    269
  1. Congratulations and welcome aboard! Hope it proves a worthy successor to the Ranger.
  2. Nice detective work, sorry u have to deal with it tho. http://www.fordedgeforum.com/topic/22717-fluttering-noise-from-undercarriage-and-dashboad-rattle/
  3. Welcome in, zurda1, and congrats on the new ride!!! It is a beauty!
  4. Yes, a cooler does exist https://parts.levittownfordparts.com/auto-parts/2015/ford/edge/sport-trim/2-7l-v6-gas-engine/cooling-system-cat/trans-oil-cooler-scat Apparently 2 part numbers, w tow and w/o. Is the Gen 2 sport rated for towing?
  5. AFe only notes oil filters for the 2015+ Edge http://afepower.com/vehicle-platforms/gas-trucks/ford?model=Edge&year=2015-2015
  6. Not directly related to this issue, but thought I would add it here just in case TSB 13-1-15_ANTI LOCK BRAKE SYSTEM (ABS)-ADVANCED TRAC WARNING LIGHT ILLUMINATED - DTCS P193C AND U0401 - BUILT ON OR BEFORE Jan23-2013 http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=179343 The concern often occurs when idling for long periods with the air conditioning on, or when shifting gears. Requires powertrain recalibration.
  7. Sometimes you have to slap them with a glove and call them to a duel to get results.
  8. Well, hop to it, man. It's been a couple of days already! LOL.
  9. No. Unfortunately, the intake manifold has to be removed to replace ANY fuel injector. The rail and injectors are removed as an "assembly".
  10. Premiumcare would be the only way I know to get coverage on the APIM past the extension date. Pricey just for APIM, not so if you have an AWD. Just had the PTU, A/C compressor, and Left Front Wheel Bearing replaced under PC warranty, deductible only out of pocket cost. Invoice was for $2,800 in all.
  11. Use Motorcraft Mercon LV (fine for partial or full exchange) or Valvoline MaxLIFE Multivehicle ATF (advise for full exchanges only).
  12. Welcome aboard, and congrats on the "upgrade"! Nice to have that bottom end torque isn't it? Post pics of your new ride when you get a chance, please :camera: :camera:
  13. Either something stuck in the brake dust shield, or it really is an axle/halfshaft issue. Would also inspect the hub/bearing assembly and strut mounts closely.
  14. Different TStat opening temps between Gen 1 and Gen 1.5. Gen 1 opens around 190F, I believe Gen 1.5 around 180F. So 186F is perfectly OK. Most of the time, the temps on my Edge are between 192F and 196F. Higher ambients will raise those numbers a little, about 2F for every 10F ambient rise.
  15. I think I will wait. The programmer's name is dvil. I think I will wait. Not desperate to put possible ransomware on my machines.
  16. Doesn't want you to access it directly, I guess? but yes, it does work through the search method.
  17. One of those times when you just have to knuckle down But you should be set for another 4-5 years!
