What does a P0016 have to do with water pump failure? Video
WWWPerfA_ZN0W replied to macbwt's topic in 3.5L
Do the PTU fluid change within 1 year/10K miles, then at least every 3/36. I think that would keep any issues from cropping up. Not sure on capacity exactly though ... I think yours may have a drain plug, not sure, the Sport definitely does. If you do have your Edge on a lift and can grab some pics of the PTU from different angles, that would answer many a question for owners with Gen 2's with AWD. TIA.- 10 replies
- p0016
- water pump failure
(and 3 more)
Welcome to the community, Kona11, congrats on snagging an Edge with one of the most brilliant colors around Do post before and after pics of your Edge, esp with the all terrain tires when that happens.
Good info I have to always remember to not fill past the first click LOL.
Middle East - does ford limit speed on the Edge?
WWWPerfA_ZN0W replied to WWWPerfA_ZN0W's topic in 2013 Edge & MKX
For my 2007, I see Less Safety Packs and Less Ambient Temp/Speed Pack but that's it. No mention before 2014 either. But you are correct, for 2015, they do display the 2 parameters you mentioned, interesting! Why would they do that? Always there, just never displayed? -
Have never seen a limiter mentioned on any of the build sheets I have seen on ETIS. I suppose that's optional/"need to know" info, can be pulled up from the PCM for sure, since tuners can limit the limiter -
Power Take Off units, transfer cases, differentials all terms that apply. I only posted the Engine part of it since you asked about the coolant pump. There's more text in the PDF regarding transmission etc also.- 10 replies
- p0016
(and 3 more)
I have someone saying 70 mph or so. I dont know if the OEM tires are rated at that tho. -
Does anyone know if there is a factory-set limiter on speed in Edge vehicles shipped to the Middle East? I am thinking this is a MyKey phenomenon, but maybe not? TIA!
Ask Benny Once he has your Edge's VIN number should be pretty straightforward.
Do I really need new rotors at 60k?
WWWPerfA_ZN0W replied to normcloutier's topic in Brakes, Chassis & Suspension
Is the Torx screw necessary to put back in? I thought it was for factory production reasons only? -
Coolant sump? You mean the degas bottle? Good question, but I believe not. The computer definitely makes its' decisions based on cylinder head temperature, and if a warning does pop up, immediately stop off in a safe location and do not attempt to restart the engine. Tow to your nearest dealer. Yes, coolant pump failure should be covered by the standard powertrain warranty. http://www.fordservicecontent.com/Ford_Content/Catalog/owner_information/2017-Ford-Car-Light-Truck-Warranty-version-2_frdwa_EN-US_05_2016.pdf- 10 replies
- p0016
(and 3 more)
Replacing the ugly BLUE FORD EMBLEM
WWWPerfA_ZN0W replied to olperez1's topic in Accessories & Modifications
A heat gun/hair dryer and some floss/fishing line should be all you need to get the old one to come off. -
Welcome! Maintenance and recalls will always be first on the list for any "used" vehicle under consideration. Seeing as how this Edge is potentially 11 years old, hard to say if the mileage is "easy"/highway or "mixed"/city/highway. My biggest concern would be whether the coolant was flushed at 105K, and whether the transmission fluid has been flushed/exchanged (exchanged hopefully). Then there's the spark plugs (90K I think), belts, etc. This generation of Edge is known to eat wheel bearings, particularly in the rear. Rear wheel bearings are expensive parts as they AND the control arm have to be replaced to fix the issue. If the price is right, you can afford maintenance if you DIY.
It is in "layer 3" of the system if you have the 8 inch screen. Behind the Front Display Interface Module (FDIM) which is behind the Front Controls Interface Module (FCIM). FCIM Removal and Installation All vehicles Remove the LH and RH floor console upper finish moulding. For additional information, refer to the floor console exploded view in Section 501-12 .Edge Place the transmission selector lever in neutral. NOTE: The floor console selector lever panel does not need to be removed. Remove the 4 screws, detach the 2 clips and position the floor console selector lever trim panel back.Remove the 6 Front Controls Interface Module (FCIM) screws and remove the FCIM . Disconnect the electrical connector. Remove the 4 screws and remove the Front Display Interface Module (FDIM). You may need to recalibrate once reinstalled. Disconnect the two electrical connectors.Vehicles with 8 inch screen Remove the 4 screws and remove the Accessory Protocol Interface Module (APIM) from the FDIM . To install, tighten to 0.6 Nm (5 lb-in). If you have the 4.2 inch screen, it is a little easier Vehicles with 4.2 inch screen Remove the front floor console. For additional information, refer to Section 501-12 .Remove the floor console rear trim panel.Remove the 5 screws and the remove floor console HVAC duct.Remove the 3 screws and remove the APIM from the mounting bracket. Disconnect the electrical connectors. To install, tighten to 0.6 Nm (5 lb-in). Once the new APIM is installed, you have to recalibrate it. All vehicles To install, reverse the removal procedure. If a new APIM is being installed, program the APIM to the correct software level. For additional information, refer to Accessory Protocol Interface Module (APIM) Programming — 4.2-Inch (107 mm) Screen or Accessory Protocol Interface Module (APIM) Programming — Module Replacement, 8-Inch (203 mm) Touchscreen in this section.
