Welcome! This forum was very helpful to me when deciding yes/no on an Edge. Hopefully you will find it to be the same.
Wrecked...in my own driveway...pathetic!
WWWPerfA_ZN0W replied to dolphinsc66's topic in 2010 Edge & MKX
Awful thing to happen, coulda happened to anyone. Hang in there! -
The ReaL Custom Car Audio install
WWWPerfA_ZN0W replied to challenger74's topic in Audio, Backup, Navigation & SYNC
Nice work. What are your objectives with this install, how did you choose the components, and how do you plan to isolate them from noise & vibration? Looking forward to the progress pics! -
Need to compare the crossover/equalization specs/capabilities of the factory and aftermarket units to see where the difference might be. Besides that, in general, every amp is going to have its own sound profile, due to the many components involved in both the digital and analog stages. Just look up all the crazy talk on audiophilia on the 'net
^ similar to this video:
Glad it's fixed, and hope it holds!
- 7 replies
- engine rattle
- clack
(and 4 more)
Do these brakes look bad?
WWWPerfA_ZN0W replied to DunePearlEdge's topic in Brakes, Chassis & Suspension
AutoZone, Advance Auto, RockAuto, Amazon, pretty much anywhere for rotors. Best to go local store in case of returns. -
http://www.fordedgeforum.com/index.php?/topic/2030-any-aftermarket-brake-pads/ This thread has useful info. -
How much do you think such a retrofit would cost? Interested.
I had Akebono ceramics put on a car one time, didn't like the stopping power at all. Those pads came highly recommended, but my personal experience was meh. So I have stuck with Performance Friction Z-rated CM pads for other cars. Probably will wear down the rotors faster, they do dust quite a bit, but they have been there whenever I have needed them to be. Would love to have a true high performance ceramic pad, something that doesn't dust, performs well, and minimizes enviro impact.
Looks good! For those that don't want black (few and far between as they may be), other colors are available also, including white, smoke, clear, blue, orange, yellow, and red.
Total HID n00b here. Just some random thoughts, other than mis-wiring: 1) With the original DDM harness, did the bulb fail to come on only on one side? If so, tried switching sides on the bulbs, and/or harnesses/ballasts? 2) Possibly the DDM setup was drawing too much power when "cold", and you "warmed" them up by auto-on, then switching off, then manual-on again. 3) Too much resistance in the circuit, possibly early warning signs of a short. HTH.
AutoZone or Advance Auto are good starting points. Usually get lifetime warranty on pads, can get lifetime on rotors such as Wagner, tho generally 2 years on rotors. Search for and use coupons online to get parts even cheaper than listed. -
Looking to replace the power brake booster in my '07 Edge. As far as I can tell, the OEM part number is 540-00142, and the part is common to the 2007-2010 model years. Does anyone know what the latest revision number is for this part? Is retrofitting the 2011+ booster (supposedly improved) a possibility? TIA.
Welcome! I have seen a Cinnamon Edge around in my neighborhood, and it is a very distinctive color. Good choice!
Sold my 2011 Edge Sport to CarMax this weekend
WWWPerfA_ZN0W replied to sandjunkie's topic in Owner Impressions
Good luck with the Passat. I haven't driven one in quite a while, but my driving experience was positive. If you plan on keeping it for a while make sure you have an experienced VW mechanic as a friend for the post-warranty years (same goes for BMW, Mercedes, etc). -
This thread may be of use to you: http://www.fordedgeforum.com/index.php?/topic/11207-emblems/
2010 edge sport remote flip key
WWWPerfA_ZN0W replied to colinero's topic in Alarms, Keyless Entry, Locks & Remote Start
Nice, thanks! Might have to get one myself. Here's a link from EBay for interested buyers: http://www.ebay.com/itm/FORD-ALLin1-SWITCHBLADE-FLIP-TRANSPONDER-CHIP-KEYLESS-ENTRY-KEY-REMOTE-FREE-PROG-/130687018414 3 button version here: http://www.ebay.com/itm/FORD-F150-EDGE-ESCAPE-ALLin1-FLIP-TRANSPONDER-CHIP-KEYLESS-ENTRY-KEY-REMOTE-FOB-/360453606781 -
Maybe go this route: http://www.jcwhitney.com/frameset/?pl=vt&make=Ford&model=Edge&year=2007 Other retail sites may have options as well.
2007 Ford Edge: Technical Service Bulletins (TSB)
WWWPerfA_ZN0W replied to Edge Guide's topic in Recalls, TSBs & Warranty
A quick update to the list above from AllData's site: TSB Number & Issue Date TSB Title 09M04S1 MAR 10 Campaign - Potential Cooling System Corrosion 09L03 APR 09 Campaign - Tire Valve Stem Inspection/Maintenance 07B46 JUN 07 Campaign - Tire Pressure Monitor System Activation TSB Number & Issue Date TSB Title 10-16-1 AUG 10 Engine - MIL ON/Camshaft Phaser DTC's Set 10-4-6 MAR 10 Interior - Foam Seal Shows Between Dash And Windshield 10-2-9 FEB 10 Drivetrain - Growl/Howl From Rear Hub Area 10-1-8 FEB 10 Electrical - MIL ON/No Crank/No Start/DTC's Set 09-25-7 DEC 09 Drivetrain - PTU R/H Intermediate Shaft Leaks Svc. Tips 09-21-6 NOV 09 A/C - White Flakes Are Blowing From Dash Vents 09-11-15 JUN 09 Engine Controls - Rough/Rolling Idle/Idle Speed Drop 09-11-2 JUN 09 Wheels/Tires - Popping/Snapping Noise At Low Speeds 09-6-3 APR 09 Body - Liftgate Spoiler Gasket Slippage 08-26-8 JAN 09 Engine Controls - Harsh Low Speed Driveline Clunk 08-14-5 JUL 08 Body - Power Liftgate Inoperative/DTC B117B 08-9-4 MAY 08 A/T - No Reverse/3rd or 5th Gears/MIL ON/DTC's Set 08-7-3 APR 08 Steering/Suspension - Vehicle Pull or Drift Condition 08-1-7 JAN 08 Instruments - Inaccurate Fuel Gauge 07-25-4 DEC 07 Body - Sunroof Slow Operation/Sticking/Binding 07-25-8 DEC 07 Drivetrain - Front Axle Clicking/Creaking Noises 07-25-14 DEC 07 Steering - Leaks From Steering Rack/Pump Areas 07-23-18 NOV 07 Steering - Power Steering Belt Chirp/Squeal When Cold 07-23-4 NOV 07 Wheels/Tires - Popping Noise From Wheels When Turning