  18. See here https://www.fordpartsgiant.com/parts-list/2014-ford-edge/chassis-frame.html Ford BT4Z-5400145-A BT4Z-5400145-A Shim Washer - Insulating Require Quantity: 2 Package Quantity: 1 Base Number: <00145A Callout Name: <00145A $15.95$11.20 1 Ford 5F9Z-5400145-AA 5F9Z-5400145-AA Shim Reinforcement Require Quantity: 2 Package Quantity: 1 Base Number: <00145 Callout Name: <00145B $8.18$5.74 1 https://parts.levittownfordparts.com/auto-parts/2013/ford/edge/sel-trim/3-5l-v6-gas-engine/front-suspension-cat/suspension-components-scat No. Part # Description List Price Price 1 BT4Z-3K185-A Knuckle Knuckle, RIGHT $119.69 $75.70 1 BT4Z-3K186-A Knuckle Knuckle, LEFT $119.69 $75.70 2 -W714681-S439 Knuckle Bolt Knuckle Bolt, RIGHT $2.78 $1.60 2 -W714681-S439 Knuckle Bolt Knuckle Bolt, LEFT $2.78 $1.60 3 -W520213-S440 Stabilizer Bar Nut Knuckle Nut, LEFT $4.63 $2.67 3 -W520213-S440 Stabilizer Bar Nut Knuckle Nut, RIGHT $4.63 $2.67 4 8T4Z-3079-A Lower Control Arm Lower Control Arm, LEFT $255.38 $161.53 4 8T4Z-3078-A Lower Control Arm Lower Control Arm, RIGHT $255.38 $161.53 5 -W712734-S439 Lower Control Arm Bolt Lower Control Arm Bolt, LEFT $4.25 $2.45 5 -W712734-S439 Lower Control Arm Bolt Lower Control Arm Bolt, RIGHT $4.25 $2.45 6 -W712850-S439 Lower Control Arm Mount Bolt Lower Control Arm Mount Bolt, LEFT $2.13 $1.22 6 -W712850-S439 Lower Control Arm Mount Bolt Lower Control Arm Mount Bolt, RIGHT $2.13 $1.22 8 BT4Z-5482-A Stabilizer Bar W/ O 22 WHEELS $119.43 $82.41 8 7T4Z-5482-B Stabilizer Bar W/ 22 WHEELS $184.92 $127.59 9 7T4Z-5484-B Stabilizer Bar Bushing Stabilizer Bar Bushing, LEFT W/ AWD $14.68 $10.13 9 7T4Z-5484-A Stabilizer Bar Bushing Stabilizer Bar Bushing, LEFT W/ O AWD $15.15 $10.45 9 7T4Z-5484-A Stabilizer Bar Bushing Stabilizer Bar Bushing, RIGHT W/ O AWD $15.15 $10.45 9 7T4Z-5484-B Stabilizer Bar Bushing Stabilizer Bar Bushing, RIGHT W/ AWD $14.68 $10.13 10 7T4Z-5486-AA Stabilizer Bar Bracket Stabilizer Bar Bracket, RIGHT $23.02 $15.88 10 7T4Z-5486-AA Stabilizer Bar Bracket Stabilizer Bar Bracket, LEFT $23.02 $15.88 11 -W712802-S439 Stabilizer Bar Bolt Stabilizer Bar Bolt, LEFT $1.00 $0.58 11 -W712802-S439 Stabilizer Bar Bolt Stabilizer Bar Bolt, RIGHT $1.00 $0.58 12 7T4Z-5K483-A Stabilizer Link Stabilizer Link, LEFT $44.29 $28.01 12 7T4Z-5K483-A Stabilizer Link Stabilizer Link, RIGHT $44.29 $28.01 13 -W520214-S440 Control Arm Lock Nut Stabilizer Link Nut, LEFT $5.97 $3.44 13 -W520214-S440 Control Arm Lock Nut Stabilizer Link Nut, RIGHT $5.97 $3.44 14 7T4Z-3B154-AL Mount Plate Mount Plate, LEFT $19.83 $13.69 14 7T4Z-3B154-AR Mount Plate Mount Plate, RIGHT $19.83 $13.69 15 9T4Z-5874-A Stabilizer $94.33 $65.09 16 DT4Z-5C145-A Engine Cradle FROM 2/ 15/ 12 $875.50 $604.10 17 7T4Z-5400155-AB Engine Cradle Insulator Engine Cradle Upper Insulator, LEFT $17.30 $11.94 17 7T4Z-5400155-AB Engine Cradle Insulator Engine Cradle Upper Insulator, RIGHT $17.30 $11.94 18 BT4Z-5400155-A Engine Cradle Insulator Engine Cradle Lower Insulator, LEFT $15.68 $10.82 18 BT4Z-5400155-A Engine Cradle Insulator Engine Cradle Lower Insulator, RIGHT $15.68 $10.82 19 DT4Z-5019-A Cross-Member FROM 2/ 15/ 12 $68.62 $47.35
  19. 2010 was a crossover model year in MANY aspects. So it is possible some spec changed, and the Quick Struts do not allow for it, having been developed on a 2007 platform most likely. OR your Edge has had some body work in the past that caused this, but would have to be fairly major.
  20. Based on what people have done with late model Fords, you are likely ok upsizing the tire width by up to 30 mm or so total and still be rub-free. The new size you specified is 30mm exactly upsized, so my assumption would be that it is ok.
