Welcome to the community, Tom! What color is the Edge?
Awesome! Your persistence has been justly rewarded.
- 34 replies
- 2011 Edge
- PCM Failure
Nice to be able to talk/hear yourself at highway speeds, Cellbine! jmacd27, did you find 915 easier/same/more difficult to work with than 845, what prompted you to switch? Don't look at the paint in direct sunlight if you hate swirls! -
Welcome, Simplex! Sorry to hear about your '12, and glad everyone is a-ok. I am sure the '14 will serve you will in its' stead
Welcome to the forum, cnyle, and congrats on your Edge You do realize that washing & waxing your car these days is the equivalent of a raindance? Look forward to the pix, and your further experiences!
Sorry it did not work out, Swatman. I guess the logic is the same as "oh an air filter could affect emissions, but it is a regular maintenance item, we'd have to charge for it". Normally, hardware is warrantied and not software. I HAD hoped that since this has a direct effect on the emissions system, that Ford &/or the dealership would step up.
- 34 replies
- 2011 Edge
- PCM Failure
Unfortunately, they don't make it easy to service the transmission (or the fuel filter) in the Edge. Other than filling/draining the trans, you pretty much have to crack it open to do major work OR replace the trans filter. HOWEVER, the transmission has been quite reliable, though I don't know if I'd wait till 150,000 miles to change the fluid. Better to check at every OCI.
Welcome to the community! Are you looking at a FWD or an AWD? If AWD, the additional item to look out for is PTU-related, specifically the PTU/axle seal leak and burnt out PTU fluid. Would advise PTU fluid change at that mileage. Other things specific to the Edge: Battery Door latch (usually front driver side) Panoramic sun roof - may stop working; it it is slow to operate, needs to be maintenanced PCM - calibration up to date Brakes - brake pedal If you can get a CPO, so much the better, just so you have time to figure everything out.
Differences between 2011 and 2013 Edge Sport?
WWWPerfA_ZN0W replied to ksandals's topic in Buying, Leasing & Ordering
Looks like the SPORT version is equipped with true duals, the remaining trim levels get the "quasi" duals. -
True duals? Got any more info on this? If anyone on the forum has one of these OEM true duals, please post some pics/audio files/etc. TIA. -
Ultimate Rear DVD Alternative
WWWPerfA_ZN0W replied to pjsockett's topic in Interior, A.C., Heat, Interior Trim
A very cost effective DIY solution for today's on-the-go families & friends. Well done. -
I think it just means check the hub mounting surface, as you have already done.
Auxiliary Power Points
WWWPerfA_ZN0W replied to oskar27's topic in Interior, A.C., Heat, Interior Trim
Not just the socket, but the wiring as well. Though the fuses are same in capacity (20A on my '07), the wiring seems to be inadequate for full loads. A good explanation can be found here: http://www.f150online.com/forums/2789415-post2.html -
Quite a bit of work there, Cellbine! I am anticipating a flood of interest in a HOW-TO with part numbers for this mod
- 4 replies
- Ground Effects
- LED lighting
As long as there are no errors in Capacities & Specifications
First mods for my 2011 Edge Limited
WWWPerfA_ZN0W replied to splork's topic in Accessories & Modifications
Great progress! -
Welcome! I do see Edges of both generations out and about a lot more this year. Served us well over the past winter About to become handy again with all the hauling for garden work/materials!
edge sport suspension question
WWWPerfA_ZN0W replied to dsage's topic in Brakes, Chassis & Suspension
Might have better luck comparing with the Fusion, since the Edge is based on that platform. -
Could be. I don't think tire position (think rotation) would make a difference. A sensor could actually have gone bad, but since you are not seeing any driveability issues/other notifications, that does not seem to be the case.
Firm brake pedal on startup
WWWPerfA_ZN0W replied to Limited59's topic in Brakes, Chassis & Suspension
I'd suspect the brake booster as well. -
What tire pressure level will trigger TPMS warning
WWWPerfA_ZN0W replied to zzbsb's topic in Wheels & Tires
Don't know for sure, but mine triggered around 28 psi. -
Welcome, Tricia, and congrats on your first official post
Good luck!
