Shift to Park Warning when it's in Park
WWWPerfA_ZN0W replied to AmyLovesHerEdge's topic in All Wheel Drive (AWD)
Hope they get your Edge fixed up pronto! -
I see what you mean. Is it "off" more at the top of the door than the bottom? Hopefully no "shaving" or trimming of metal parts is needed.
If the headlights are anything like the taillights, you should be able to separate the lens from the body. There was a writeup sometime ago on how a member coated/painted the interior chrome parts of the taillights black, that has some tips on how to separate and re-join. http://www.fordedgeforum.com/topic/14008-diy-tail-light-painting/
I find it really difficult to believe an oil could make that much of a difference, but am interested in your followup I would think colder weather, more idling time, more use of the HVAC, all these things would contribute to the lowered mpg. Still, 4 mpg is a lot!
Absolutely. I posted the alignment procedure for GK purposes, since the topic was brought up. Not sure I see anything in these instructions either to help the door close tighter to the body, but a body shop would know far better than I
Since the frame of reference is relative, either the front or the rear door or both could need alignment. Here are the instructions for a 2007: Door Adjustment — Front NOTE: LH door shown, RH door similar. NOTE: Make sure the rear door is within specifications before making any adjustments to the front door. For additional information, refer to Section 501-35 . Remove the front fender. For additional information, refer to Section 501-02 .Mark the position of the front door hinges to use as a reference point.Loosen the 2 front door lower hinge-to-body bolts just enough to permit movement.Loosen the 2 front door upper hinge-to-body bolts just enough to permit movement.Loosen the front door upper hinge locator pin nut just enough to permit movement.Adjust the front door to specifications. For additional information, refer to Section 501-35 .Tighten the front door upper hinge-to-body bolts in the order shown. Tighten to 30 Nm (22 lb-ft). Tighten the front door upper hinge locator pin nut. Tighten to 12 Nm (9 lb-ft). Install the front fender. For additional information, refer to Section 501-02 . Door Adjustment — Rear Remove the B-pillar trim panel. For additional information, refer to Section 501-05 .Mark the positions of the rear door hinges to use as reference points.Loosen the 2 lower interior rear door hinge-to-body nuts just enough to permit movement.Loosen the 2 upper interior rear door hinge-to-body bolts just enough to permit movement.Loosen the exterior upper rear door hinge locator pin nut just enough to permit movement.Adjust the rear door to specifications. For additional information, refer to Section 501-35 .Tighten the interior upper rear door hinge-to-body nuts in the order shown. Tighten to 30 Nm (22 lb-ft). Tighten the exterior upper rear door hinge-to-body nut. Tighten to 12 Nm (9 lb-ft). Check the front door adjustments. For additional information, refer to Door Adjustment — Front in this section.Install the B-pillar trim panel. For additional information, refer to Section 501-05 .
Hit carpet on hiway, scuffed 22" wheels
WWWPerfA_ZN0W replied to OnTheFence's topic in Appearance - Detailing, Wash & Wax
Man, people seem to be sent out there with a missive to cause damage to other vehicles these days! Glad the scuffs are taken care of -
According to the oracle of our times (Amazon), it is ethylene glycol http://www.amazon.com/Genuine-Ford-VC-7-B-Concentrated-Antifreeze/dp/B000NU3T3W To quote: Yellow-colored, longer-life, ethylene glycol-based antifreeze/coolant for use in gasoline and diesel engines Provides year-round antifreeze, anti-boil and corrosion protection A 50/50 mixture of coolant and distilled water provides freeze protection down to -34°F (-37°C) and boiling protection up to 265°F (129°C) Do not mix different colors or types of coolant in your vehicle Contains a bittering agent Ford's product page & MSDS: http://www.fordparts.com/Products/Chemicals-EngineProducts-Coolants.aspx https://www.fcsdchemicalsandlubricants.com/main/msds/us189062us.pdf Use only when specifiedUse when Ford Specification WSS-M97B51-A1 is specified Do not mix different colors or types of coolant in your vehicle. Make sure the correct coolant is used. Mixing of engine coolants may harm your engine’s cooling system. The use of an improper coolant may harm engine and cooling system components and may void the warranty Do not use this product in systems originally equipped with the orange-colored Motorcraft® Orange Antifreeze/Coolant, meeting Ford Specifications WSS-M97B44-D or –D2, or with the fluorescent green-colored Motorcraft® Premium Antifreeze/Coolant, meeting Ford Specification ESE-M97B44-A (refer to the Motorcraft® usage chart for exceptions), or with the dark green-colored Motorcraft® Specialty Green Engine Coolant, meeting Ford Specification WSS-M97B55-A Meets or exceeds the requirements of WSS-M97B51-A1 (as a 50/50 mixture), ASTM D 3306, Chrysler MS-9769, Cummins 14603, and ASTM D 6210
Hope Ford can get you guys a new & improved tank soon!
Post a pic so we can see what the issue is? Is it aligned on the fender side of the door? How much is it off? Closes with no problem?
Sync may need to be updated, worst comes to worst, the APIM (which has an extended warranty) may need to be replaced. Did you get the window sticker? You can check the production date on it at the bottom (last 6 digits on line below item #): http://www.inventory.ford.com/services/inventory/WindowSticker.pdf?vin= Another source of info (put in VIN under Vehicle tab): http://www.etis.ford.com We ran into transmission troubles with our '98 Blazer 4x4 before we gave it up. Engine continued to work fine. Some body rust too.
How come?
It's Ford (not Lincoln) leather, you live in a hot/dry climate. If you are planning to keep the Edge for a substantial length of time, dress the leather well with a good leather cleaner/conditioner every couple of months. Should not be a lot of product required if done at these short intervals. Will maintain suppleness and looks.
- 11 replies
- hot climate
- dry climate
(and 2 more)
Welcome to the forum & Edge ownership, Mikey! Tell us a bit more of the backstory, how come you bought it out here in VA? What color is it? What do you like best so far, and what was your previous ride? Pics?
Congrats on your '14 SEL, and welcome to the fold 3 years (maybe more) of fun & adventure to look forward to! What was your previous ride? Put up some pix!
Very likely, but for under $30, at the very least you are looking at eye candy -
Car washes around here would basically shut down if the highs don't crack the freezing point, so I probably should get in a good wash 'n wax session before then as well! Keep an eye on the battery esp if leaving outdoors. -
Looks like Ford is in the process of acknowledging and implementing a replacement solution to this problem: http://www.fordedgeforum.com/topic/12839-serious-gas-tank-leak/page-3?do=findComment&comment=118764 http://www.usnews.com/news/business/articles/2014/10/29/ford-recalls-205-000-suvs-for-fuel-tank-leaks
Oh man, REALLY sorry to hear! Best wishes for a full & speedy recovery!
Wow, nice lookin' Edge! Welcome to the forum, sorry about your '06 Escape, hope you guys made it out of there OK.
AEM makes products similar to K&N, probably better known in the F150 community. In fact, this filter was developed in collaboration with K&N. But it doesn't need to be oiled. Fits very nicely into the airbox. You don't need to buy their detergent to clean it either, bonus! -
Been a year since last air filter change. Still looks pretty new. But to scratch the mod itch, installed an AEM DryFlow filter Will see over time if any practical improvements result. -
Great way to break it in Slowly getting colder around here, no snow/ice yet tho.
- 1 reply
Welcome fellow Edge owner, all the way from the Lonestar state! Glad to have you here, and wise decision getting the wife a '13 Edge I assume the Yamaha Royal Star forum is a motorcycle forum? Post some pics of the Edge, and feel tree to tool around, ask questions, and contribute!
