If you ARE paying for a new PTU, see if the mechanic will install a drain plug per the_natrix's instructions. Despite the revisions, I am not sure the basic issue has been resolved. Also try to get it filled with Amsoil gear oil, not Motorcraft.
Reverse Camera Lines
WWWPerfA_ZN0W replied to tamugrad2013's topic in Audio, Backup, Navigation & SYNC
Probably the estimated tracking of the Edge based on current steering position? Referred to as FIXED GUIDELINES in the owner's manual in the PARKING AIDS section: Using the Rear View Camera System The rear view camera system displays what is behind your vehicle when you place the transmission in R (Reverse). The system uses two types of guides to help you see what is behind your vehicle: 1. Fixed guidelines: Show the actual path the vehicle is moving in while reversing in a straight line, which can be helpful when backing into a parking space or aligning the vehicle with another object behind the vehicle. 2. Centerline: Helps align the center of the vehicle with an object (i.e. a trailer). Note: If the transmission is in R (Reverse) and the liftgate is ajar, no rear view camera features are displayed. Note: If the image comes on while the transmission is not in R (Reverse), have the system inspected by your authorized dealer. Note: When towing, the camera only sees what is being towed behind the vehicle. This might not provide adequate coverage as it usually provides in normal operation and some objects might not be seen. In some vehicles, the guidelines may disappear once the trailer tow connector is engaged. Note: The camera may not operate correctly under the following conditions: • Nighttime or dark areas if one or both reverse lamps are not operating. • The camera’s view is obstructed by mud, water or debris. Clean the lens with a soft, lint-free cloth and non-abrasive cleaner. • The rear of the vehicle is hit or damaged, causing the camera to become misaligned. Note: Fixed guidelines are only available when the transmission is in R (Reverse). Note: The centerline is only available if fixed guidelines are on. A. Rear bumper B. Fixed guideline: Red zone C. Fixed guideline: Yellow zone D. Fixed guideline: Green zone E. Centerline The fixed guidelines fade in and out depending on the steering wheel position. Always use caution while reversing. Objects in the red zone are closest to your vehicle and objects in the green zone are further away. Objects are getting closer to your vehicle as they move from the green zone to the yellow or red zones. Use the side view mirrors and rear view mirror to get better coverage on both sides and rear of the vehicle. Selectable settings for this feature are FIXED and OFF.- 1 reply
To success
What is leaking in these pictures?
WWWPerfA_ZN0W replied to DunePearlEdge's topic in Brakes, Chassis & Suspension
The trans and power steering fluids are one and the same for your Edge, Dune. Both use Mercon V spec fluid. So should be pink-red when "healthy". If you take a sample of the PS fluid shortly after you are done driving it and feel it with your fingers/put it through a coffee filter and it is dirty/gritty, it is a good time for a change/flush. -
Welcome, Matt, but you know, you can't buy a Yugo and come on here claiming to have bought an Edge Got pics of your new ride?
Agreed. All the guidance on the PTU/RDU fluids has come from owners, so empirical data is our friend right now.
Yes, steering fluid should be changed/flushed periodically. Any hydraulic system will get clogged with debris from weasr and tear over time. There is no set interval for power steering fluid, butdoing it at the same time as a trans fluid change would be a good idea. And I don't mean 150,000 miles either. 60,000 is the latest I'd wait. Good time to check the tpms sensors is when new tires asre being installed. Your installer should be able to advise you on keeping or replacing them. -
Rubbing noise from front when turning left or right
WWWPerfA_ZN0W replied to kaushen79's topic in Exterior & Body
So I guess the "folds" of the boot are creating that noise all by themselves, is what Ford is saying? Interesting. In that case, they should not be left to dry and should be covered with a long-lasting lubricant, just like they suggested.- 17 replies
The Official Ford Customer Service “Out of the Office” Thread
WWWPerfA_ZN0W replied to FordService's topic in Welcome Forum!
Enjoy your vacation, Tricia, build happy memories -
Sound clips before and after! Will likely have to cut that hose a little since the OEM connection comes out straight and the TS connection is at 90 degrees, plus external body looks to be significantly larger.
