Maybe you can hop over to macbwt's and he'll take a look He's got firsthand familiarity with motor & trans mounts!
Removing headrest?
WWWPerfA_ZN0W replied to Wildman Goose's topic in Interior, A.C., Heat, Interior Trim
Push in the hole, lift up on the head restraint and release one side of the head restraint.Push the release button and remove the head restraint.Remove the safety belt comfort guide. -
ETIS http://www.etis.ford.com
Wondering what the stock Sony speaker sizes are on your 15+ Edge? bill valley has some info for you here (thanks, bill!): http://www.fordedgeforum.com/topic/20243-door-speaker-size-and-replacements/ His voyage of discovery: http://www.fordedgeforum.com/topic/20164-anyone-replace-their-sony-speakers/
Manual Latch Release for Power Liftgate To manually open the power liftgate, due to power latch failure, remove the latch access cover located on the lower center of the liftgate trim panel. Reach in and down on the right side of the latch and push down on the manual latch release lever. 2012 Edge Power Liftgate Operational Details.pdf
Congrats, just in time for the weekend! Rock on!
Any other electrical issues with the Edge? Sometimes, if the Battery Monitoring System is not reset when a new battery is installed, the charging does not occur properly because the computer thinks it is still dealing with the old battery. Best/easiest way is to have the dealer reset the BMS. Sometimes Motorcraft batteries give up the ghost early, it happens even in their Tough Max offerings. Try having it loadtested with a digital load tester. Another possibility is that the alternator is not charging properly, and if you track the voltages while the Edge is running, it should be between 14 and 14.5V consistently, preferably towards 14.5V than not. With engine & every accessory off, voltage should be about 12.6V or so.
First off, I have no way to verify that the statements made (e.g. battery totally drained) are assumptions or fact. None of us who have posted so far can. So that's why I said "guess", to keep the mind open to the possibilities. I have no doubt that hooking up a charger and/or buying new cables etc are good solutions, but I am looking to "empower" OP to try anything/everything. That's all.
The Power Liftgate feature can be enabled or disabled using the Message Center. With the control in the OFF position, power operation is disabled from the liftgate handle button and from the rear cargo area button. The integrated keyhead transmitter and instrument panel switch will operate the liftgate regardless of the position state of the Message Center. Refer to the Message Center section in this chapter. To manually operate the liftgate: 1. Disable the liftgate power function. Refer to the Message Center in this chapter. 2. Open and close the liftgate as you would a standard liftgate. Refer to the Manual liftgate in this chapter. Note: In case of operation in extreme cold -40° F (-40° C), or on extreme inclines, manual operation of the liftgate is suggested. EDIT: Fuse 14 in the passenger compartment and 59 in the underhood Power Distribution Box are for the Power Liftgate, you could try pulling those also.
Looks like a bump-stop to me ...
Scored a deal Welcome to the forum, congrats on the '13 Ltd!
Loose tail light housing
WWWPerfA_ZN0W replied to Ghannan's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I know this works for 2007-14, same for 2015, enigma? That would be sweet. -
Finger-lickin' good!!!
Factory Service Manual
Welcome, and hope they deliver your Edge in short order!
New guy from Minnesota! Need some advice.
WWWPerfA_ZN0W replied to Vette10R's topic in Welcome Forum!
Welcome to the forum, Vette10R, congrats on the new ride Grows on ya for sure! Put up a pic or two of the Edge (and other rides) when you get a chance, please! -
HTH 2012 Edge 6F50 Selector Lever R&R Cable Adjustment.pdf
I do, in a reflector housing. But I find the dispersion not be quite like a halogen bulb, so orienting it properly in the housing is important. Since your Edge has projectors, you might have better luck. Dingo had installed PIAA LEDs on his Edge, took off the bulb "cap", and is very pleased with the outcome.
Supporting Waldo's assertion is this article in GEARS on Ford's Intelligent All Wheel Drive system: Introducing Ford’s Intelligent All-Wheel Drive System GEARS 2009_9_20.pdf The 3% I was thinking of is not directly related to AWD. It is a "global" 3% tolerance based on the tire/wheel size coded into the PCM, which means that overall wheel/tire height should be within 3% of that expected by the PCM to not trigger a fault, such as P1635. The Owner's Guide is kinda vague on this, but you can see a little bit of information in the "Roadside Emergencies" section.
Wow, in April??? Edge looks great even with it's snow jacket on.
Seats giving me a back problem
WWWPerfA_ZN0W replied to Mike Tollin's topic in Interior, A.C., Heat, Interior Trim
Nice mod, Kevin! -
I believe the tolerance in size differences F/R is about 3% max with AWD, that's what it is on other Ford models. So as long as all 4 tires are the same brand/model/inflation pressure, the difference between the individual tires would be tread depth, which should work out ok.
