    272
  1. Has the transmission fluid ever been changed on your Edge? That is a vital service, and considering the (relatively) low mileage on your Edge, should really be changed under the Special Operating Conditions schedule. Even under Normal Operating Conditions, the Ford stated schedule is way overly optimistic, unless you drive 99% highway (maybe). That's where I would start. What about spark plugs, coils and PCV valve? Many transmission issues actually are due to misfires or a poorly running engine and a dirty MAF sensor/throttle body. Once the engine maintenance is brought up to date (much cheaper to start there), then we can start attacking possible trans issues. Since the "putter" is around the area of torque converter lockup, that could be an issue. Or it could be a bad wheel bearing, though usually there is noticeable drag/noise accompanying it. Speaking of which, check the brakes as well. The rears are especially prone to sticking if not lubricated regularly.
  2. Does the Note 4 charge at a good rate with the combo of a non Samsung charger and non Samsung cable? I assume you have already tried charging in the Edge with the OEM Samsung cable? Is the Sync version uptodate? What is the production date of your Edge? Early in the 2016MY or ...?
  3. You may want to consider doing it on-vehicle, as you have to be very careful not to break the glass. Anyway, here is the official procedure 2007 Edge Spoiler R&R.pdf
  4. What pads do you have on there now, Mirage? They should be ok to transfer to the new rotors, assuming they have been worn in evenly and are defect-free. Just would need to re-bed them to the new rotors for best braking.
  5. Scorpion Verde. Not a bad price at all! Good find, omar!.
  6. Sounds like time to find another dealer to work with.
  7. You are right, they are doing everything possible. Hope the new transmission does get put in place, the parts swapping is getting a bit ridiculous ...
  8. Well done, Chevy dealership! Best of luck to your mom with the 2014.
  9. Is that possible to use this stand-alone or are there any other required mods? I'm guessing it's a combination of both - addt'l mods aren't required but would give additional performance gains. Correct Also, my Edge (2017 Sport) is a lease. I'm concerned that the dealer may discover that I tuned it and fine me/void the warranty, etc. Any concerns in that department? Not really. Unless you get silly with the Edge and cause some damage to the powertrain etc. Drive sensibly. Finally, skimming through the owner's manual (thank you for the link), I noticed "*This product is not legal for sale or use in California on pollution controlled motor vehicles". I live in California but I'm not sure if the Edge Sort is considered a "pollution controlled vehicle". Any idea? Yes, any motor vehicle (and probably commercial as well) is a pollution-controlled vehicle (it has catalytic converters, for example). This is a disclaimer they HAVE to give to cover their bases. Edit: Continued reading manual. How damaging would it be to use the 93 Octane tune but only using 87 Octane fuel. Note - I would NEVER intentionally do this - just curious in case I'm a dumb ass and forget to use the proper fuel. Owners manual says it can damage/destroy the engine - is that generally the case or is that more "worst case" scenario? Absolutely no-go. MUST use 93 fuel with 93 tune. Can you get 93 in California? If not, get the tune for the most commonly available premium octane. 2nd Edit: Does anyone have experience on performance gains for the 3 different octane levels? ....
  10. They have oiled filters (just like K&N does) and dryflow filters (completely washable w soap & water or their cleaner). From my understanding the dryflow filters were developed by K&N to be sold by AEM, not sure if that is the case with aFe also.
  11. True, you just can't handle the risk of a rod thru the block. LOL.
  12. No one has added a vent tube on the Edge/MKX that I have seen posted. FWIW, these are the only PTU mod references I have seen ... http://www.fordedgeforum.com/topic/10914-ptu-leak-failures/page-12?do=findComment&comment=148260 http://www.fordedgeforum.com/topic/10914-ptu-leak-failures/page-13?do=findComment&comment=148567 a good photo of the vent from the_Natrix http://s159.photobucket.com/user/the_natrix/media/Ford%20Edge%20PTU/KICX5250_zps24f9b30f.jpg.html?sort=3&o=2
  13. Did they provide you a rental for the duration?
  14. You are SURE there is no overfilling, right? That will cause the fluid to foam and spew out the vent. The correct fill level for 2007 is about a 1/4 inch below the lowest point of the fill plug. I believe you remove the existing jiggle vent, and press fit the new vent fitting instead. This is the part number from the TSB and should fit your PTU AG1Z-7034-A http://www.revbase.com/BBBMOTOR/TSb/DownloadPdf?id=171259 This vent assembly is for 2013 MY on up, hence the new P/N DB5Z-7034-Chttps://www.fordpartsgiant.com/parts/ford-valve-asy-vent_db5z-7034-c.html DB5Z-7034-C Valve Assembly – Vent (Ti-VCT) DG1Z-7034-F Valve Assembly – Vent (GTDI)
