problems. CELs are reserved for occasions when the computer cannot overcome a fault in the system. Thus they MUST be taken seriously when seen, temporary or not.
  8. The PCM can usually be repaired, you can send it over to circuitboardmedics.com for evaluation. If it cannot be repaired by them, it only costs you shipping, IIRC. P1000 is a code that is set when the PCM is reset, such as when battery is disconnected for an extended period of time. Not necessarily an indicator of issues. You will need to verify that the coil drivers in the PCM are intact, otherwise you are stuck in a loop replacing the coils as they will get burnt out time and time again. P0206 is pointing to a fuel injector problem, either in the harness or with the injector itself. I would suspect injector unless you have pest-related damage to the engine wiring. https://www.obd-codes.com/p0206 Replace all 6 injectors at one time to make it easier on yourself. Motorcraft or Denso should work well. P2272 is an o2 sensor stuck lean. This is the post cat sensor on the radiator side. Cats are usually the last to fail, and the problem originates upstream - pcm, coil, plug, injector, etc. So fix the upstream problem first, then clear codes and see what comes back. https://www.obd-codes.com/p2272 Loss of power could also be clogged cats, but no code yet, thankfully.
  9. Ford should have this available in their catalog, I would think. RockAuto.com is showing a radiator fan relay connector (and also a motor connector): https://www.rockauto.com/en/catalog/ford,2007,edge,3.5l+v6,1434490,electrical-connector,radiator+fan+relay+connector,18946 but it is not the right part.
  10. TSB 17-2271 2.0L/2.3L/2.7L EcoBoost, 5.0L, 5.2L – Engine Oil Pressure (EOP) Sensor Oil Leak 22 December 2017 This bulletin supersedes 15-0183. Reason for update: Missing or Incorrect Applications Model: Ford 2015-2017 Edge 2015-2017 F-150 2015-2017 Mustang 2016-2017 Mustang 2016-2017 Explorer 2017 Escape Lincoln 2017 MKC Summary This article supersedes TSB 15-0183 to update the vehicle list and vehicle model years. Issue: Some 2015-2017 Edge vehicles equipped with a 2.0L/2.7L EcoBoost engine, 2015-2017 F150 vehicles equipped with a 2.7L EcoBoost or 5.0L engine, 2015-2017 Mustang vehicles equipped with a 2.3L EcoBoost, 5.0L engine, 2016-2017 Mustang equipped with a 5.2L engine, 2016-2017 Explorer vehicles equipped with a 2.3L EcoBoost engine or 2017 Escape/MKC vehicles equipped with a 2.0L EcoBoost engine may exhibit an engine oil leak. This may be due to the engine oil pressure (EOP) sensor threads leaking. Action: Follow the Service Procedure steps to correct the condition. Parts Part Number Description Quantity TA-24-B Motorcraft Thread Sealant with PTFE 1 PM-4-A Motorcraft Metal Brake Parts Cleaner 1 XO-5W20-QSP Motorcraft SAE 5W-20 Premium Synthetic Blend Motor Oil – 5.0L 1 XO-5W30-QSP Motorcraft SAE 5W-30 Premium Synthetic Blend Motor Oil – 2.0L, 2.3L, 2.7L 1 XO-5W50-QGT Motorcraft SAE 5W-50 Full Synthetic Motor Oil – 5.2L 1 Warranty Status: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. Labor Times Description Operation No. Time 2015-2017 Edge 2.0L, Mustang 2.3L/5.0L/5.2L, 2016-2017 Explorer 2.3L: Inspect And Reseal The EOP Includes Time To Clean Area And Check/Correct Engine Oil Level (Do Not Use With Any Other Labor Operations) 172271A 0.4 2015-2017 F150 2.7L/5.0L, 2017 Escape 2.0L: Inspect And Reseal The EOP Includes Time To Clean Area And Check/Correct Engine Oil Level (Do Not Use With Any Other Labor Operations) 172271B 0.7 2015-2017 Edge 2.7L: Inspect And Reseal The EOP Includes Time To Clean Area And Check/Correct Engine Oil Level (Do Not Use With Any Other Labor Operations) 172271C 1.4 2017 MKC 2.0L: Inspect And Reseal The EOP Includes Time To Clean Area And Check/Correct Engine Oil Level (Do Not Use With Any Other Labor Operations) 172271D 0.5 Repair/Claim Coding Causal Part: 9278 Condition Code: D8 Drive Tool Name 1/4″ Ratchet 1/4″ Torque Wrench 1/4″ 2″ Extension 1/4″ 6″ Extension 1/4″ 7 mm Socket 1/4″ 8 mm Socket 1/4″ 10 mm Socket 1/4″ Power Tool 3/8″ Ratchet 3/8″ Torque Wrench 3/8″ 15 mm Socket 3/8″ 21 mm Socket 3/8″ 3/8″ to 1/2″ Adaptor 3/8″ Torx T-30 Socket 1/2″ Ratchet 1/2″ 27 mm Socket Trim Tool Wire Brush Service Procedure 1. Inspect the EOP sensor. Does the EOP sensor exhibit an oil leak at the sensor threads? (1). Yes – proceed to Step 2. (2). No – this article does not apply. Refer to Workshop Manual (WSM), Section 303-00. 2. Remove and reseal the EOP sensor, refer to WSM, Section 303-14. Clean the area as necessary. 3. Inspect and set the engine oil level as needed. Refer to WSM, Section 303-01.