2012 Edge SEL amp location?
WWWPerfA_ZN0W replied to cauchy-goursat's topic in Audio, Backup, Navigation & SYNC
Not sure, but if there is one, it will be behind the subwoofer speaker behind the quarter trim panel (rear passenger side of the cargo area). -
Welcome to the community, John, chefduane makes an excellent suggestion for DIY'rs! How many miles on your wife's Edge, do you have any pics to share? As far as maintenance help, two resources that might help right off the bat: FORDTECHMAKULOCO https://www.youtube.com/user/FordTechMakuloco/videos and specifically for the Ford Edge (MACTFORDEDGE) https://www.youtube.com/channel/UCJb7karK2nhyA7G1BW6xESg/videos For OEM Parts & questions, ask Benny @ LevittownFordSuperCenter http://www.fordedgeforum.com/topic/10937-employee-pricing-on-all-parts-accessories/ See what the Edge came with https://www.etis.ford.com
Fog lamps
WWWPerfA_ZN0W replied to ian whu's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Specifically for 2017 http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O33943&languageCode=en&marketCode=GB&viewTech=IE&chapterTitleSelected=G1676250&subTitleSelected=G1726843&topicHRef=G1726844&div=f&vFilteringEnabled=True -
Fog lamps
The UK site does have manuals http://www.fordservicecontent.com/Ford_Content/Catalog/owner_information/2016-Edge-Owners-Manual-version-1_om_EN-GBR_11_2015.pdf pg 253 BULB SPECIFICATION CHART Exterior Lamps Lamp Specification Power (Watt) Brake and rear lamp. P21/5W 21/5 Central high mounted brake lamp. W16W 16 Cornering lamps. H1 55 Front direction indicator. PY21W 21 Front fog lamp. H11 55 Front side lamp. W5W 5 Headlamp high beam. H15 55 Daytime running lamps. LED LED License plate lamp. W5W 5 Headlamp low beam. H7 55 Rear direction indicator. PY21W 21 Rear fog lamp. P21W 21 Reversing lamps. P21W 21 Side direction indicator. WY5W 5 Note: LED lamps are not serviceable. See an authorized dealer if they fail. Interior Lamps Lamp Specification Power (Watt) Interior lamp. LED LED Luggage compartment lamp. LED LED Map lamp. LED LED Edge Vignale http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Index?bookcode=O35562&marketCode=GB&languageCode=EN&VIN= -
H11 to H9 conversion
WWWPerfA_ZN0W replied to PaulSchott's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
How can we believe this happened? Where are the pics, LOL! -
No Power Leaving From Red Light and Check Engine Light
WWWPerfA_ZN0W replied to tamugrad2013's topic in EcoBoost Mod & Tech
Replacing the HPFP itself is not a big deal, but if the manual calls for replacing the pipe, and the dealer is doing things by the book, you should have gotten a new pipe installed for the price you paid. Just my 2 cents. NOTE: To release the fuel pressure in the high-pressure fuel tube, wrap the fuel injection pump flare nut with a shop towel to absorb any residual fuel pressure during the loosening of the fuel injection pump flare nut. NOTE: Make sure that a new high pressure fuel tube is installed. https://www.fordpartsgiant.com/parts/ford-tube-asy_cj5z-9j323-b.html?Make=Ford&Model=Edge&Year=2013&Submodel=&Filter=(30600)&Location=fuel-injectors-and-pipes,,9J285 -
Welcome to the community, Courtney, nice ride! As forums go, this one is pretty informative & helpful, but the downside is that you will statistically hear more about issues than you will about raves, just the nature of things. Don't let that make you wary/leery though I think of it as preparation for "in case".
Technique and number of coats is important to ensure the dip stays on.
2015 Edge Sport broken trans/PTU?
WWWPerfA_ZN0W replied to redlancer's topic in 2015+ Edge & MKX Generation II
That is wacko! -
I saw this recently recommended on MotorWeek as well. -
Rears are the absolute worst on the Edge, due to the emergency brake, the brake distribution control which uses rears up faster than fronts, and of course the rust mentioned above. Calipers freeze and have to be replaced all the time, so greasing the slide pins regularly should be on your schedule, at least yearly I'd say. And do replace rotors and pads together, this will optimize the bedding in of the pads to the rotor. If you know a trustworthy place that will turn the existing rotors, you can go that route as well, checking the rotor thickness is needed as also mentioned above.
