2011 Ford Edge backup camera troubles
WWWPerfA_ZN0W replied to Piercingpeg's topic in Accessories & Modifications
Per the dealer site, based on the production date of your Edge: 1 BT4Z-19G490-B Rear Camera, TO 10/ 23/ 12 $491.18 $338.92 1 ET4Z-19G490-A Rear Camera, FROM 10/ 24/ 12 $458.65 $316.47 There are people selling on eBay with the OEM moniker just to catch people searching for Original Equipment Manufacturer parts, yes, they are wily that way. Always look for the brand specified in the product description. If it does not stay Ford or Motorcraft, steer clear. Can you provide a link to the product you purchased? I want to see exactly what they describe. TIA. BTW, you CAN use a Gen 2 camera F2GZ-19G490-A instead, it just will not calibrate/provide the guidelines, but works perfectly otherwise. A much cheaper option. -
LED Puddle Lights - 2016 Edge Sport
WWWPerfA_ZN0W replied to roots57's topic in Accessories & Modifications
That or http://drivebright.com -
Also need the W520214 stabilizer bar link lower nut. This is the FSM on the gen 1.5 front LCA: Item Part Number Description 1 3A423 RH/ 3A424 LH Lower arm 2 W520213 Lower ball joint nut 3 3B438 Stabilizer bar link 4 W714681 Lower ball joint bolt 5 W520214 Stabilizer bar link nut 6 W712734 Lower arm-to-frame forward bolt 7 W712850 Lower arm-to-frame rearward bolts (2 required) Removal NOTICE: Suspension fasteners are critical parts because they affect performance of vital components and systems and their failure may result in major service expense. New parts must be installed with the same part numbers or equivalent part, if replacement is necessary. Do not use a replacement part of lesser quality or substitute design. Torque values must be used as specified during reassembly to make sure of correct retention of these parts. Remove the wheel and tire. For additional information, refer to Section 204-04 .Remove and discard the stabilizer bar link lower nut.Remove and discard the lower ball joint nut and bolt.Remove the lower arm-to-frame forward bolt and spacer. Discard the bolt. Remove the 2 lower arm-to-frame rearward bolts and the lower arm. Discard the 2 bolts. Installation NOTE: Do not tighten the bolt at this time. Position the lower arm and loosely install the 2 new lower arm-to-frame rearward bolts. NOTE: Do not tighten the bolts at this time. Loosely install the new lower arm-to-frame forward bolt and install the spacer.Install the new lower arm ball joint bolt and nut. Tighten to 55 Nm (41 lb-ft). Install the new stabilizer bar link lower nut. Tighten to 90 Nm (66 lb-ft). Install the wheel and tire. For additional information, refer to Section 204-04 .With the weight of the vehicle resting on the wheels and tires, tighten the lower arm-to-frame forward bolts to 150 Nm (111 lb-ft).With the weight of the vehicle resting on the wheels and tires, tighten the 2 lower arm-to-frame rearward bolts to 80 Nm (59 lb-ft).Check and, if necessary, align the front end. For additional information, refer to Section 204-04 . AFAIK, these are the Ford part numbers in full 3 -W520213-S440 Stabilizer Bar Nut/Knuckle Nut, LEFT/RIGHT $4.63 $2.67 5 -W712734-S439 Lower control arm-to-frame forward bolt, LEFT/RIGHT $4.25 $2.45 6 -W712850-S439 Lower Control Arm-to-frame rearward bolts, LEFT/RIGHT $2.13 $1.22 13 -W520214-S440 Control Arm Lock Nut/Stabilizer Link Nut, LEFT/RIGHT $5.97 $3.44 2 -W714681-S439 Knuckle Bolt/Lower ball joint bolt, LEFT/RIGHT $2.78 $1.60 4 8T4Z-3079-A Lower Control Arm, LEFT $255.38 $161.53 4 8T4Z-3078-A Lower Control Arm, RIGHT $255.38 $161.53 4 7T4Z-5K483-A Stabilizer Link EDGE, MKX $44.29 $28.01 https://www.fordpartsgiant.com/parts-list/2014-ford-edge/front-susp-arms-stabilizer-x-member.html?Filter=(30393;36997) Qty Required/Qty in Pkg information listed on this site, hopefully accurate!
