Power steering issues. Hard to turn
WWWPerfA_ZN0W replied to Chigozie's topic in Brakes, Chassis & Suspension
What year Edge? Is the fluid full? Looks clean & healthy? Then I suggest you try replacing it completely / flushing with Valvoline MaxLife Full Synthetic ATF, which is mercon V compatible. Hope it is available where you are. Is it more effort turning in one direction vs another? Does the effort level go away with higher RPMs turning lock to lock while parked and idling? -
MIght need ABS module reprogramming, OR brake booster replacement.
Cracked Flexplate on 2015 Ford Edge
WWWPerfA_ZN0W replied to Kinza Khan's topic in Recalls, TSBs & Warranty
Rootin' for ya! -
Tow Package/Radiator/Cooling Fans
WWWPerfA_ZN0W replied to coeperc's topic in Cargo, Hauling, Roof Racks & Towing
Might be for 2007-10 Edge/MKX vehicles. Radiator 7T4Z-8005-A EDGE, MKX; W/TRAILER TOWING PKG. $285.88 $197.26 ADD TO CART 1 Radiator 7T4Z-8005-B EDGE, MKX; W/O TRAILER TOWING PKG. $221.10 $152.56 -
2011+ Edge/MKX will take advantage of fuels up to 93, from the factory. Tuning will increase the benefits further, but most times, you will have to switch tunes to switch octane grades. Gearhead Tuning may have an Auto Octane tune that gets around this tho, I would speak with them.
Awesome!
P0018 after water pump and head gasket change
WWWPerfA_ZN0W replied to The_high_priest's topic in 3.5L
Did you take pics during the process? Sure the timing marks are correctly aligned? -
yeah probably could use a recalibration, but IDK if the procedure for MyFord is the same as MyFordTouch.
Fuel consumption - L/100Km or the equivalent MPG
WWWPerfA_ZN0W replied to Edgingage's topic in 2011 Edge & MKX
Are you having oil consumption issues? That may be a problem in your 2011 Edge. If you check oil level regularly, you will know. OR if you check the intake tubing/back of the throttle plate and see pooling oil. Then you would need to update the front valve cover to fix it. Also due for new plugs and new fluids at the very least. Then there are the standard variables: load carried by the vehicle, tire pressure, driving conditions, fuel quality, etc.- 10 replies
- fuel consumption
- fuel mileage
(and 5 more)
Premature ball joint failure on Gen 2 Edge
WWWPerfA_ZN0W replied to Wesley's topic in Brakes, Chassis & Suspension
So what brand did you go with this time? -
see? see? never say never!!! ??
is the door latch pulling an amp draw? if so, it might be causing the battery problems you are seeing.
- 10 replies
Welcome, sweet ride!
2011-18 3.5/3.7 engines on the Edge/MKX platform do indeed have the updated timing setup, since the engines are now Ti-VCT i.e. BOTH intake and exhaust cams are variable. Compared to 2007-10 engines being VCT i.e. only the intake cams being variable.
Special_K, may i request that you add a full list of the mods done to your Edge in the signature? I know the parts list for the 2.7 is published, but I am not sure exactly what all is done specifically to yours. The list is so long that when I am asked to recite it, I constantly keep leaving items off of it! TYVMIA!
Those are outrageous numbers! Well done -
Welcome and congrats!
It's almost 2020 now. Time to replace the struts, I think. Go with Motorcraft or Sachs Stabilus.
2017 edge heater core problem
WWWPerfA_ZN0W replied to Wendy's topic in Interior, A.C., Heat, Interior Trim
Sorry to hear! Which engine in your Titanium?
