Replacement Options for 21" Pirelli P-Zero Performance Tires
WWWPerfA_ZN0W replied to roots57's topic in Wheels & Tires
Lionhart makes well reviewed tires in this size for hipo applications. and gets a thumbs up from a trusted source for tire testing. -
this is a daily drive for @macbwt lol. assuming maintenance is uptodate, your Edge should do fine. most owners don't even change the fluids at Ford recommended intervals, and that means all bets are off. what does your normal drive look like, is it mostly city, mostly highway, or some of both? 150K looks different in an allhighway vehicle than an allcity vehicle. also, do you regularly scan the computers for codes?
the 3.5 in a 2010 is vct, not ti-vct. i am not sure how that affects the sync issue but the pcm seems to be expecting a different response from the sensors than it is getting. i don' t know enough to say that you can use the 2010 oem pcm with the ti-vct engine, a reflash with an as-built from a 2011+ might work, but i just don't know. you could ask a tuner to see if this new engine can be accommodated with the old pcm. changing the throttle body should rid the throttle actuator code, but it will not help with the syncing issue.
did you use a VCT 3.5 or a Ti-VCT 3.5? probably a silly question, but needed to ask. since it is cranking (150-250 rpm?), it is not a PATS issue, and the PCM/instrument cluster are not involved. comes down to checking all the electrical connections and health of battery. are you able to turn on/run all accessories, headlamps, etc? if cam and crank sensors are not synced, then it should set a code. what was the original problem that led to replacement of the engine? was it misfiring on the old setup?
need to retune the fans along with the 170 tstat to take advantage. otherwise you are just delaying the initial rise to operating temperature. the other proactive piece of course is to use a better fluid - such as Amsoil Severe Gear or Redline Lightweight Shockproof. as for difference the cooler makes -
@mrmikesdeuce will be fine without. does affect aerodynamics and mpg to a small extent. -
wont physically fit. the heads and turbos basically are in the way. you would need the entire drivetrain/axles too, plus a custom length driveshaft most likely. now if you are really going to customize it, maybe do the 3.0 TT swap that SpecialK did in the gen 2 sport. i think it would be a better expenditure of time and money. still customization involved, not a dropin type project, but results worth it.
2013 Edge Subwoofer thump and battery drain
WWWPerfA_ZN0W replied to Maddog9776's topic in Audio, Backup, Navigation & SYNC
check the battery to make sure it is still healthy. voltage AND cold cranking amps. is this a factory or aftermarket subwoofer, same for amp. if aftermaket, check the grounds, that's what usually causes the thump. the problems with radio/battery drain have usually been due to a failing CD player, no grounding issues unless of course something is spilled into the console. -
wellll ... the gap is not too far off from ford spec, but it will run a bit leaner than a ford plug would. but the motorcraft is spec'd at 0.031 based on the rockauto listing, so go ahead and use the ngk plugs if you want. general consensus is NGKs don't last as long as the motorcraft plugs tho the ruthenium tech should mitigate that. https://www.rockauto.com/en/catalog/ford,2015,edge,2.7l+v6+turbocharged,3310415,ignition,spark+plug,7212 usually we look for 1 heat range colder in performance applications (when adding 100 whp to the edge for example). not sure what returns the ignitability will have. hope it pays off for you.
great to hear, best of luck, prayers and hugs for the little one. -
drain is at the radiator https://drive.google.com/file/d/1yb7iiEEb6lynAz24D2PUJEpqqMtTYSWE/view?usp=sharing
https://drive.google.com/file/d/1VnfMbTpjvwMlvXwvFZdnlCQ05qXJCoug/view?usp=sharing 148 ft lb
Dead Battery on new Edge ST
WWWPerfA_ZN0W replied to ALDriver's topic in Alarms, Keyless Entry, Locks & Remote Start
much could be said about older vehicles. never had batteries die in our pre2000 Taurus-es either. the demand on them is just so much more now. there are many reasons to buy newer vehicles, but DIYability and battery reliability are definitely not two of them lol. -
if feasible, use a motorcraft branded replacement. rebuilt/remanned by other brands may not perform at the same level, however flawed OEM may be. also service brakes regularly, including slide pins, boots, and fluid.
yes maf related errors can trigger all kinds of warnings and codes as it feeds into the ABS and electronic stability algorithms.
idk if the pcm retrains itself whenever a new battery is installed on gen 2+ but if it thinks it is charging an old battery, this can happen. also pretty easy to check for parasitic draws. normally takes 40+ minutes after engine shutoff for all modules to go to sleep, but plug in additions can be responsible too. -
2.0 and 2.7 transmissions are the same family but not the same build. xx35 series is 2.0 paired, xx55 series is 2.7 paired in gen 2 xx37 for 2.0, xx57 for 2.7 in gen 2.5
Headlights
WWWPerfA_ZN0W replied to Woodboss53's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
a) poor bulbs b ) poor headamp aim c) badly oxidized headlamp lens d) cheap LED bulbs (yes still out there in droves) that said, these headlamps do have a shutter mechanism to work the low and high beams off the same bulb. make sure the shutter is working properly. we have had some that failed entirely and fell in front of the bulb, obscuring ANY function. -
Service Advancetrac light on 2012 Edge while in idle
WWWPerfA_ZN0W replied to 2012 Edge's topic in 2012 Edge & MKX
extended idling with climate control on is known to prompt this ghost error. programming update fixes it, but leaving it alone won't hurt anything, per TSB https://drive.google.com/drive/u/4/folders/1VZ5-ZQ3yDQtlxIF8MGDwtT-2CVpaCZkn -
Greetings - My first 4 cylinder ...LOL
WWWPerfA_ZN0W replied to MNFlatland Edge's topic in Welcome Forum!
welcome and congrats! 2 things: 1) check engine label on valve cover under appearance cover on pass side of engine. hope it is a VEP and not a Cleveland 420 sticker. 2) flexplate is the other major possible issue with these engines. if you start hearing rattles on the driver side of the engine, that is most likely what it is. ok, 3 things. 3) highly advise considering ford protect premiumcare or at least powertrain warranty. check pricing at: https://www.lombardfordwarrantys.com -
best of luck, hope the insurance comes thru with a clean title.