  11. This pipe is also known as the coolant crossover tube/water pump inlet tube, and was a subject of a coolant corrosion related customer satisfaction program on 2007-9 MY Edge MKX that used Gold Coolant from factory. 09M04-S1 Certain 2007 through 2009 model year Edge and MKX Vehicles - Cooling System Corrosion.pdf
  12. The part number ending in AA is the current version of the seal The vehicle options this part fits: Production Date: 11/2006-12/2014 Ford Part No.: XW4Z-6700-AA Seal Assembly - Crankshaft Oil - Front Base No. 6700 Part Description Seal Assy - Crankshaft Oil - Front Manufacturer Ford. This genuine Ford part is guaranteed by Ford's factory warranty. Your Price: $11.09 Retail Price: $15.54 You Save: $4.45
  13. Welcome to the community, and congrats on the new ride! Believe it or not, the first "mods" for performance and mileage ... getting all fluids up to date - transmission, PTU/RDU (AWD), coolant, power steering, brake etc. Then you have a solid foundation to build on. Is the engine 2.0EB or naturally aspirated 3.5?
  14. Catch can might not be needed for moderate driving, but enthusiast driving, yes, certainly advisable. A few installations have already been done and documented, so you do have a path to follow. Somewhat more involved is setting up the engine for methanol injection, tho if using solely to keep the valves clean does not require a tune, simply plumbing/reservoir.
  15. The Ford model for this work is generally to replace the entire BAMR due to the lack of availability of these small repair parts. So the owner's best resort is to either have a glass co seal the BAMR shut, OR to find a replacement in a JY. You COULD find someone to custom make these parts for you, all depends on how much effort you put into int. Plastic parts can be 3D printed assuming a proper base material is used to withstand the abuse the parts are expected to face.
  16. Serious damage, that is. Hope no one was on there at the time! Merry Christmas and Happy Holidays to you and yours
  17. I believe there was a recall for a rollaway condition for gen 1.5 Edge/MKX for the right halfshaft 2012-14... 14S10/14V393/14V393000: Halfshaft Disengagement/Loss of Drive/Roll Away Also this TSB for the Taurus/Flex/MKS etc - may simply need an updated thrust washer ... TSB 14-0186 (supersedes TSB 13-5-14) TING/POP/CLICK NOISE – FRONT HALFSHAFT Ting, Pop or Click Noise From the Front Wheel Area When Accelerating From a Stop, on Turns or When Shifting Between Drive/Reverse and/or Reverse/Drive Publication Date: October 6, 2014 FORD: 2011-2014 Flex; 2011-2015 Explorer, Taurus LINCOLN: 2011-2014 MKS, MKT This article supersedes TSB 13-5-14 to update the vehicle model years, Issue Statement and Part List. ISSUE: Some 2011-2015 Explorer, Taurus, 2011-2014 Flex, MKT and MKS vehicles may exhibit a noise that could be described as ting, pop or click noise from the front wheel area when accelerating from a stop, on turns or when shifting between drive/reverse and/or reverse/drive. ACTION: Follow the Service Procedure Steps to correct the condition. SERVICE PROCEDURE 1.Separate the halfshaft from the wheel hub. Refer to Workshop Manual (WSM), Section 205-04. a.Do not remove the halfshafts from the transmission or power transfer unit (PTU). 2.Install one (1) thrust washer, metal surface first, over the halfshaft splines until the metal ring is flat against the wheel bearing mating surface. The nylon surface should face outward toward the hub/splines. (Figures 1 and 2) Figure 1 – 14-0186 Figure 2 - 14-0186 3.Install the halfshaft to wheel hub. Refer to WSM, Section 205-04. PART NUMBER PART NAME BB5Z-7G273-B Washer – Thrust W712435-S439 Nut – Wheel Hub W714890-S440 Nut – Ball Joint W713968-S440 Nut – Sway Bar Link W714890-S440 Nut – Tie Rod End W500220-S439 Bolt – Dynamic Suspension OPERATION DESCRIPTION TIME 140186A 2011-2014 MKT, MKS: Install A Thrust Washer Onto One (1) Front Halfshaft Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.8 Hr. 140186B 2011-2014 MKT, MKS: Install A Thrust Washer Onto Both (2) Front Halfshafts Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.2 Hrs. 140186C 2011-2014 Flex 2011-2015 Taurus: Install A Thrust Washer Onto One (1) Front Halfshaft Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.7 Hr. 140186D 2011-2014 Flex 2011-2015 Taurus: Install A Thrust Washer Onto Both (2) Front Halfshafts Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.1 Hrs. 140186E 2011-2015 Explorer: Install A Thrust Washer Onto One (1) Front Halfshaft Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.7 Hr. 140186F 2011-2015 Explorer: Install A Thrust Washer Onto Both (2) Front Halfshafts Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.0 Hr. WARRANTY STATUS Eligible Under Provisions Of New Vehicle Limited Warranty Coverage. Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. DEALER CODING BASIC PART NO. CONDITION CODE 3B436 42
  18. Easily available, and more importantly, owner's choice
  19. Welcome to the community, and congrats
  20. sewing machine oil, eh? Out comes my Fellowes Shredding Machine oil