  15. The parts diagrams show no drain plugs for any model PTU but the Sport's.
  16. Possibly a faulty display, and it is B226E, or a MODE BLEND DOOR MOTOR STALL error. Pinpoint test J.
  17. Best to leave the options alone, don't fine tune the tune. That's what you paid Torrie for. Once you have loaded the tune, it has flashed the PCM, so it will take a little bit for the PCM to relearn. After that, you can create some datalogs for Torrie to look at if you want. Torrie can check to see if there is room for improvement and/or address any specific issues you discover.
  18. When you say "Ford", Gimp, I assume you meant a dealership? I am going to suggest the obvious: try another dealership, preferably a Lincoln dealership with experienced service techs. Get Ford engineering involved, you do have to ask the dealership to request it tho. The most common boost leak problem has indeed been with loose hoses because Ford in its' wisdom does not clamp all of them on some engines. But it could be a torn seal on a wastgate, or a broken spring therein. obviously the boost leak has not gotten large enough to set a code, but it would be pretty big by then and easy to locate.
  19. A 2008 Orange Crush in Davenport, IA. No, that's not stalking at all ... LOL!
  20. We need more fact-checking by their audience on their own vehicles! Volunteers?
  21. So we are sure that 2012 MY (at least for the Edge) onwards, the IOLM does vary as per intention? the following sections seem to support that claim, since there is no mention of it in the 2011 MY OM. 2012 MY owners manual Intelligent Oil Life Monitor™ Your vehicle is equipped with an Intelligent Oil Life Monitor™ that determines when the engine oil should be changed based on how your vehicles is used. By using several important factors in its calculations, the monitor helps reduce the cost of owning your vehicle and reduce environmental waste at the same time. This means you won’t have to remember to change the oil on a mileage-based schedule; the vehicle lets you know when an oil change is due by displaying ENGINE OIL CHANGE DUE or OIL CHANGE REQUIRED in the message center. The following table is intended to provide examples of vehicle use and its impact on engine oil change intervals; it is provided as a guideline only. Actual engine oil change intervals will depend on several factors and will generally decrease with severity of use. When to expect the OIL CHANGE 2013 MY owners manual Intelligent Oil-Life Monitor® Your vehicle is equipped with an Intelligent Oil-Life Monitor that determines when the engine oil needs to be changed based on how your vehicle is used. By using several important factors in its calculations, the monitor helps reduce the cost of owning your vehicle and reduce environmental waste at the same time. This means you won’t have to remember to change the oil on a mileage-based schedule; the vehicle lets you know when an oil change is due by displaying ENGINE OIL CHANGE DUE or OIL CHANGE REQUIRED in the information display. The following table is intended to provide examples of vehicle use and its impact on engine oil change intervals; it is provided as a guideline only. Actual engine oil change intervals depend on several factors and generally decrease with severity of use. 2014 MY owners manual Intelligent Oil Life Monitor™ Your vehicle is equipped with an Intelligent Oil Life Monitor™ that determines when the engine oil should be changed based on how your vehicles is used. By using several important factors in its calculations, the monitor helps reduce the cost of owning your vehicle and reduce environmental waste at the same time. This means you won’t have to remember to change the oil on a mileage-based schedule; the vehicle lets you know when an oil change is due by displaying ENGINE OIL CHANGE DUE or OIL CHANGE REQUIRED in the message center. The following table is intended to provide examples of vehicle use and its impact on engine oil change intervals; it is provided as a guideline only. Actual engine oil change intervals will depend on several factors and will generally decrease with severity of use. 2015 MY owners manual Intelligent Oil-Life Monitor® Your vehicle is equipped with an Intelligent Oil-Life Monitor that determines when you should change the engine oil based on how you use your vehicle. By using several important factors in its calculations, the monitor helps reduce the cost of owning your vehicle and reduces environmental waste at the same time. This means you do not have to remember to change the oil on a mileage-based schedule. Your vehicle lets you know when an oil change is due by displaying ENGINE OIL CHANGE DUE or OIL CHANGE REQUIRED in the information display. The following table provides examples of vehicle use and its impact on oil change intervals. It is a guideline only. Actual oil change intervals depend on several factors and generally decrease with severity of use.
