    269
  1. 0-20 is def not necessary, 5-20 is OEM, correct. I typically use 5-20, but if I can get 0-20 cheap, I see no harm in using it, esp if full synthetic. I won't put in 5w-30 though, unless the PDS matches very closely with or betters the Motorcraft 5-20 Syn Blend PDS. Even though the label on synthetics says the weightage, not all oils are same in their characteristics, weightage being the same.
  2. Yeah, I was probably better off in my Hyundai Accent rental LOL. Just don't try wheelies ...
  3. Only thing I can think of would be DIY or custom solution from say Dynamik Illusions.
  4. Welcome! Most of the issues won't show till later, but battery/gear shifter/door latch would be at top of the list right now. PTU later on, maybe 50k mark or so. Make sure the climate control works properly in all settings, and have them run the built-in diagnostics for you before tasking delivery. Rare but possible: throttle body issues.
  5. Haven't experienced this issue with my 07 either. Maybe the gear shifter thought it was no longer in Park and locked the doors? Although it takes a speed above 10 mph to lock, I believe.
  6. Did they at least run the diagnostics on the Climate Control Module? Since everything is affected, I am more tempted to blame the CCM.
  7. I see you excised the part where you were swearing up & down ...
  8. A trip by the Great Canadian Railroad to the Edge loading point, then a chauffered ride to the factory ... Sounds delectable.
  9. Meh, no luck. The scan picked up single quart bottles, plus no 5 qt jugs on the shelves. Sorry!
  10. Typo? I don't know for sure. I am going to try picking up my order within the hour. http://shop.advanceautoparts.com/p/castrol-cas-mag-0w20-5qt-06006/10838501-P Hope you have success with it as well. I have attached data sheets for comparative purposes. Castrol edge w Syntec PDS.pdf Castrol Magnatec 0w20 PDS.pdf
  11. Jeezuz, glad you are OK! Maybe you should hang a NO DEER CROSSING sign up front on the Edge to warn them. Yikes!
  12. And that's because Toyota stole all their paint for use on the MR2
  13. Probably take about a year to start acting up. At least that was the case with the Strongarm 6120s I installed. Fine above freezing, a muscle building exercise below. Too bad Redline doesn't offer these for the Edge.
  14. If disconnecting and reconnecting switches under the driver's seat does not work, replacement of the DSM is the next logical step. That has been the fix on other model lines. I think the part number is 7T4Z-14C708-A. http://www.fordparts.com/Commerce/CatalogResults.aspx?y=2007&m=Ford&mo=Edge&initSearch=1&partNo=7T4Z-14C708-A#Search
  15. DTBL's HID kits are available now. Dan has a YT video on installation. You can also try other kits from DDM, TRS, etc. LED lighting is starting to become more available. You can get it from EBay or from vLEDs.
  16. Hope you kept your watch Good luck with the MB, I am sure it will prove to be a fine vehicle! Though I should note, the Edge IS available with the Ecoboost in 2.0 and soon the 2.7 trim
  17. Always takes time to recover from the b***-clenching moments. If you trust your work, then relax and see what happens, rather than imagine the worst in the future.
  18. Sorry to hear about this problem! could be a bad battery/trans shifter etc. Did you check the cables/terminals? No corrosion, tightly fastened, etc.? Try moving the shifter to N (neutral) and then starting. Does your insurance have tow/rental coverage? You can also talk with the dealer see if they will do that for you for free, seeing as how new your Edge is. They will need to run a thorough diagnostic anyway, so that will take time. Do you have the Ford extended warranty or some other ...