2011-2014 Parasitic battery drain
WWWPerfA_ZN0W replied to fishx65's topic in Audio, Backup, Navigation & SYNC
Kewl, enjoy!!! -
SSM 45857 Some 2015-2016 Edge and 2016 Lincoln MKX vehicles built on or before 3/23/2016 may exhibit overly sensitive brake applications. This will typically occur at low speed and/or in cold/wet conditions. To correct the condition, install an updated brake booster with part number F2GZ-2005-F (only 2.0L GTDI with 17" rotors) or F2GZ-2005-E (all except 2.0L GTDI with 17" rotors). Refer to Workshop Manual, Section 206-07. For claiming, use causal part 2005 and applicable labor operation(s) in the Service Labor Time Standard (SLTS) Section 2.
I guess the question is how deep does it reach into the tire, and does it have a negative effect, since it IS water based.
sunroof leaking
WWWPerfA_ZN0W replied to Wilson3703's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Try the antenna. Sometimes it leaks from there, and has to be resealed.- 1 reply
2017 Edge SE stereo options?
WWWPerfA_ZN0W replied to dan321's topic in Audio, Backup, Navigation & SYNC
If you only care about the breadth of programming available on Sirius, it is worth it. But you also have to put up with poor audio quality, and renegotiating every few months to get the best pricing (do not auto-bill). -
Keep that name to yourself LOL.
That's a lotta hurt to take! How low WAS the coolant? Keep an eye on it, it should drop pretty slowly over time after the refill. -
Engine Replacement - with or without oil cooler?
WWWPerfA_ZN0W replied to Lonstar's topic in 2008 Edge & MKX
HTH 2007 EdgeMKX Oil Cooler R&R.pdf -
Definitely, the tests are the way to go! But for ecoboosts, yeah, the OCI needs to be rigorous compared to the naturally aspirated options.
I Am sure some rewiring would be involved. People have given up such projects exactly due to this obstacle.
Watch out for flood-damaged cars
WWWPerfA_ZN0W replied to enigma-2's topic in Buying, Leasing & Ordering
I know . My intention basically is to remind, caveat emptor. Just coz it looks good dont mean its gonna last. -
2011 FWD Edge fluid leak after LCA replacement
WWWPerfA_ZN0W replied to mobrien118's topic in Transaxle (FWD)
Dont say that to Thor.- 8 replies
- transmission leak
- fwd
(and 2 more)
2013 Edge rear suspension creaking
WWWPerfA_ZN0W replied to brewman84's topic in Brakes, Chassis & Suspension
Heck if it lasts a while, what the hey! Let people judge you, who cares. If it is not a blatant safety violation, go for it, but advise full disclosure at time of sale. -
Seems pretty early for a purge valve failure on a 15. How many miles do you have on it. The valve may be on the firewall, or in the engine valley close to the intake manifold, like on the 3.5 ecoboost. Fordparts.com should have a diagram showing location. SNMJim might have a manual he can look it up in?
I believe the oil cooler is hooked up to the cooling system. Now to make it work on YOUR vehicle, extra lines and fittings will be needed. I personally do not see a need for the cooler unless you tow a lot. I would swap in the parts from the old engine, sell the cooler on ebay or something. -
Even if deemed roadworthy, we all have seen electrical gremlins rear their ugly heads on flooded vehicles. Just take the early gen 2s for example. So you may be motoring down the road when whammo you get hit with a blackout etc. -
Great capitalization on the dual benefits of E with GDI - octane AND cooling!
2013 Edge Heater Blend Actuator - Replacement Part
WWWPerfA_ZN0W replied to kballein's topic in 2013 Edge & MKX
For the passenger side, I believe it is this one MOTORCRAFT YH1877 {#604240, 7T4Z19E616C} Right -
i dont think the rears have a holding feature like the fronts do, at least on my 2007: With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .Remove and discard the stabilizer bar link upper nuts. To install, tighten to 35 Nm (26 lb-ft). Remove and discard the stabilizer bar link lower nuts and remove the stabilizer bar links. To install, tighten to 35 Nm (26 lb-ft). Remove and discard the stabilizer bar bracket nuts and remove the stabilizer bar brackets and the stabilizer bar. To install, tighten to 55 Nm (41 lb-ft). Inspect the stabilizer bar bushings and install a new bushing(s) if necessary.To install, reverse the removal procedure. -
well, that's not good! have you replaced the pcv valve yet?
Post pics
