fredj132
About fredj132
fredj132's Achievements
  1. On my 2007 Edge, I have complained since taking the vehicle in August that when the driver's door is closed the panels do not line up. It has been back to to dealer many times for various faults but apparently nothing can be adjusted to make the doors align when closed. This only affects the drivers side, so I suppose I should be thankful for small mercies. Has anyone else suffered from this comical built control?
  2. Yes, it's the same oil that was supposedly fixed before. I don't do any towing and am not sure where about the oil cooler in question lies. Fred J
  3. Hey fantastic, even bigger wheel to corrode and blacken at the fist sign on inclement weather.
  4. Just a quick update to the tale of woe. The latest failure is a leaking oil cooler which will take almost a month to source and repair.
  5. A quick update, the latest fault is a leaking oil cooler which will take almost a month to source and repair.
  6. I have have my Edge since August 2007 and am going to sell it as it is become more and more difficult to accept all the faults and the trips to the dealership. The latest is an oil leak which they have 'fixed' twice already but still leaves drips on the cardboard I have put down to protect my garage floor. The doors don't line up when closed, but according to Ford there is nothing to adjust, pieces of trim fall off the inside of the A pilars while driving, the bolts holding the seats down have nasty plastic covers the kids kids off every time they get in, the rims have started to corrode but according to Ford that's normal wear and tear (8 months), the Sirius radio goes off the air when some component at the back fails, the engine sounds so rough when you use anything more than 2000RPM you need ear defenders. The adverts claim that it's build with pride in Canada, well pride had a day off when mine come of the line.
  7. You'll find that the plastic cleans ok, but the actual rim edges on mine have already stared to corrode after just 8 months. Apparently that acceptable wear and tear according to Ford. Just another example of the tacky build quality and cost cutting in this range.
