    269
  1. Interesting. Mastel Ford of NY seems to be well liked/rated: http://www.cars.com/dealers/155961/mastel-ford-lincoln/reviews/?sortBy=featured-most-recent&filterBy=service-results Whereabouts are they in PA?
  2. Time to replace the fan assembly most likely: http://www.amazon.com/TYC-622040-Replacement-Radiator-Condenser/dp/B0041TNK44/ Notes: Components Included: Control Unit, Configuration: Radiator and Condenser Cooling Fan Assembly, Connector Quantity: 1, Connector Terminal Quantity: 3, Connector Type: male, Fan Blade Material: PA+GF, Fan Type: Dual, Package Contents: Radiator & Condenser Fan Assembly, Shroud Included: Yes, Shroud Material: PA+GF, w/o TOW Limited Lifetime for non-commercial use http://www.amazon.com/Dorman-621-392-Radiator-Fan-Assembly/dp/B0074DFTKM/ Notes: w/Air Conditioning, wo/Trailer Tow Package, 100% NEW, Fully Assembled for Ease of Installation Dorman limited lifetime warranty Tow package assemblies cost about $100 more.
  3. TSB 14-0045 MUSTY OR ORGANIC ODOR FROM FRONT VENTS – AIR CONDITIONING (A/C) IS ACTIVATED – BUILT ON OR AFTER 4/6/2012 Publication Date: March 5, 2014 FORD: 2013 Edge LINCOLN: 2013 MKX ISSUE: Some 2013 Edge and MKX vehicles built on or after 4/6/2012 may exhibit a musty or organic odor coming from the front vents when A/C is activated. ACTION: Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE Replace the air conditioning evaporator housing assembly. Refer to Workshop Manual (WSM), Section 412-01. PART NUMBER/PART NAME CT4Z-19B555-G Complete Asy, Production-Installed Type, Includes Evaporator Core, Thermostatic Expansion Valve (TXV) And Evaporator Temperature Control Sensor, From: 4/3/2012 2013/ ; Humidity Sensor CT4Z-19B555-H Complete Asy, Production-Installed Type, Includes Evaporator Core, Thermostatic Expansion Valve (TXV) And Evaporator Temperature Control Sensor, From: 4/2/2012 2013/ ; Humidity Sensor CT4Z-19B555-J Complete Asy, Production-Installed Type, Includes Evaporator Core, Thermostatic Expansion Valve (TXV) And Evaporator Temperature Control Sensor, From: 4/3/2012 2013/ ; Less Humidity Sensor CT4Z-19B555-K Complete Asy, Production-Installed Type, Includes Evaporator Core, Thermostatic Expansion Valve (TXV) And Evaporator Temperature Control Sensor, From: 4/2/2012 2013/ ; Less Humidity Sensor 9T4Z-19B555-G Complete Asy, Production-Installed Type, Includes Evaporator Core, Thermostatic Expansion Valve (TXV) And Evaporator Temperature Control Sensor, From: 4/3/2009 2013/ ; Less Humidity Sensor AT4Z-9H486-A Upper Intake Gasket W714878-S439 Steering Column Shaft-To-Steering Column Pinch Bolt OPERATION/DESCRIPTION/TIME 140045A 2013: Edge 2.0L GTDI: Replace The Evaporator Housing Assembly (Do Not Use With Any Other Labor Operations) 4.4 Hrs. 140045A 2013: Edge 3.5L/3.7L: Replace The Evaporator Housing Assembly Includes Time To Remove And Install Upper Intake Manifold (Do Not Use With Any Other Labor Operations) 5.3 Hrs. 140045A 2013: MKX 3.7L: Replace The Evaporator Housing Assembly Includes Time To Remove And Install Upper Intake Manifold (Do Not Use With Any Other Labor Operations) 5.4 Hrs. WARRANTY STATUS Eligible Under Provisions Of New Vehicle Limited Warranty Coverage. Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. DEALER CODING/BASIC PART NO./CONDITION CODE 19B555 42
  4. They are correct in their statement, but it should be a relative piece of cake once you get it started, and it's not.
  5. My sympathies. Can't say I am surprised at your conclusion! I think I will get the OEMs from Ford next time though, just for grins.
