    269
  1. Some sellers are x-identifying that as Motorcraft WW-1412 (which is what Amazon sells, I think). http://www.levittownfordsupercenter.com/ford-edge-wiper-blade-rear-p-2311.html http://www.nospartsltd.com/product-p/7t4z17528ac.htm
  2. From what the manual is telling me, you can remove the engine/trans as an assembly from the top, but the PTU does have to come off. Try the Chilton manual's section on Engine/Mechanical to get to this info: http://www.fordedgeforum.com/topic/13205-chilton-2007-13-ford-edge-manual-available/?do=findComment&comment=103079
  3. Haven't replaced the rear wiper on my Edge yet. Am using Bosch for the fronts, they work well. Dingo had recommended Silblade. Should be fine using Motorcraft Motorcraft wipers. From this EBay listing http://www.ebay.com/itm/201126009437 9T4Z-17526-A (Arm) 7T4Z-17C526-B (Cap) AU2Z-17V528-MA (Blade)
  4. So, no noise when applying the brakes hard? Probably a loose brake pad OR a sticking caliper causing uneven contact. Assuming the rotors were turned properly and didn't end up being lightly grooved.
  5. A tire shop can probably diagnose the bad one for you, not sure how you'd do that yourself (generic link below). Here are the R/R instructions for an 07: http://www.aa1car.com/library/diagnosing_abs_wheels_speed_sensors.htm Wheel Speed Sensor — Front Item Part Number Description 1 W500010 Wheel speed sensor bolt 2 2C204 RH/ 2C205 LH Wheel speed sensor 3 — Wheel speed sensor electrical connector (part of 14290) Removal and Installation Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .Remove the retainers and position the fender splash shield aside.Disconnect the wheel speed sensor electrical connector.Disconnect the 6 pushpin fasteners.Remove the front wheel speed sensor bolt and the wheel speed sensor. To install, tighten to 7 Nm (62 lb-in). CAUTION: The wheel speed sensor harness must be routed as shown or damage to the harness during vehicle jounce and rebound can occur. To install, reverse the removal procedure. Wheel Speed Sensor — Rear Item Part Number Description 1 2C190 Wheel speed sensor 2 W500010 Wheel speed sensor bolt 3 — Wheel speed sensor electrical connector (part of 14A005) Removal and Installation Disconnect the battery ground cable. For additional information, refer to Section 414-01 .Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .Disconnect the wheel speed sensor electrical connector. NOTE: It is not necessary to remove the harness routing brackets. Disconnect the wheel speed sensor harness from the brackets.Disconnect the pushpin fasteners.Remove the wheel speed sensor bolt and the wheel speed sensor. To install, tighten to 7 Nm (62 lb-in). To install, reverse the removal procedure.
  6. Make sure when you fill out the app not to go over the 7 months - 1 year mark for next vehicle purchase. Won't get an offer otherwise.
  7. What year is your Edge? Should be on the silver sticker along with gross vehicle weight, tire pressure, etc. Down at the bottom, it should say "Ext Paint:" and then the paint code beside it. That's the way it is on my '07. Also look up drcolorchip.com, they list this type of info also. RR for 2013 ruby red
  8. Not sure on the part number (BT4Z-7821813-B?), but here is a how to on doing it: http://www.fordedgeforum.com/topic/14262-how-to-replace-door-latch-module-for-door-ajar-warning/
  9. Almost caught up to me in my '07
  10. Place to put a note on his obituary "wall": http://www.lastingtributesfuneralcare.com/obituaries/Nicholas-Fersch/
  11. Funky Edge Electricals ... umm yeah ... blame the hyperflash on that Light color looks nice.
  12. "That's the other big opportunity that Butler is chasing: building deeper, longer term relationships with customers so Ford can add value to their lives and to their vehicles." Sounds good. That should be the goal of any business, but seems to have been forgotten by many.
  13. I'd host them on photobucket so you can control the albums/layout, then link them there. You can upload them to a gallery here, but they all get dumped into one album. Space is also limited here.
  14. Wow, tough luck with the Cobalt! How warm does it have to be to qualify for the recall? MD does reach 100+ temps with 100% humidity at times, as you know.
  15. A new tank from Ford (discounted) is $1,000 or so. A Spectra aftermarket tank is $1,600+, if you can believe it!
  16. Awesome! Hope to hear the good news and see pics very soon
  17. Not AWD unfortunately. Though if we did an SVO version of the Edge, wouldn't be a bad idea at all!
  18. I have moldings on mine, put them on the "high" spots on the doors for maximum deterrence. But yeah, folks are gonna ding ya if they want to. Best you can do is park between vehicles that look like their doors will be far enough from yours when open. Either that or have a shock sensor with a police siren go off
