    269
  1. According to the manual, A/C turns on automatically with the DEFROST function. You can try turning that off. I did not find any mention in the Owners Manual that the defroster air will only blow cold. Do you have automatic climate control? You can try putting it into manual mode and then turn on the DEFROST. No heating/cooling problems otherwise in the cabin?
  2. Are you grounded directly to the battery or are you using a chassis ground?
  3. Thank you! Best wishes for the holiday season for everyone
  4. Rocket & Si make excellent play companions! I didn't think you could get a faster one than Rocket, but Si is QUICK!!! And they play so quietly, amazing
  5. The oil filter itself is leaking? Wow! Hope it wasn't a Motorcraft? Never had a unit leak on me through many, many OCs.
  6. Good luck! Hope they fix it right the first time.
  7. Have there been any software updates for the Fusion related to this sensor, akirby?
  8. Welcome & congratulations on the new Edge! Details/pics? Plenty to read on here, and participation is always welcome
  9. WeatherTechs, no question! I was lucky to snag a used set. Husky would be my second choice.
  10. Cool complement to your crew, this Black Beauty He's not gonna want to leave!
  11. With the shortened cycle this MY (end of March, was it?), it is entirely possible that the Jan '14 show will reveal the production model, albeit with a few minor "show only" tweaks. I just hope that color from the concept vehicle makes it into production. If they do go all-Ecoboost, hopefully the MKX will get a larger EB version, or at least a V6 naturally aspirated version. The V6 MUST survive! Wouldn't be totally against a small displacement V8 either
  12. LOL. Your good deeds far outweigh these "oversights", so not to worry
  13. Ok, I stand corrected. Regardless, a PCM/coil problem should still be covered under her warranty, and that's the important thing
  14. She did say "2010 AWD" as thread title ... I think the problem with coils/PCM made Ford extend the warranty out to 80,000 miles? In which case this should be covered (wouldn't that be great!). Thanks for mentioning that, ls973800!
  15. Low humidity around AZ at this time, Prinzll? Hope you feel 110% soon! Looked at my Edge today, saw just how MUCH salt there is to be had on our roads, even tho they LOOK clean & dry.
  16. Door latch! Lubricating the latch has helped some folks for sure. Preferably with an electronics-safe cleaner if not opening up the door panel.
  17. Turning in either direction produce the sound? Any change in steering effort? Fluid quality/level ok? How many miles on your Edge? Could be time to try flushing the PS system. I think I did read about the rack having to be replaced on a couple of Edges on this forum, but not a common occurrence for sure.
  18. Who is this mysterious triumvirate??? Thanks for the link!
  19. If you want to change the spark plugs, there are a couple of step-by-step writeups on this forum to help you out. Take your time & it should go fine. Or get a mechanically inclined friend to help. http://www.fordedgeforum.com/topic/8724-sparkplug-replacement-job-info-with-photos/ Haven't heard of the coils catching fire, maybe on other makes & models? BUT, yeah, if the coils wear out (excessive resistance in the circuit), the PCM can eventually fry, which would potentially account for the $2,800 fix the mechanic was referring to. This TSB (which officially applies to 2007-2008 MYs) should help: http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=176650
  20. Did they say how long the repair is covered (independent of the 100K warranty)?
  21. Nice catch, Dingo. Congrats, Cellbine! That camo outfit hid all that stuff from me really well
  22. Look up whiteis33's posts on here, or go to his facebook website to contact him directly. He does really cool work. You can also get in touch with Lightwerkz to see if they have anything for the Edge.