Hope you will do a writeup if & when you decide to tackle this project, djeyecon
Good to hear the mykey has been subtracted from the equation. Let's see if this resolves the limiter situation! Thanks again to omar302 for pointing this out.
- 668 replies
- 2011 Ford Edge
- Limiited
(and 4 more)
Could be the PTU, but you will have some other symptoms first like a whine or a grinding noise or a leaking vent. Since the symptom has been localized to the front DRIVER side, I am favoring an axle issue at this point. -
Tire noise???????????????????
WWWPerfA_ZN0W replied to Redbow's topic in Brakes, Chassis & Suspension
Sound choice, in tires and life . Good luck! -
This article shows you how to approximate remaining usable tread. http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=51 Tire mfrs typically build in wear "bars" also, not sure what your particular tire is set up for. Tires CAN last that long, but are they safe ... Whole 'nother story. A typical life span is 5-7 years from manufacture to discard. If you do a lot of highway driving, you can rack up a good many miles in a short time, but wear out the tread quickly, for example. When tires start to crack or dryrot, best to start looking for replacements. An alignment will be necessary to maximize the new tires' life. Also have the TPMS checked to make sure the sensors have good battery remaining. -
Look for part numbers EV257 and EV261. Both are Motorcraft parts. Only these 2 need to be ordered. Not sure on the axle leak, possibly a seal issue, possibly an axle issue. That is, the rubber seal could be bad, OR the metal of the axle shaft could be pitted or scored, causing the seal to fail. I see cracking in the nontread area of the tire, plus the whitish pastches look like the belts are starting to get exposed, but IDK. Are these tires original to the vehicle? Is there low tread depth remaining? If so, time to look for replacements. -
Agreed. Talk with your SA, then it's time to investigate.
Dont know about the camera, but getting the tpms retrained might get rid of that annoying tire pressure message.
I loved mashing the pedal to the metal on my loaner Accent. Fun little cars
Abnormal Steering on the 3.7 Sport
WWWPerfA_ZN0W replied to mcali6301's topic in Brakes, Chassis & Suspension
Ford will use plants in Mexico, Brazil, etc. But built to standard. Oem shocks used to come from Sachs, a well respected mfr. -
No carb cleaner on these engines, as mac said. Plugs come pregapped, no real need to touch them other than to install. I am just obsessive lol. You wont know which type pcv valve you have until you take the manifold off. I highly recommend buying both types and returning the one you don't use. -
Carmen might be easier to find. Hope all goes well!
- 668 replies
- 2011 Ford Edge
- Limiited
(and 4 more)
K, I think I found the OEM part (bypass valve) on EBay BL3Z9K378A: http://www.ebay.com/itm/NEW-OEM-TURBOCHRAGER-BYPASS-VALVE-2010-2015-FORD-LINCOLN-VEHICLES-BL3Z-9K378-A-/231449794421? Here is an applications list from the same listing: 2011-2014 Ford F-150 - 3.5L 2015 Ford Transit - 3.5L 2015 Ford Expedition - 3.5L 2015 Lincoln Navigator - 3.5L 2013-2015 Ford Fusion - 2.0L EcoBoost 2013-2015 Lincoln MKZ - 2.0L EcoBoost 2013-2015 Ford Focus - 2.0L EcoBoost 2010-2015 Lincoln MKS - 3.5L 2013-2015 Ford Escape - 2.0L EcoBoost 2015 Lincoln MKC - 2.0L EcoBoost 2010-2015 Ford Flex - 3.5L 2010-2015 Lincoln MKT - 3.5L 2013-2015 Lincoln MKT - 2.0L EcoBoost 2012-2015 Ford Edge - 2.0L EcoBoost 2012-2015 Lincoln MKX - 2.0L EcoBoost 2013-2015 Ford Explorer - 3.5L 2012-2015 Ford Explorer - 2.0L EcoBoost 2010-2015 Ford Taurus - 3.5L 2013-2015 Ford Taurus - 2.0L EcoBoost
Nice find! A lot more work than putting one on the 3.5 EB for sure! http://www.focusst.org/forum/focus-st-performance/12705-turbosmart-dual-port-blow-off-valve-ts-0203-1060-1061-setup-faq.html
