Did you check the coolant level? I know it was pressure tested, but didn't see a mention of the coolant level. Also check the coolant itself to see if it has any discoloration/floating stuff in it. If so, might be time for a flush. How many miles on your Edge? And, BTW, welcome and glad to have you here.
Hope this thread helps you: http://www.fordedgeforum.com/topic/8329-07-sel-plus-awd-rear-bearinghub-replacement/ Thought I saw a T-60 mentioned in there.
- 2 replies
- Tools
- bearing/hub
(and 2 more)
List of Mods Goal -- inputs requested!!
WWWPerfA_ZN0W replied to TmoodEdge's topic in Accessories & Modifications
Welcome & congrats, TMood! You've got a great list of mods lined up Opinions on the exhaust system are varied, as expected. To me, both look good and sound good. The Gibson is a bit more "aggressive" than the Magnaflow. Both are Stainless Steel, I assume 304 variety, so longevity should not be a problem. Your Edge is gonna be pretty rad when done -
It really is too bad that, first, this part continues to be problematic, and second, continues to be implemented in production without any resolution. At least they should put a notice out to put a black box in the vehicle when the owner registers a complaint. Maybe the legal department has other ideas (CYA)?
Spanking New 13' Sport owner Brooklyn, NY
WWWPerfA_ZN0W replied to AvBg2000's topic in Welcome Forum!
You know, I was thinking the exact same thing as i was cruising past a Cayenne just the other day. Wouldn't be surprised if it served as inspiration for style AND power. -
Quiet Start
WWWPerfA_ZN0W replied to normcloutier's topic in Alarms, Keyless Entry, Locks & Remote Start
http://www.fordedgeforum.com/topic/8648-remote-start-quiet-start/ Lower RPM engine start. -
Welcome & congrats, Brian! Your pride in your vehicles shows Like the Brian from VA said, great pics. -
H.I.D upgrade.
WWWPerfA_ZN0W replied to Msl558's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Well, that's no fun! Glad you got out of the situation safely. Almost makes you want to put in an inline fuse/fusible link -
No luck taking the airbox off yet, will try AGAIN Monday. Pix then, audio too. Intake Air System Components — Exploded View
Engine Bay Dress Up - Steeda Billet Caps???
WWWPerfA_ZN0W replied to af_maineiac's topic in Accessories & Modifications
EBay is the closest I have come to finding anything useful for "dressup". -
Also check your battery. Many electronics issues can be traced to an old/dying battery.
10k miles, new short block
WWWPerfA_ZN0W replied to Phillip Carter's topic in Recalls, TSBs & Warranty
Cool! Let us know how it goes. At least it seems easier to get an engine than a throttle body -
That might have been it, only greenish color available in the Edge lineup that I am aware of.
Great to hear, Leigh. What symptoms were you experiencing? How did they diagnose it as a TB issue?
H&R install ~3 hours, tips and tricks
WWWPerfA_ZN0W replied to IXIVI's topic in Brakes, Chassis & Suspension
Good to hear! Though it makes you wonder if the Ford guys just forgot to take off the "packing material" from the struts before installation -
Did you see any mineral grays? Quite an interesting color choice as well.
This Edge means business! What did you go for your lighting upgrades? Interior lighting shots?
Good info. No effect on ride? -
Welcome & congrats! Kona Blue is quite a striking color. Maybe look at aquatic designs for inspiration?
Thought I'd add this door latch replacement info from the 2007 Edge Workshop Manual: Removal and Installation Remove the door trim panel. For additional information, refer to Section 501-05 . http://www.paulstravelpictures.com/Ford-Edge-Door-Panel-Removal-Speaker-Replacement-Guide/index.html Remove the door window regulator and motor assembly. For additional information, refer to Section 501-11 . http://www.paulstravelpictures.com/Ford-Edge-Power-Window-Motor-Replacement-Guide/index.html Disconnect the interior door handle actuating cable. If equipped, disconnect the door lock cylinder actuating rod. Disconnect the door handle reinforcement actuating rod. NOTE: Front door shown, rear door similar. Release the door latch rear locking clip. NOTE: Front door shown, rear door similar. Release the door latch front locking clip. Disconnect the door latch electrical connector. Release the door latch front locking clip. Remove the door latch with the door lock actuating rod. If necessary, disconnect the door lock actuating rod. To install, reverse the removal procedure. Lubricate the door latch to striker surfaces after installation.
