Welcome to the forum, glad to see you and your Edge here! Looks great BTW! Having a reasonably trouble-free ownership experience is exactly what the doctor prescribed Know where to get a good price on a PCM? Do you plan to go OEM or aftermarket for your fan replacement(s)?
Interesting. Original owner/original pads? Driving conditions/style? TIA.
Wiring for Paddle Shifters - Sport & non-Sport
WWWPerfA_ZN0W replied to omar302's topic in 2011 Edge & MKX
Ugh, dang international borders! -
Nice! Welcome to the forum, and congrats on your '13 Sport! Gonna be too long a wish list for Xmas, need to start getting some done pronto Post some pics please!
Here's a video for a 2007: But you can also lookup the 2011 free Chilton manual online, through the INFOTRAC url on this page: http://hmcpl.org/dat...eference-center -
Interested in what you find, and how it works out for you. Good luck!
2012 Ford Edge Transmission Problems
WWWPerfA_ZN0W replied to Matt Kaminski's topic in 2012 Edge & MKX
I would think so. I assume you are out of the B2B period already Does it happen when you shift from Park into Reverse, or even when going through the gears from Drive back to Park? Have you checked the transmission fluid level? Underneath for any signs of fluid leaks? May be relevant to your situation: TSB 07-21-11 http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=139970 Let's see what they find when codes are pulled. You can have an auto parts place pull them also (Advance Auto, AutoZone, etc). -
Looks great! Nice work.
WWWPerfA_ZN0W replied to omar302's topic in Recalls, TSBs & Warranty
Update when you get it back please, candurin, & good luck! -
Rear passenger side brakes
WWWPerfA_ZN0W replied to mastereh's topic in Brakes, Chassis & Suspension
Sounds like a stuck caliper to me, you should've felt some drag, unless it just happened. Caliper servicing and/or replacement should fix the problem. -
Need help buying a 2013 Edge Sport AWD
WWWPerfA_ZN0W replied to metalfred's topic in Buying, Leasing & Ordering
Doesn't sound worth it to me anymore unless they give it to you for 20,000 out the door. Will the mfr warranty cover everything, damages resulting from the accident that reveal themselves over time? Do you want to deal with the potential headaches? Will the paint match perfectly? How much does the insurance company think it's worth? I'd be ROYALLY pissed off. They should've been delivering it on a trailer, not driving it. I'd walk away, even though it means starting the search all over again. -
Renewing 07 Tan panel
WWWPerfA_ZN0W replied to iCanSeeYou's topic in Interior, A.C., Heat, Interior Trim
Is it really scraped, or is there jeans color stuck on there? If it needs repainting, I believe DupliColor & Krylon make paint for plastics, should have a close color match. Basics are the same: lightly sand with a fine grit sandpaper, lay down a coat or two of primer & adhesion promoter, then paint. Some products may allow you to go straight to paint, but even so, you should clean the surface thoroughly with soap & water/isopropyl alcohol first. HTH. -
You SHOULD miss it, but not REGRET it Best of luck! -
Rotten luck! Wonder if there is some wiring that needs to be shifted around along with software configuration. -
Congrats! What color did you go with? You had most of the bases covered, make sure you get the alignment checked elsewhere (regardless of what the dealer says) to save your tires. Do you have the panoramic sunroof/moonroof also? Make sure that is working smoothly, as it may need lube on the tracks. AWD hasn't really been a problem in 2011+, so hopefully yours won't be either. -
Has the PTU problem been fixed in the 2013 model?
WWWPerfA_ZN0W replied to schaffner4449's topic in All Wheel Drive (AWD)
Make sure the dealership checks the PTU fluid level. Possibility of level being low on some units out there when released from factory/dealer, based on amount of fluid extracted from the PTU during a flush/replace procedure by the owner. -
Unusual for the 2011+ Edge, more likely to have a throttle body problem with those years. But hopefully that's the culprit (under warranty, right?). -
Hey folks! I know this topic has been raised now and then, here & there. I hope to consolidate the interest in one place, in this thread. I am working through people on another site to help make this happen, and will need volunteers/guinea pigs for test & fitment. Please add a post with a list of aftermarket mods you would like to see available for your Edge/MKX, along with the type of vehicle you have. Additional options for the Ecoboost crowd. I will get this started: 2007 Edge SEL - 3.5L AWD Downpipes with high flow cats (and without for no-testing states) Coilovers Tuner Catback Exhaust System Cold Air Intake Kit Stabilizer Bar for front/rear (tuned to the vehicle)
- 32 replies
- Engine
- Suspension
(and 3 more)
Very nice. The emblem looks much better with the black surround on the black grille.
This is awesome Good luck on your trip back home (pretty far away!), and enjoy! Pics, please
Welcome! Great looking Sport, and nice mods you have on there already! What LEDs did you use, do you have links to them by any chance? The stance will be great with H&Rs, will likely need an alignment though.
Enjoy the trip, and post some pics too!
2015 Edge dealer preview guide
WWWPerfA_ZN0W replied to exodus's topic in Buying, Leasing & Ordering
Hope some of our forum members can make it out there and report the breaking news! January in DC would probably be too late. -
Hey there! Glad to have you and your Edge on this forum How long have you owned it and what mods (if any) do you have on it? AWD?