  6. Something like Goo Gone or 3M Adhesive Remover should work well. I'd say try acetone/nail polish remover first, if you wanted to, always using a test spot
  7. Unless you install the drivebright lights first
  8. Where did you get the actuators from? A known Ford dealer or a non-Ford source? Can you list part numbers/locations/pics?
  9. Shoulda got a Honda minivan. I hear they come with a builtin vacuum in the cargo bay
  10. Welcome to the forum, Jeff, congrats on your '15 Sport!!! Would love to see some pics of the new rocket ride
  11. How many miles/kms do you have on the Edge, Leafsgal? Is it past the bumper2bumper warranty? Usually diagnostics cost are rolled into the cost of the repair. If you are just a little out of warranty (by time/mileage), you can contact FordServiceCA on this forum, see what might be able to work out for you. Post 4 more posts here to get PM privileges. Then PM FordServiceCA with vehicle & situation details to get the ball rolling.
  12. Good ole polarity! It'd be so much easier if something just didn't work rather than look like it was, but different Good to know info.
  13. Welcome to the world of the Ford Edge, Jeff, glad to have ya here! Not to put the evil eye on your Edge, but I hope you are keeping abreast with the hiccups the 2015 MY is having ... What color did you pick, and did you go with AWD or FWD?
  14. AWD = All Wheel Drive, where both front AND rear tires can be driven as needed. Most of the time, the AWD is in FWD (Front Wheel Drive) mode, but is ready to engage all wheels/tires as needed when slippage is sensed, or the driver suddenly steps on the throttle so that power is manageably put to the ground. The overall height of the wheel/tire combination affects what the system "senses" when it is gathering information as to how much power to apply where, because it assumes a] the overall height is the same at each corner of the vehicle, and b] the overall height is equal to the setting in the computer's memory So BOTH conditions must be satisfied for the AWD to work properly, but you have a leeway of +/- 3%. Outside of that, the AWD when called upon feels it cannot deal with the conditions, and can shut down, effectively putting the Edge into a FWD or limp-home mode. NOT a good thing, as it can destroy the PTU (power takeoff/transfer unit).
  15. Mine's a 2007, so it was a dropin replacement for halogen OEMs. Didn't/don't have to worry about projectors/cutoffs etc. like with HIDs in my application. Very different from the 2015 setup. They do work very well for me, unfortunately I didn't have a color choice at the time of purchase, so I am stuck with 6000K lighting. Would have gotten 4300K or 5000K if available. $160 in all for 4 bulbs (high beams, low beams).
  16. Don't know of anyone who's running any LEDs for the 2015, but GNERGY has vLED's product for his Edge, I have EBay TXT LEDs for mine. Very doable.
  17. Is the centerbore the same as for your Edge? The 2007 Edge is 70.6, 2011+ Edge is 63.4. Not sure on the Taurus, I THINK they are 63.4 also. You might need an adapter depending on the answer, shouldn't be a big deal if the Taurus wheels are same or larger centerbore than your Edge. 18x8 and 39 Offset looks OK.
  18. #1 Change the cabin air filter, probably filthy. Easy DIY. #2 Check to see if water drips under the car when standing after having used AC for some time. If not, it is clogged. There is a connection near the driver side of the center console under the carpeting you can access to blow it out. #3 Spray Lysol (or a foaming AC cleaner product such as from BG or Lubegard; follow instructions) in the vents via the windshield cowl with the engine running and heat on high/blower on high after doing the above. If you still perceive the problem, go in for the TSB fix.
  19. Use Carfax or Autocheck with your Edge's VIN to see where the Edge was originally registered. How long did you use it in Germany, do they salt roads there? Post 4 more posts here to get PM privileges. Then PM FordService (Tricia) with vehicle & situation details to get the ball rolling.
